I cannot open dataguardian flash drive - Computers & Internet
  • 27,725 Answers
W7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp or earlier
click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with this or if i have missed the problem post a reply
hope it helps
Posted on Nov 03, 2012
Windows run doesn't keep my work history
you have to physically save any work
save the history to a usb drive in case you have computer failure
Plug the flash drive into your computer's rectangular-shaped USB drive.
Wait for Windows to recognize the system.
Windows operating systems use "plug and play" technology, which means that computer peripherals like USB flash drives can be recognized instantly by the system without further need for device configuration.
Open the drive on your computer.
Open the "My Computer" directory if using Windows XP or the "Computer" directory if using
Windows 7 or Vista. Locate the flash drive letter and icon under the section named "Devices with Removable Storage." Double-click the flash drive icon to open it.
Transfer files to the flash drive.
Click the "Restore" button in the top-right corner of the "Computer" or "My Computer" directory to shrink the window so that you can view your computer's desktop background.
Open the folders or locations of the files which you want to save to the flash drive.
Click and drag with your mouse each of the files and folders you want to save to the flash drive over to the empty space in the "My Computer" or "Computer" window.
Release the mouse button to let the files "drop."
Close the windows and directory locations when finished.
Save files directly onto the flash drive. From an open file (i.e. text, spreadsheet, image files. etc.), click the "File" menu and "Save as" option.
Select the "My Computer" or "Computer" directory in the drop-down menu at the top of the "Save As" box. Double-click the flash drive letter under the "Devices with Removable Storage" section.
Click the "Save" button to save the file onto the flash drive.
Close the windows and files when finished
hope this helps
Oct 17, 2012 | Microsoft Windows XP Professional Full...
Transcend jf v30/64gbmy pen drive is not detected in my computer
Flash drive not detected, it means there is damage to hardware.
Damage to hardware, there are two types
1. Cracked solder.
Solution: Open flash drive casings, heat the tin solder.
2. Resistor (R) broken
Solution: Open flash drive casings, replace the resistor.
Hopefully this information helps
Nov 04, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I forgot my password and i have tried to format my cruzer flash drive but it still has failed to respond,what should i do?
Hi , i hope in a certain way we can help you''' please insert your flash drive into your PC USB port then go to my computer and click to open then you will see the administrative tools click to open , then click computer management ,when it opened you can see disk management and click to open you will see your flash drive on an assigned drive letter, then on the drive where you can see your flash drive click right to follow what command do you wish to do , so click right and then click format to finish, just follow commands . . . . .
thanks,
gilbert
Aug 07, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How do I use this product to save photos off my computer?
Moving files from your computer to the USB flash drive is simple. Plug in your flash drive. Go to "Computer" or "My Computer". You should now see your flash drive show up under a drive letter, like E: or F: for example. Double click this drive letter and a window should open up. Alternatively, when you plug in the flash drive you may get a message on your computer with an option "Open/View folders and files". You can click this to open the flash drive window.
Now, go to the location on your computer where the photos are located. You can use your mouse, click and hold , drag the mouse over files you wish to move. Now that the photos are highlighted, you can click, hold and drag them to the flash drive window. Alternatively, you can right click on pictures and choose the "copy" option. You can then right click inside of your flash drive window and chose "paste". Either of these options will move the photos from your computer to your flash drive.
Regards,
G33k
May 20, 2011 | PNY 4GB Micro Attache USB 2.0 Flash Drive
How do i download itunes music to my flash drive
Open "My Documents".
Open "My Music".
Open "iTunes".
Open 'iTunes Music".
Click once on a folder.
Click 'Edit'.
Click 'Copy to Folder'.
Choose the drive-letter assigned to your flash-drive.
Click 'copy'.
May 29, 2010 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Why my flash usb is don't tell me the files
try plugging your flash drive into a usb port then going into my computer and opening the appropriate drive letter for the flash drive.
You can also put a shortcut to the flash drive on your desktop and simply open it to see what is actually on your flash drive.
You can also use windows explorer and open up your flash drive icon and see a listing of what is on it.
Your problem may be that the flash drive has its own installation program and it has possibly been wiped or cleared accidently.
Feb 08, 2010 | PQI 512MB Intelligent Stick USB 2.0 Flash...
Opening the flash drive case
remove the protective cap on one of the sides.
Jan 23, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
I can not open my Flash Drive
Your flash drive might have caught virus or viruses that corrupted your files, thus, needed to reformat and can't be open...else, u can't use your flash drive anymore and may cause total lost of data in the near future....the only choice t continue using your drive is to reformatting it. But the consequence of it is the data that you are having right now will be deleted. Be careful for viruses next time...thank u!
Oct 14, 2008 | Electronics - Others
Flash Drive problem
Try opening the 'computer' icon - normally shows as an icon on your desktop or in start menu then you will hopefully see the flash drive listed along with C Drive, CD Drive etc. Double click or right click and open - this should let you see and open individual files on the flash.
Feb 12, 2008 | Acer Extensa 710TE Notebook
How to open files on a Flash drive
You must have all the programs files for the thing your opening. For example, If Im trying to open up google Sketchup from my Flash Drive, I need to have all the files that sketch up uses to run on the flash drive.
Nov 18, 2007 | Computers & Internet
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
