Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
How to remove back panel of freezer in Admiral fridge freezer
I have a side by side Admiral fridge freezer ad the freezer is leaking. Advice on this site is to remove the back panel and clear out a clogged drain. We managed to remove the upper panel at the back of the freezer but couldn't remove the lower panel (which has  a kind of grating at the bottom). Any ideas?
Sea Breeze
  • 4655 Answers
SOURCE: Admiral - GC2224GEKB
Does freezer cool like the cold food section? Did this suddenly happen, and frozen food began to thaw?  Most freezers control the cooling in the cold food section. The freezer must work fine before the cold food section will work fine. Let us know more, Thanks JT
Posted on Oct 25, 2007
  • 100 Answers
SOURCE: admiral side by side
All the cold air from your freezer gets pushed into the fridge with a fan in your freezer section. So your problem is from the fact that this cold air isn't get to your fridge.
- the door that allows this cold air into the fridge, normally in the top left corner of the fridge, is stuck shut and needs replacement.
-the freezer isn't defrosting and restricting the air flow
-the temp controller for the fridge is damaged and thinks that the fridge is cold enough.
Posted on Nov 15, 2007
  • 125 Answers
SOURCE: Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
Posted on Feb 07, 2008
SOURCE: The water input to the water filter is leaking - admiral model GC2224GEKB
my water filter water line is leaking from the bottom in the back of my refrigerater. How can i get to it to repair it.
Posted on Oct 09, 2008
Sea Breeze
  • 4655 Answers
SOURCE: I have water (condensation?) leaking from under the freezer
I appoligize for not seeing your post sooner here are some links to pages that may be helpful, Let me know if you need more help as Fixya has a problem notifing me of anyones response to a solution , Thanks, Sea Breeze
appliancepartsse@yahoo.com
864-812-1887
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://appliancejunk.com/forums/index.php?topic=22.0
PART NUMBER AND MODEL SEARCH FEATURE
Please feel free to contact me the charge is free, Sea Breeze
Posted on Jul 16, 2009
How to remove back panel of GS2326CEDW/11 Admiral fridge freezer
If the water is showing on the freezer side, more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt. Also note on the maytags these days they put a rubber piece called a duck bill on the bottom half of the drain which will also cause this over time. To access this piece you'll have to pull the machine from the wall and remove the lower panel and find the plastic drain and remove the duck bill
Apr 29, 2012 | Refrigerators
My frost free, Admiral, side by side freezer just stopped working, i plugged it out for two days and when i plugged it back in neither the freezer or fridge works. Its actually warm inside both sides and i...
Whoops
The fridge has a refrigerant leak, or the thermostat has failed.
Try replacing the thermostat, if that does not work then you will need to call a technician in to find and repair the refrigerant leak and regass the fridge
Mar 30, 2011 | Admiral 26 cu. ft. Side-By-Side...
Hi I have a Maytag fridge freezer GC2227CDFB The fridge compartment has stopped working, the lights still come on when door open, the motor seems to be working, when temp. setting is turned down to 0 the...
Your problems are exactally the same as mine. I have taken the freezer back panels off and fornd the elements blocked with ice, the upper and lower channels to the fridge are blocked with ice and obviously therefore no0 cold air is going the fridge, I have de-frosted the freezer and put back together and everything works great for 2 weeks when the same thing accurs. My settings for both fridge and freezer are on the lowest possible, but the wife does fill the freezer with too much food! I guess I need an expert in!!
Jun 16, 2010 | Admiral 26 cu. ft. Side-By-Side...
Have moved into new house with Admiral freezer/fridge/icemaker. Leaks water onto floor from time to time under freezer. Ice maker not connected to water supply so not that.ANY SUGGESTIONS?
Defrost drain is clogged causing this problem. Clear the dfrost drain and pan from inside the freezer section by removeing the freezer back cover plate and you will see from there. No extra parts required just patience.
Feb 01, 2010 | Admiral 26 cu. ft. Side-By-Side...
Constantly defrosting freezer automatically and
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Oct 05, 2009 | Admiral 26 cu. ft. Side-By-Side...
Admiral GC 2027 HNKBS
Hi i had the same problem, if you ring Maytag on 08444990101 they are the uk supplier for admiral fridge freezers. hope this helps
Mar 29, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Ice repeatedly forms at the bottom of the freezer compartment. Eventually it reaches the door and water leaks out. Signature Series Frostfree Model HMG51108
Your defrost drain line is frozen up.
Turn off fridge, remove bottom freezer drawers.
Remove visible ice.
Take a hair dryer and melt ice at the back of the freezer at the drain pan.
Pour a water and bleach mixture through drain hole.
This procedure could take a hour or more.
Feb 21, 2009 | Admiral 26 cu. ft. Side-By-Side...
Admiral SAC224 fridge freezer: fridge intermittently freezes up
To Whiteorchid,
Found a fix for my issue ... hopefully it'll help you.
Up at the topleft rearmost corner of the fridge remove panel to reveal spring attached slots where cold is supplied from freezer. The spring attached had came off one end as there isn't a "slot" for the spring to hold in place (design fault?).Reattached the spring and taped on .... and hey presto fridge now working perfectly again. Hope this helps.
Sep 01, 2008 | Admiral 26 cu. ft. Side-By-Side...
Aug 19, 2008 | Admiral 26 cu. ft. Side-By-Side...
Feb 07, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
219 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
