Question about Bosch Classixx WFL 2066 Front Load Washer
Remove filter for cleaning
Unable to remove filter for cleaning
    Top Expert:
  • Bosch Master
  • 9,472 Answers
Could you please describe the problem you are having a little better?
Posted on Nov 03, 2012
Unable to remove back panel
There are two Philip screws located on the edges of the back. Remove them this will allow the back to be taken off. Then remove the two screws at the top bracket that holds the filter in place..Ypu can remove the filter and bracket No need to remove any more of the screws on the back . From there you will see the plates and another filter. You can get at them by removing the two screws on the left and right of the plates..You can take the plates and filter out for cleaning and change the bulb if needed....NOTE; the filter on the back is resting on a activation switch just make sure when replacing the filter and bracket is pushed down to activate or the machine will not work..good luck....
Mar 24, 2014 | Ecoquest Fresh Air Air Purifier
How do i get my filter out of my bush a127ldw washing machine got E03 error am working my way through your list but cant get filter out
Water inlet filters
On the tap part of your machine's water inlet
hose and at the ends of water inlet valves, there
are filters to prevent entrance of the dirt and
foreign materials in the water to the machine. If
the machine is unable to receive sufficient water
although your water tap is fully opened, these
filters should be cleaned.
x Remove the water inlet hose.
x Remove the filters found on the water inlet
valves by using a pincer and wash thoroughly
with a brush. (1)
x Clean the filters of the water inlet hoses
located on the tap side by removing manually
together with the seal. (2)
x After you clean the filters, you can fit them
the same way as you have removed them.
Pump filter
The pump filter system elongates the life of your
pump, which is used to drain the dirty water. It
prevents lint to enter the pump. Cleaning of your
pump filter in every 2-3 months is
recommended. To clean your pump filter:
x Open the kickplate's cover, by pulling the
handle. (2-A & 3-A)
x Before opening the filter cover,place a cup in
front of the filter cover to prevent flow of the
remaining water in the machine.
x Loosen the filter cover by rotating it counter
clockwise and drain the water. (4-A)
x Remove the foreign materials from the filter.
x Check for the rotation of the pump manually.
x After you have cleaned the pump, fit the filter
cover by rotating clockwise.
x Put the kickplate cover into place.
x Do not forget that if you do not fit in the filter
cover properly, it will leak water.
Jan 21, 2013 | Washing Machines
Unable to open pump fillter
Remove the kickstrip, front of the appliance. Unscrew the pump filter by rotating it anti-clockwise, A little water may leak from the pump: this is perfectly normal. Clean the interior thoroughly, removing any visible debris. Refit by screwing the filter into place.
Jan 04, 2012 | Hotpoint Washing Machines
How to clean water pump
Hi
To resolve the issue you’ll need to then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn’t work then you’ll need to check the connections of the drain pump, check the connections with a multimeter. In case you need more information then please post back with the make and model number. Hope this helps...
Daniel
Aug 30, 2010 | Whirlpool Washing Machines
Retractable vent stuck
after struggling for hours to remove vent for cleaning, I just happen to pull frong panel forward, and that release the vent so that i could clean it. No big deal. Simple
May 29, 2010 | KitchenAid KIRD861HSS Kitchen Hood
Unable to remove filter on machine
Assuming you have located the filter at the bottom front of washer, you unscrew it anti-clockwise to remove and clean.
If there is a small screw in the filter handle, then unscrew it first, before removing filter.
Please rate my solution.
Thankyou.
Feb 01, 2010 | Candy AQUA1000T Front Load
I have a Creda 1200 washing machine, I am unable to locate the fluff filter. Does my machine have one? if not, what happens to dogs hairs etc? will they damage my machine?
The filter is at the rear of the washer.
Remove the lower rear cover of washer.
Remove the large black hose fastened to bottom of drum.
Clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well..
Thanks.
Jan 17, 2010 | Creda W120VW Front Load Washer
UNABLE TO REMOVE FILTER ON ZANUSSI, EVEN THOUGH UNSCREWED
Having made sure you have unsrewed it all the way, then try pulling from side to side as you are unscrewing it, if you still can;t get it out, then something is stuck inside the filter, or the filter housing, this will entail removing the pump complete to clear blockage.
Thanks.
Oct 10, 2009 | Washing Machines
Remove lint holder on ge front loader dryer
I have the exact same problem. I am amazed at had been the engineering is for such a simple process. The user guide just says to clean the lint filter. Even when doing so, there is still an excessive build up of lint beyond reach. There are no instructions that mention how to clean this part. It is obvious that GE did not test this part of the machine.
Jan 30, 2009 | Zanussi ZWF1440 Front Load Washer
Bosch Classixx WFL 2066 Front Load Washer Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
