Question about Frigidaire FRT15B3A Top Freezer Refrigerator
Freezer loosing its seal.
I have a side by side fridge/freezer. For no apparent reason the seal on the freezer side is not sealing properly. IF I close the fridge side firmly there appears to be a piston effect or “something” that causes the side to loose it seal. I have checked the obvious possibilities; something interfering with the seal, freezer too full, Ice maker out of place. I am at a loss. I need recommendations.
  • 2,976 Answers
Clean the door frame and the seal well. Put some DRY silicon or car wax where the seal touches, especially at the hinge edge. This is where the most friction is.
Posted on Mar 07, 2009
Gasket seal is not good
Check the door is aligned properly and meets all the way round If not, grasp the door firmly at the top and push it closed while placing the head of a mallett or similar item between the bottom of the door and the body of the fridge. This will straighten the door and the seal will fit again
Apr 22, 2012 | Kenmore Freezers
Side by side kenmore refrigerator no suction on produce side
There is no suction normally. The door has a spring type mechanism to keep it firmly closed, and the magnetic seal takes up the slack. Check the door/ hinge is straight and tight and look at the top of the hinge. There is a small cylinder about 5mm high with a number of dimples in it. One of these should have a pin in it that operates the spring mechanism; if it is missing the door will not close well.
Also make sure there is nothing in the fridge protruding, stopping the door from closing and the seal sticking!
Apr 18, 2012 | Kenmore Refrigerators
My freezer door doesnt close fully, the seal is poor & a constant draft flows from the freezer. My fridge door seals properly. You can actually HEAR the difference in the quaity of the seal (the...
Sorry to read about your problem, I hope this helps you out.
The total gasket must get replaced...
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 21, 2010 | KitchenAid Superba Architect KSCS25INSS...
Suction of freezer door
No, that perceived suction effect is the magnetic door seals 'grabbing" onto the fridge cabinet and pulling the door(s) shut firmly and securely.
Typically as the fridge gets older, you'll need to clean off both the fridge cabinet edges and the door seals to maintain a proper seal, which is essential to keeping the fridge operating properly.
Hopefully you find this Very Helpful and best regards!
Sep 23, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Kitchen aid refigerator: door won't seal then lost power.
The GFI had becme stuck - yes we had plugged the fridge into the GFI which is apparently a bad thing to do. Replaced the GFI (and moved in away from the fridge) and all is well.
Jun 02, 2009 | KitchenAid KTRC19MKSS Top Freezer...
Freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
May 26, 2009 | Amana ARSE66MB Side by Side Refrigerator
Freezer door wont seal and stay closed
Your pushing air from the fridge part over to the freezer door when you clos it,the only thing i can suggest is make sure that the seal (which is magnetic) is clean and not falling apart,inspect it all around the door,and when closing the door i would close it gently.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 25, 2009 | Amana ARSE66MB Side by Side Refrigerator
Kitchen aid superba door problem
Oct 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Noisey fridge freezer
Please check the fallowing:
-Loose flooring or floor not firm.
- Cabinet not level.
- Tubing in contact with cabinet, other tubing or other metal.
- Drip tray vibrating.
- Fan hitting another part or worn fan motor bearings. Unplug the unit and rotate fan manually by your finger.
- Compressor mounting grommets worn or missing; mounting hardware loose or missing.
- Free or loose parts causing or allowing noise during operation
- Check compressor it may contact with tubing or other parts.
- Check the body of your unit is not touching the wall or other object
Jan 25, 2008 | Freezers
Frigidaire FRT15B3A Top Freezer Refrigerator Logo
149 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
