Question about Hardware & Accessories
My nail gun hitachi nr90gl want shoot nails - Hardware & Accessories
    Genius:
  • 1,669 Answers
You really did not describe the problem well enough for me to analyze and help you fix it so I have sent you a website that shows a similar nail gun in exploded view (all the parts) so that if you open up your gun to look at what may be broken you will know:
http://www.ereplacementparts.com/hitachi-nr90gr-312-gas-powered-round-head-framing-nailer-parts-c-7927_13310_13317.html
Posted on Jan 14, 2013
Hitachi troubleshooting
Since TV's don't shoot nails, I'm assuming your post is mis-matched somehow. Can you post again, with some more information and please specify what device you are asking about, a TV or a nail gun. Thanks.
Mar 30, 2014 | Televison & Video
Hitachi NR83A2 nailer pushes next nail down
Are you using full round head nails?
The hissing indicates your O-rings are worn out and need to be replaced. This is not covered by warrenty and is common for all nail guns. Lots of kits are available on Ebay or your local Hitachi service center should stock them.
Hope this helps,
Cheers
Jan 22, 2010 | Hitachi NR83A2 2" To 3 1/4" Full Head...
I have a hitachi nv 65 ah that will shoot two nails at time
I hope this doesn't offend you. What I'm suggesting is that you may not be using your nail gun correctly. Some people keep the trigger pulled and bounce the gun onto the wood. This technique works okay, but placement accuracy of the nail suffers. The other technique is to place the gun on the wood and pull the trigger USING TWO HANDS! This is the technique suggested by the manufacturer. The problem with this technique is that if you apply insufficient pressure to the gun (USING ONE HAND) the safety is not engage so you don't shoot a nail. What usually happens - I just witnessed this a couple of weeks ago - is that not enough pressure is applied while pulling the trigger so you push harder and end up bumping the gun which shoots a nail - because you have the trigger pulled, but the nail shot was a surprise so it causes another bump (and is more apt to bounce because you're using just one hand). Because it is a machine and can operate faster than your reflexes - it shoots another nail. This happens before you can lift it off of the wood, or remove your finger from the trigger. That's the reason I keep the trigger pulled and bounce it. I know that after the bounce I've set a nail, and can remove my finger from the trigger. When I need to accurately set a nail I always use two hands, press hard and pull the trigger, and release quickly. Only pull the trigger when you know you're about to set a nail, and are poised above the workpiece.
Dec 09, 2009 | Air Tools & Compressors
Need to know size nail that it shoots and do you have new lables for the gun
This gun takes 2"-3 1/4" .113" - .131" Paper striped 34 degree clipped head nails.
This is the Tool Card provided by Hitachi. Follow link:
http://www.hitachipowertools.com/product/files/pneumatics/framing_nailers/NR83AA3toolcard.pdf
Sep 07, 2009 | Hitachi NR83AA3 3 1/4" Clipped Head...
Does no want to shoot nails till you put the back of the nail gun up 10 degrees
This is because the safety on the nose of the gun has to make good contact for the trigger to be active. It may have some adjustment. Consult your owner's manual, or Hitachi.
Regards, --W/D--
Aug 18, 2009 | Hitachi Tools & Hardware - Others
Sparks when shooting a nail
It is common to see sparks. It is metal striking metal. Although, if it sparks alot. It could be a chipped driver blade and the nail would not drive all the way. Does your sink `em?
Aug 15, 2009 | Hitachi NT65MA2 1 1/4 To 2 1/2 Inch 15...
Gun wont recoil to spit a nail out
the sring on feeder paw broken or missing
Mar 20, 2009 | Hitachi Tools & Hardware - Others
Won't feed nail
This happens to my gun too. You probably need to oil the gun once in a while. Here is how you fix it:
Disconnect the gun from the compressor first don't wanna get hurt or anything like that. There is a pin that shoots the nail out well that pin is jammed so what you have to do is push that pin to the original position. using a flat head screwdriver would help you to push that pin back into place. Let me know how that turns out please. I pretty sure that is the problem with your gun. Make sure you lubricate the Nailer once in a while.
Sep 24, 2008 | Hitachi NR83AA3 3 1/4" Clipped Head...
Hardware & Accessories Logo
71 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
