Question about Estate Washing Machines
How long should a large wash load take - Estate Washing Machines
    Top Expert:
  • Estate Master
  • 9,472 Answers
Depends on the machine, setting and even the model.
Posted on Nov 03, 2012
I have a Maytag Centennial top load washer. When washing in normal or heavy with large or super load size, the washer remains in sensing mode. Some water does start to fill, but never reaches wash cycle....
This unit does not handle a super large load as it advertised. When you put a super large load, the sensor is over-sized and will not move on the next cycle.
Sep 03, 2013 | Maytag Centennial MTW5800TW Top Load...
Our LG227HW washer is showing an error code UE, what does this mean and how do we correct it
UE means an unbalance load. Either you have too small a load, too much of a load or you're washing a large bedsheet all by itself. If you are washing a large bed sheet or bed spread, you need to add about 4 bath towels in the load to help offset the balance problem. As for loads, you can only put in 15 lbs of dry weight laundry in the wash. Preferably, fill the tub with clothes half way up the window and no more.
Jun 29, 2011 | Washing Machines
I have a ge profile harmony top load washing machine. Is there any way I can get more water to fill with certain loads of laundry?
there should be something on the console that says small medium large,that's the water settings.if you have a few things to wash put it on small,large load fill it up on large that's it.
Apr 09, 2011 | Washing Machines
Washer wont wash on large load but will wash on medium and small i want to kwow what is going wrong it want do nothing but fill up and leak on the flooor when on large load should i replace the washer
the water pressure hose connected to the load size switch and the lower outer tub has a hole in it,remove the control panel and replace this hose,it uses water height/pressure in the tub to trigger the switch to operate the machine and the hole must be at the upper end of this hose,so it leaks before the water gets high enough to trigger the switch on a large load
Sep 08, 2010 | Frigidaire Gallery GLWS1339EC Top Load...
Wash starts before water is full
most washers if put on a large load do start going around before the water has finished filling this is just to get all the clothes fully wet before the proper cycle starts to wash them it is just how the washer copes with a large load peter
Nov 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Turn off ALARM - Whirlpool washer
This sounds like the imbalanced load alarm. This can occur with large heavy loads like blankets, bedding, lots of diapers (cloth), jeans etc. The best solution is to wash lighter loads and not overload the machine. If overloading continues, the machine could be damaged.
Apr 11, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
Does not agitate with large load
have same problem but mine take large and small loads and leaks
you need part #ap4253876 made by whirlpool
Feb 28, 2009 | Amana ALW480DA Top Load Washer
Timer setting
choose the load size on the timer for what your putting in large small medium etc match the water fill large small med etc select wash rinse temp to you pref add soap bleach fabric softner pull out the knob make sure the lid is closed
Feb 18, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Frigidaire FTF530FS Front Load washer
Take off the lower panel. Inspect the shocks too see if they are damaged. If they are OK turn the wash basket by hand if the knock is heard then most likely you have a broken wash basket.
Jan 13, 2008 | Frigidaire FTF530FS Front Load Washer
Washing machine letting water out on large loads
this sounds like the hose that connects the soap drawer to the drum has a split in it, within the folds, when the machine is empty the folds are closed and the water runs where it should, when loaded the folds are open so the machine leaks, check the hose and replace it, make sure it is located at both ends properly, that is the problem,, if i have helped rate me pleeasse
Sep 25, 2007 | Washing Machines
Washing Machines Logo
12 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
