Question about ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Put television on then goes off by itselfs and comes back on makes a we clicking noise off comes back on about three minutes
    Top Expert:
  • ESA Master
  • 14,553 Answers
Have the power supply looked at--the clicking sound is most likely the power relay (mechanical) coming on and then off again.
Posted on Nov 03, 2012
My sony mhc-bx7 makes a strange clicking noise 3 times when you turn it on and it then says tape b on screen then says eject and powers down. what is the fault and can i fix it?
Dual cassette deck are nothing but trouble, but on occasion they can be made to work a little longer. Maybe lose belts or the most common thing is the grease is all dried up. It requires the cleaning off and application of new better grade grease. The problem is the mechanism has to come apart and make sure it is aligned when put together- this can take 3 hours.
Aug 27, 2016 | Sony Audio Players & Recorders
DLP powers down after 1 minute; no sound or audio
REPLACE LAMP IF PERSISTENT REPLACE THE LIGHT ENGINE COS THE COLOR WHEEL IS WORN OUT
Jul 07, 2013 | Televison & Video
Tv goes on and off a few times then turns off
Thats a common symptom which is usually caused by the Small signal board. You can get a replacement small signal board from www.tvrepairworld.com
Jul 16, 2010 | RCA HD52W66 Projection Television
My tv turns off by itself and makes a clicking noise
Most likely it has some bad capacitors in the power supply. Flat--panel sets are VERY hard on capacitors, due to the fact that the "rising heat' from the set "cooks" the caps and they fail VERY early.
Oct 12, 2009 | Samsung HP-T4234 TV
TV turns off after 3 minutes or goes black
It may be an overheated capacitor in the power supply. You can test these with a capacitor tester
Aug 26, 2009 | Televison & Video
RCA TV, model number 32V550T. No picture but sound is fine.
hiya
this sometimes is quite simple to fix as it cud be a dry joint on the circuit board where the tube motor sits.
or it cud be the tube is on its way out, which wud be cheaper to buy a new tv rather than have it fixed
rik
Feb 24, 2009 | RCA 32V550T 32" TV
TV won't turn on even though it starts green, then goes off
Although my tv still does the "turn green and turn off" thing, I simply unplugged and repluggd the tv. After I did that, I pushed the "ON" button on the tv itself, unplugging and replugging the tv until it finally came on. I think the "instant warm-up" switch is going out.
Feb 18, 2009 | iLO 3200 32 in. LCD Television
I have a 52" GE-HDTV/Monitor. After the unit is turned off, it will not come back on-at all now. When I try to turn it on, the green light on the front of the TV comes on briefly, then goes off. I can...
replace CP150 CP114 and CP120 all three capacitors are available at the following link with free instructions they are listed under the RCA parts category which are the same ones for your GE TV.
http://servicemanuals.vstore.ca/
Jan 17, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Panasonic PT-61LCX65 61" Television Set Popped, Now Left with a Cicking Sound
Your problem more than likely lies in your lamp. The whirring noise you hear is the ballast trying to fire up the bad lamp. The lamp part # for your set is TY-LA1000 and can be purchased online at vance baldwin. This is something you can easily replace yourself and your owners manual will give you instructions. Hope this helps
Mar 31, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Power on and yet picture flicks and powers it's self off (over and over again)
First it's not just Philips, they all are making TV to only last a few years now, they are not made to last, thats how they make money by selling you something you will have to replace in just a few short years. As far as your problem, you may have a cold solder joint somewhere, do you have a 25/35 watt soldering iron? if so try soldering pins on the regulator IC the vertical IC the horz output transistor and drive transformer and the flyback, in fact solder just about as much as you can, spend some time in there soldering. Dont forget to ubplug the set and stay away from the high voltage anode connected to the picture tube, it can still hold a charge even if the set is unplugged, do not try to take it off. Hope this helps!
Sep 27, 2007 | Philips 27PT543S 27" TV
ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV Logo
65 people viewed this question
Top ESA Televison & Video Experts
Colin Stickland
Colin Stickland
matt martin
matt martin
Are you an ESA Televison and Video Expert? Answer questions, earn points and help others
