Hoover washer dryer Error Code E12 during dry programme. How can I fix?
Whenever I try to dry clothes I get error code E12 after approximately 20 minutes (I haven't actually timed it). Issue appears to be that the machine cannot drain water during a dry programme. If I manually drain water using the hose by the filter on the front and then remove and put back the filter, it then starts again but stops after another 20 minutes. Wash programmes (without drying) work without any problems). Is there anything practical I may be able to do myself to fix to avoid a high charge from Hoover as I am outside the warranty period?
  • Dave Nov 09, 2012
    After a further test I can confirm that emptying the water makes no difference. If I leave the machine after the error and then turn it off and on again and then press start, it begins again without touching the water. Of course, it still stops again after another 20 minutes.
  • Gemma Knowles
    Gemma Knowles Dec 07, 2016
    Sounds like the British Economy as from April 2017. Press reset and hope. Failing that, sledgehammer. (Disclaimer: Sledgehammer may make you feel empowered, but you may not be completely happy with the results. Also, it may lead to the guarentee no longer being valid) Dave, I would suggest just not putting washing on in the first place. Eau de Farage will combat any nasty side effects from not washing clothes. Alternatively, you could help shore up the UKs economy by constantly purchasing new clothes. Hope that helped. Good luck!
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
E12 means a problem filling on dry cycle.
Unplug the appliance, take the top off and check that the plastic condenser below the fan is clear and clean.
If this is ok, the most likely fault is the triple valve isn't opening properly to feed water into the condenser.
Posted on Nov 03, 2012
  • 2 more comments
  • Dave Nov 04, 2012
    I removed the top and the back panel. I couldn't find anything that matched the above description. There is a small plastic fan piece, but this is attached to a small metal box which is attached to what I'm guessing is some sort of air chamber (it's a long, wide metal chamber that runs the full depth of the machine, above the drum). The only other fan is in the filter compartment, which is accessed via a small flap at the front o the machine, behind the filter where the water is not emptying during the dry programme, but nothing appears visibly wrong with this (at least to my untrained eye).
  • Dave Nov 09, 2012
    As per my new comment above, there does not appear to be any issue with the water emptying. I'm not sure what you mean by a problem filling on the dry cycle.
  • Mark Street
    Mark Street Feb 11, 2014
    Richard, I read your post over ther. What you mean with "take the top off". How can I do this?
  • Richard Roth
    Richard Roth Feb 11, 2014
    Look on the back of the top plate. There should be three screws you need to remove, slide the panel back about a half inch and lift it off.
3 Suggested Answers
  • 91 Answers
SOURCE: My LG Front Load washer
Hi dear.OE code meaning on Lg washer's"machine unable to drain in 10minutes". You can make a little test.Please remove the filter & pour some water in side drum ,watch for water coming out of filter.If it's slow, tub to pump hose clogged.(there must be some sort of fluff or coin clogging hose)if it's not slow,waters comes out freely, run machine on drain cycle & check the pump motor is it running smoothly?If not change the pump.I hope that helps.Thanks.
Posted on Aug 29, 2010
barkencoa
  • 3463 Answers
SOURCE: Instruction Manual for Hotpoint washer dryer wd420
Try this link:
http://www.hotpointservice.co.uk/hs/pages/manual/manual/search.do
Enter the model number in the search box, and download instructions.
Please rate my solution.
Thankyou.
Posted on Mar 02, 2009
Hi, my Electrolux EWX12550w washing machine and dryer, working fine on was but when I'm drying it it starts at 13 minutes then keeps working but sticks on 10min also I get an err sign it's E10
Family error code E10 is visible to customers and (could be E11,E12 and E13 only visible in service mode) means problem
with filling water.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme).
Press and hold down START/PAUSE and the nearest option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the last alarm.
The alarm sequence continues as long as the two buttons are held down.
E11 - Problems with water fill for washing
E12 - Problems with water fill for drying
E13 - Water leakage
I believe there are difficulties in water fill for drying.
Water is necessary in the drying phase in order to cool down the steam entering in the drying condenser.
Possible causes: Tap closed or water pressure too low; Drain tube improperly positioned; Water fill solenoid valve is faulty; Leaks from water circuit on pressure switch; Pressure switch faulty; Wiring faulty; PCB faulty
Dado
Sep 07, 2015 | Electrolux Washing Machines
HI would you what know what error code Er13 is?? on a Logik L614WD13 washer dryer?
Feature : Error Code-control panel display "Er13"
  • Answer : Reason:Drying heater element error. Sometimes caused by to much load during the drying cycle. Washer dryers can only dry half the wash load.
Nov 03, 2014 | Washing Machines
Error e 12 frigadaire front end loader washer
Hello paversa971 - Are you certain the error code is E12? This manufacturer does not have any E12 error code for washers. Could it possibly be E10 or E11? If so, washer may be experiencing a water fill issue.
Dec 14, 2012 | Frigidaire ATF6000ES Front Load Washer
Hoover washing machine showing H05 error
Error code: h05 coming up when i switch on the tumble - Fixya
www.fixya.com/support/t8443068-error_code_h05_coming
Feb 24, 2011 - Question about Washing Machines. Open Question ... SOURCE:Hoover washer/dryer VHW854D SHOWS ERROR. I have exactly the same ...
I have a 3 month old Hoover washing machine [DYN10146P ...
www.fixya.com > Forum > Washing Machines
Aug 11, 2011 - I have a 3 month old Hoover washing machine [DYN10146P] with aH05 fault. ... Have just looked in the service manual, it reads: Error 9 - Cancel the programme by returning the selector to the OFF .... show e-60 on screen.
Hoover and Candy Washing Machine Error Codes - YouTube
? 5:00
https://www.youtube.com/watch?v=kzhlvB2LjXg
Sep 1, 2014 - Uploaded by eSpares
Does your Hoover or Candy washing machine stops before .... I have a question: My Hoover displays the error code E08. what can I do to fix it?
Nov 18, 2012 | Washing Machines
ERROR CODE H02 ON MY HOOVER SENSOR DRY WASHER DRYER WD9616C
Hi I have the error code ho2 on my Hoover wash machine does any one no what it means
Oct 21, 2012 | Washing Machines
Dryer turns off after approximately 20 seconds. Error code E4
E4 Tumbler rotation failure If during a cycle the tumbler rotational speed drops to 0, all outputs will be turned off and error code E4 will be displayed.
May 17, 2011 | KitchenAid KHGV01RSS Dryer
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
F13 error during drying cycle
Hi, that indicates that either the fan motor is not working/ blocked or the dryer thermistor (thermostatic sensor) is playing up. Of course, the pcb reads the sensor so it could also be that causing the error.
May 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Kemore Elite Oasis Dryer Error Code "AF?"
Problem solved! We read on here about someone else addressing the AF code by removing the back panel and fixing the pully that had come off. Belt was fine, with pully back in place dryer now works perfectly again. Thank you for saving us so much time and money!
Jun 14, 2008 | Kenmore 67082 Electric Dryer
Error 20 AEG washer dryer
On 40c wash hit E20 error so moved programme onto long spin and all ok!
Jan 09, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Washing Machines Logo
4,161 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
