Question about WonderMill Grain Mill 240v - International Model
Wondermill jams before hopper empties when milling wheat
Wet nuts inside grinding heads of WonderMill
1) Don't pour water into the chamber.
2) Grind some white rice through it. That should begin to absorb the almond oils. Dust it off with a pastry or paint brush.
The bit about the brushes comes straight from the manual:
https://www.thewondermill.com/pdfs/WonderMillManual_web.pdf
Just in case you have a clogging problem subsequently:
How to Unclogg Your WonderMill or Whisper Mill grain mill
Feb 03, 2018 | WonderMill Flour Mill
How can we fix a nutri-mill wheat grinder?
can you see the grinding wheel /blades . if so try to rotate it /them slightly by hand
Dec 17, 2015 | Nutrimill Grain Mill Grinder
Why Oki b4600 after changing drum devolves toner empty
The toner cartridge is only a supply chamber. The cartridge simply dumps toner into the feed hopper in the drum. When you change the drum the feed hopper is empty and it is likely that the cartridge dropped the last of it supply into the hopper - ergo it is now empty. I recommend shaking the toner back into the cartridge before separating the cartridge from the drum unit when changing them
Sep 08, 2014 | OKI B4600 Printer
Won't turn on
Possibly a piece of rock or other debris stuck in rotating portion....if it "hums" when powered on, you will need to invert it and shake it - or carefully tap it on a dishtowel to dislodge the stuck debris.
Mar 05, 2014 | Nutrimill Grain Mill Grinder
Paper jam 2 but no paper is stuck
Most printers/faxes need more than one or two sheets of paper in the hopper in order for printing to commence. If it's not that, take out all paper. Turn off the printer/fax. Wait five minutes and turn printer/fax back on. With some printers/faxes, that almost acts like a re-boot. Good luck!
Mar 28, 2012 | Samsung SF-5100 Plain Paper Laser Fax
How do I clean my burr mill (Models BMX3, BMX4, BMX5 and BMX6)?
Clean your burr mill before using it for the first time. Then, to ensure optimal mill function and durability, clean it regularly following these simple steps.
  1. Always unplug your burr mill after use and before cleaning.
  2. Open the hopper lid. Empty any whole beans from the hopper. Remove the top burr mill by rotating it clockwise. For better results hold the grind setting button while rotating the burr mill clockwise. This will allow you to clean the grinding wheel and the grinding compartment.
  3. Clean the interior recesses with a soft brush. Note: Never use water or liquid for cleaning the lower grinding section of this appliance. BRUSH NOT INCLUDED.
  4. Wipe the whole bean hopper, its lid and the mill exterior with a damp cloth.
  5. The ground coffee chamber and lid can be washed in mild detergent and water. They both are top rack dishwasher safe. Do not immerse the mill or the whole bean hopper in water or any other liquid or place in dishwasher. Use only non-abrasive cleaners to remove stains.
  6. After completely drying the whole bean hopper and top burr mill, replace the burr mill in position by aligning snaps with receptacle and rotating counterclockwise to lock it in position. For better results, hold the grind setting button while rotating the burr mill counterclockwise. Once the burr mill is in position, pull gently to check it is properly locked in position. If the burr mill comes out, repeat this step again.
  7. Replace the ground coffee chamber and lid, making sure both snap securely into place.
  8. Fill the hopper with whole beans.
Sep 02, 2011 | Bunn NHB Coffee Maker
I haven't used my torilla press for quite awhile & want to start using it again but have lost the instruction/recipe book for it. Would you have one on-line? I remember that there is a bit of a...
the Villaware manual is here
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000046402.pdf
Villaware support site
Instruction Manuals at VillaWare com
Wholewheat Tortilla making
video
Video Recipe How to Make Whole Wheat Flour Tortillas by Archana Kitchen
Homemade Whole Wheat Tortillas (Using a tortilla press and cooker)
foodstoragemadeeasy.net > Recipes > Cooking From Scratch
Feb 27, 2012 - I've been making homemade whole wheat tortillas for awhile now by hand. A friend of mine called me a couple weeks ago and said she ...
Whole Wheat Tortillas with My Tortilla Maker ' Grain Mill Wagon
www.grainmillwagon.com/whole-whea-tortillas-with-tortilla-press/ Rating: 5 - ‎2 votes
Jan 15, 2013 - Whisk together all dry ingredients in a mixing bowl. In a separate mixing bowl mix together hot water and oil. Stir wet ingredients into the flour mixture with a spatula until all the flour is sticking to the dough. Spray the top of the dough with a little oil and cover with plastic wrap. Leave it for about 5 minutes.
General information and videos on making Tortilla with a press.
Making Tortilla with a press - Google Search
Jul 07, 2017 | VillaWare UNO Flatbread Maker 5955
Grain mill stops turning
Will it grind any wheat? I had a similar problem with the wheat overwelming the drive system and had to use smaller amounts of wheat to keep the system grinding. Do you have the feeder attached? I couldn't just load it up but had to feed a little at a time. Hope it helps. Favorable comments are apprieciated.
May 08, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Card hopper jamming
Could be that your cleaning unit is not installed or is old. Or, it could be too few cards in the card hopper. You could apply a little weight to the cards in the hopper to see if that helps. And/or try changing out the cleaning cartridge.
Oct 04, 2008 | Fargo DTC520 Thermal Label Printer
Osyer burr mill 6389
Apparently, you unplug the unit, dump any beans out of the supply hopper, then rotate the burr intake module in the bottom of the supply hopper counterclockwise. You can then pull it out, and brush it out. You also brush out the other half of the burr unit; don't put water or anything in it, you'll kill your grinder. You can, in theory, wash the removable module, but if you do, be sure it's ABSOLUTELY dry before you put it back together.
Jun 15, 2008 | Oster Coffee Burr Mill - 6389 Grinder
WonderMill Grain Mill 240v - International Model Logo
Top WonderMill Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a WonderMill Saw Expert? Answer questions, earn points and help others
