Question about Sony FD Trinitron WEGA KV-21CL10 21" TV
How do i adjust picture width on sony KV-21cl10B
I need to reduc the width of the picture, I think it's done using the remote but I don't know the codes
    Top Expert:
  • Sony Master
  • 14,553 Answers
It is done by remote by entering the service or tech menu---you have to be very careful as one wrong move and poof-------different buttons navigate and others change the settings and a last pair save the adjustments.
Want the entry or ?
Posted on Nov 03, 2012
    Top Expert:
  • Sony Master
  • 74,136 Answers
Check this link to download the user manual to your Sony TV. It has all details.
5 Suggested Answers
  • 4234 Answers
SOURCE: Sony Trinitron Color TV KV-35V65 - No Picture, red light stand/by timer flashing
A reset won't fix this. The standby light should be blinking a repeated count with a 3 second pause inbetween. Post that count here. That will indicate the circuit/condition that is preventing the set from turning on.
Thanks,
Dan
Posted on Jul 18, 2008
SOURCE: tv remote codes
I have a Zenith universal remote that i want to program to a sony 27 inch Trinitron, what are the codes?
Posted on Nov 19, 2008
SOURCE: need remote codes for Sony trinitron kv-27s66
I have the same T V and i used the code 11100 and it worked . Give this a try and it should work. for T V Sony Bravia lcd
Posted on Apr 10, 2009
gopakumarg43
  • 74136 Answers
SOURCE: I have the 2000 Sony
Hello
To turn the PIP feature ON and OFF press the button marked PIP on the remote contro. Each press will get it vanished and reappear. OK.
Posted on May 08, 2011
Sony KV-40XBR700 40" CRT WEGA
I too would like to know the solution to this question...we are having the identical problem and Sony doesn't seem to know how to fix it. Although, the picture from the DVD player is perfect, the pictures for cable & video games are terrible. Very frustrating!
Aug 24, 2011 | Sony KV-40XBR700 40" TV
Sony Trinitron KV-ES34M90 turns on OK but goes off after about 5 mins. Timer is off. The screen goes orange before it turns off and the red light flashes x2 at intervals. Could you please help me with...
The two blink code means the set is turning off because of over-current protection. This, along with your saying that the screen turns orange before the set shuts off, leads me to think your picture tube is bad. What's probably happening is that as the tube heats up (there's a filament like that in a light bulb in the neck of a conventional picture tube) one of the metal elements moves and touches something it shouldn't. This then lets high voltage from the tube get to places it shouldn't and the protection circuit kicks in.
There's no fix for this other than to replace the picture tube. It would be far less expensive to buy a new LCD or plasma TV than to buy a replacement Sony tube. And the replacement tube then needs convergence to get the red, green and blue color beams properly aligned and adjustments to get them balanced. Work done in the field seldom looks as good as the factory job, and it can be disappointing. The LCD or plasma sets don't have these issues.
Now might be a good time to start checking sale prices.
Jun 22, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a new Sony VPCJ1 series desk top. When I make a slide show, the slides are much larger than the pictures in the video file and they don't show all of the picture. what can I do. I have tried...
Are you using the laptop screen or using a larger monitor or projecting the slide show? The screen resolution on the Sony may need to be adjusted.
Apr 15, 2017 | Arcsoft MediaImpression for PC
Picture is out of line
One of the following may be misaligned. i) Aspect ratio of your TV may be wrongly selected. i.e. select 4:3 in place of 16:9 or vice versa with your Remote . ii) Picture Width or Height may be wrongly adjusted. With the help of Remote, select MENU go to PICTURE option, reduce height or width which ever is needed.
Have a nice day Rating the solution is highly appreciated.
Mar 07, 2010 | RCA HD52W58 52" TV
Picture image does not look full when showing people
There is a service menu adjustment. I have seen several of these sets with bad components in the horizontal width control circuit. maybe your other set has a width problem. put both on the same channel. like cnn with the ticker on the bottom. what is the difference in size?
the width adj. procedure is: with the set off. use the remote, enter. MENU>5>VOL+>POWER . the set will come on in the service mode. then with the menu adj. buttons you can step threw the service menu to H.WIDTH adj. until full picture. also VERT. HEIGHT. when you are done adjusting make sure you press the mute button and watch the word WRITE flash from green to red or you won't save your adjustments.
Jan 07, 2010 | Sony FD Trinitron WEGA KD-27FS170 TV
What is the width of the tv
this is a pin-amp section problum .
if your tech. pls check sum spare in Pin -amp section .
pin-amp ic / capaciter / pre-set .
( i think your tv set screen is low width and up or down corner is bend ) if yes then replace capaciter 10uf/63v non poler or Pin IC
Oct 06, 2009 | Sony KV-27S20 27" TV
Fine interference lines running diagonally across picture.
Hi There,
Sounds like your Horizontal Output Circuit is leaking current causing diagonal lines across the screen. I hope this will help and thank you for using FixYa!
Mar 29, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Replace color
Hi.
Try pressing menu on the remote then move cursor to picture & adjust the colour.
http://dysonmanuals.inc.io/
Chris.
Nov 09, 2007 | Sony KV-36FS16 36" TV
KV-32S45 Disappearing Picture, Good Sound
yes you have a bad vertical ic . i,ve seen bad conections on this ic too, it may not need to be replace its a ic that stands up 6 pins the numbeer on it starts with TDA
Apr 19, 2007 | Sony KV-32S45 32" TV
Sony Tv kv 2584 A5
There are no adjustments for this problem,if the unit has been working good for 3 years and suddenly gives you this pix is time to call a qualified technician,among many reasons you might have loose solder conections in the horizontal drive circuit or poor regulation problem in the power supply,if you dont know how and where be safe and call a Technician.
Aug 30, 2006 | Sony KV-32S26 32" TV
Sony FD Trinitron WEGA KV-21CL10 21" TV Logo
81 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
