Question about Western Digital HDD WD5000AAKX 500GB SATA 6GbS Desktop 7200rpm 32MB Cache 35inch Bare Drive Parallel ATA Hard Drive
Western Digital HDD WD5000AAKX reads slow..
Every time i use this WD HDD my computer run so slow and even if i reformat it still the same...can anyone help me...pleae
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 137 Answers
What do you mean by slow? Compared to an SSD the HDD would obviously be slower. If you're running your OS and everything off that HDD, try defragmenting it. Please run benchmark tests (e.g. Crystal Mark) and tell me the results you get! Typically you should get 120MB/s for your type of hard drive.
Posted on Nov 03, 2012
calanan
SOURCE: Need to open WD MyBook 1TB HDD model WD10000H1CS-00
I have this same problem and found a great write-up here that has text and photos of the process. I haven't tried the process with mine but there are plenty of responses to his posting indicating success. Good luck.
- mike
Posted on Dec 10, 2008
praky16
  • 744 Answers
SOURCE: 750GB Western Digital HDD won't turn on.
hi.. try to Remove the drive from it's external case, and try a different hard drive. If that works, your drive is the problem. If it still doesn't work, the USB to IDE interface is the issue.
Try mounting the original IDE drive internally, and see if you can read it there. If not, you'll need to send it to a data recovery center...
thank u
Posted on Feb 09, 2009
niquose
  • 198 Answers
SOURCE: Western Digital External HDD not appearing in My Computer
It could be that the OS is not assigning a drive letter to your removable drive. To do this, go to disk management and assign one.
Assuming OS is Win 2000/XP/Vista
Right-click My Computer then Manage
Click on Disk Management
Right-click the removable drive and click on Change Drive Letter
Assign a drive letter and click OK
Your drive should now show up on My Computer
Hope this helps.
Posted on Jun 25, 2009
nclark557
  • 15 Answers
SOURCE: WD is suddenly unreadable by my computer!
go into my computer it should be there
Posted on Jul 28, 2009
miokitty
  • 17 Answers
SOURCE: cant connect my 1TB WD world edition to my linksys router
Your My Book World should not be formatted or you will lose all ability to access it through the Network -- it will simply become a hard-drive at that point. There is software installed on the hard-drives that communicate with your Router in order to obtain an IP and be available as a Network Drive. If the drive and the Router are communicating, you should see an IP in the DHCP list of your Router. It is possible that the My Book World is not setup for DHCP, so if it is placed in an alternate environment with incompatible static IPs, it won't be able to access the Internet or be available locally. You can try a hardware reset on the drive and see if it pops up in your Router's DHCP/Client list, at which point it should also appear locally and over MioNet (MioNet will need to register the device to an account before it will appear in MioNet, but it must detect the drive locally in order to attach).
1. Turn off My Book World
2. Identify the reset button on the back of My Book World
3. Depress the reset button while restarting My Book World
4. Keep the reset button depressed for about 10 seconds after you see blue lights on My Book World
Posted on Sep 18, 2009
How do I make a 500 GB wd5000AAKX slave
SATA doesn't use the Master/Slave scheme like PATA. You simply plug it in.
Jul 11, 2015 | Western Digital WD Blue WD5000AAKX 500GB...
Lost password on WD Scorpio Blue WD5000BEVT hdd
Password is for the computer, not the hard drive. Get a Linux LiveCD and reformat the drive.
May 05, 2014 | Western Digital WD Scorpio Blue WD1600BEVS...
Wd5000AAkX no jumper diagram need to put it as a slave
There are normally no jumper settings on a SATA HDD as you can only connect one drive per SATA port, hence every drive is a Master on its own port.
You can set Boot Priority within the BIOS settings if you have more than one drive attached.
Dec 13, 2011 | Western Digital HDD WD5000AAKX 500GB SATA...
I just got a 1.5 TB WD ext HD. It blinks evenly & slowly when the computer is sleeping. It blinks rapidly when the computer is awakened, & becomes solid during the time the computer is...
Seems perfectly normal, the slow blink while sleeping shows you that it is active but not in use (witched off but immediately available) The rapid blinking is the machine accessing the disk and the constant light means it has power but not connected. The occasional blink is probably the HDD parking the reading head or shutting down the disk or both.
Nothing to worry about.
Jan 15, 2011 | Western Digital My Book Essential 1TB...
WESTERN DIGITAL WBDAAR3200ABK-00 EXTERNAL HDD NOT WORKING
Every time windows tells you to format the drive, copy your data to your computer then format it. when windows detect problems on the drive, it will launch ckdsk, well i dont know hoy to fix it, try plugging it in then reboot.
May 02, 2010 | Western Digital Elements powered by WD 320...
Running slow
Yes, it should. But I I think you should first try to perform a search for *.tmp, *.chk and *.dmp and erase them by pressing Shift+Del. That way they will not get to the Recycle Bin and will be permanently erased.
Apr 17, 2010 | Western Digital My Book Home Edition 500...
Western Digital HDD WD5000AAKX 500GB SATA 6GbS Desktop 7200rpm 32MB Cache 35inch Bare Drive Parallel ATA Hard Drive Logo
399 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
