Question about Jamo DMR 60 DVD Player/Receiver
Jamo is turning off itself when run in AUX1 input. it turns off after few minutes. but other inputs like DVD works fine
2 Suggested Answers
SOURCE: No response from DVD - Blue on light flashes but nothing else
I think we're on about the same model here. I found that holding down the "Source" button whilst switching on the power at the mains would temperorly solve this issue. However, it would be nice to switch it on normally.
Posted on Nov 12, 2008
DVP-NS77H will not work
You need to make sure that you change the input on the TV. It is most likely AUX1 or video input 1. Look on you TV remote for a button that says "input" or "source". Make sure your DVD player is on, press press play, then hit the input or souce button on the remote.
Dec 23, 2008 | Sony DVP-NS57P
My new LG LCD TV (3 days old!) suddenly started playing up, last night. I was initially using the receiver unit (with built-in DVD) to play a disc of MPG files, which it did successfully. Then, I tried to...
Good thing the tv is under warranty, theres no magical fix for a problem like this. I would either return it to the store or call for service. If you atempt to do to much to fix it you might voide the warranty, and you should have to do anything to fix it as you said its 3 days old.
Tim Nolan
Sep 24, 2008 | Televison & Video
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Vizio liquid crystal tv l32hdtv
Check the cable connections and/or replace the cables to the AV2 input.
If replacing the cable doesn't provide a solution, try running your DVD through the input. Since it works fine now, you would be checking the input AV2 by putting your working DVD. If the DVD plays with no problems, the input is fine.
Also try the VCR using coax into the TV instead of RCA into AV2. This will give you some idea about the condition of the VCR.
I suspect either the VCR or the cables.
Apr 22, 2008 | Vizio L32 32 in. LCD HDTV
Surround sound problems.
Dolby 5.1 is not supported via either of the Aux inputs. Be sure to check your main menu/audio setup screen to ensure that "stereo" is not selected. If it is, DVD's will not downmix, giving you only 2.1 stereo.
Dec 07, 2006 | GE GTD120 System
Sony with diagonal lines
Is it a composite(yellow plug)video input? an HDMI input? What if you switch the output of the cable box to another input, Make sure its not the cable box first. If it happens on another input then the cable box or the connection wire to the tv from the cable box is bad.Good Luck Ps Please rate this thread
Oct 18, 2006 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Jamo DMR 60 DVD Player/Receiver Logo
32 people viewed this question
Top Jamo Televison & Video Experts
Greg Cann
Greg Cann
Stan Skaggs
Stan Skaggs
Are you a Jamo Televison and Video Expert? Answer questions, earn points and help others
