Question about Bosch Ovens
Oven doesn't heat up and no light symbol shows up on the indicator panel.
Hi, We hope you can help us find the solution. Just installed a new Bosch oven. Followed the instruction. Set the time. After selecting the function then turned the temperature knob but the light symbol doesn't show up on the indicator panel however warmish air blows for 20 mins but It is still does not heat up properly. Is this a faulty oven? We also tried the trouble shooting in the back of the Instruction as well.
  • Noir11 Nov 06, 2012
    Hi Jason Thanks for your solution. Our oven is seems started working now. We delayed posting our comment since we weren't so sure what fixed our oven a part of turning the main power off as we followed your comment. We turned both knobs many times (to clean the dust off as instruction booklet said) After several attempts to reset the timer suddenly the light symbol appeared in first time after all. We baked potato it worked ok. We hope the oven isn't lemon. Question of reliability remains. See how it is keeps going. Thanks everyone for your kind suggestions and comments.
    Sergeant:
  • 264 Answers
It sounds like you tod stat has gone if you turn the oven off from the mains pull the oven right out and take the lid off you will see a little black stat with two wires join then up together do not let them tuch any thing then turn the oven back on if it all works afther you put the time in you will need a new one of them ok hope i have helped you
Posted on Nov 03, 2012
blackmar
  • 235 Answers
SOURCE: The house I've just bought
Most of these ovens have two fans. A fan forced fan in the oven and a cavity extractor fan inside the cavity of the unit between the outer skin and the oven wall. The cavity fan blows hot cavity air out the front of the unit so it remains cool. If the orange indicator light is coming on this would normally be the oven element thermostat. Leave it on and see if it gets hot. If the light goes off when you select the function switch it means you are turning it off the oven function. Your interior oven light may be blown.
Hope this helps.
Posted on Feb 07, 2011
SOURCE: OVEN will not heat
After reading the above, here is how I fixed my KEBS177DSS9
I pulled out the wall oven from the cabnet. Took off the back tin panel about 10 tin screws. Follow the wire from both heating elements. They are both connected to a thermo fuse. When using the self clean feature this fuse protects the oven from over heating and starting a fire. I put a jumper wire from the hot lead on the left and connected it to the 2 leads on the right side. I turned the power back on and turn the oven on to bake at 350 degrees. Yep It worked like a charm. I bypassed the thermal fuse and used the oven, until the new thermal fuse was ordered. If you have any questions about this fix email me at jodunn5555@aol.com Good luck
Posted on Dec 24, 2007
  • 3 Answers
SOURCE: Oven heating problems
I'm afraid you might need a new thermostat. The only other thing you might check is to make sure that your 'vent' is not blocked with a pan or tea kettle etc., but I'm pretty sure it is a thermostat.
Posted on Jun 09, 2007
KitchenAid KEBC107KSS does not heat hot enough and does not heat evenly. When the temperature is dialed higher, it burns the cookies. When the convection fan is on, it has a 'cooling effect' so the temperature never reaches the proper level. Is this problem repairable? Or is this a thermostat issue? Thank you for your help!
Posted on Jul 17, 2009
SOURCE: Bosch oven function error e124
bosch hes252u electric range on the screen shows erro 24
Posted on Jan 09, 2010
I have a Bosch oven with the "key" sign constantly lit and the oven won't function at all. Re set it at wall etc.
the key sign shows that the child lock is engaged. to unlock, usually you push and hold the lock button for a few seconds. the correct button is usually a dual function and so marked. if you need more help, go to manualsonline.com and look up your model number for your manual. good luck
Dec 27, 2015 | Bosch Ovens
My oven doesn't heat up
It could be the switch or heating element
Mar 17, 2013 | Thermador SM272 Electric Double Oven
Simpson Neptune, atlas series electric oven isn't working.
Hi If you have Simpson Neptune 3U 602 then it may be to do with the timer function. This also happened with my oven.
There is a red section on the face of the clock. The oven seems to work if it shows the hand icon. I'm not sure what it symbolises yet, as it's a new oven for me, but it is now working. You can change the icons by turning the left nob left and right. Hope this helps.
Jul 07, 2012 | Ovens
Whirlpool self cleaning oven will not heat up after cleaning. Lights and fan come on but not the elements. I have 223 volts to oven.it is model number RS696PXE
Hello Ken, welcome to FixYa.
It sounds like the hi-limit safety thermostat may be tripped, the scenario you described is exactly how this would manifest
...that is the component that typically trips/activates during a self clean on many ranges. You shouldn't need to open the front control panel, but access is through the back. (this can also occur during power surges)
You'll need to slide the range/oven out from the cabinet. If you slide the unit away from the wall and unplug it you can check the hi-limit.
Based on the model number you provided it should be a non-reset type hi-limit or push to reset. If non-reset it needs to be replaced.
**Unplug the range from the wall first of course...safety first**
Once you remove the panel you will need to look for a switch/thermostat which looks like either of these...
NON-RESET
PUSH TO RESET
(Not likely...unless model is wrong)
The replacement if necessary are available at "searspartsdirect.com" or "repairclinic.com" to name a couple.
Let me know how you make out. Good luck. I'll watch for your reply and if you need anything further I'll be glad to help in any manner I can.
Regards,
Macmarkus :)
Oct 24, 2011 | Ovens
Gorenje EI44A1-T34 or EI44A2-T44 Dear Sirs,we have the oven for quite a while,but never used the oven part of this induction oven. And therefor didn't bother too much with the blinking light showing...
I hope you have found already solution for this... Anyway this may help others: press buttons 1 and 2 together and release. Then use jog wheel to adjust time. Wait 5 seconds and you're done. Gorenje manual sucks, no info about oven controls. I managed even to set on oven child lock (key symbol), only way to take it off was to remove fuses from electric board of our house!
Jun 24, 2011 | Ovens
My Kenmore Electric Range model 790.9661 seems to have a control board problem. Before replacing the $200 part, just wanted to make sure it was the problem. The clock works, but the oven temperature side...
From your description it sounds that the board is the problem. I found the control panel you need for a lot less than $200 though.
I found one online from a store that I have bought from many times. Part and shipping is about $153. They sell brand name stuff too and they have great service. I hope that this helped you.
Control Panel
Good Luck from a bored repair man!
Joey
http://www.pricedrightparts.com/products/Frigidaire-Control-Panel-316402715.html
Jun 11, 2011 | Kenmore Ovens
What does F1 mean on the display panel on my Jenn Air gas oven? It won't allow me to heat up the oven, and the igniter is fine.
F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode or
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor gotsta be within spec or it will cause the F1 code. As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode. This is equivalent to 350°F in the oven. The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit). The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms. The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness, harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad. If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously. If the F1 code is given immediately (instead of during or after a heat cycle), remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes, then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner. The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied, the surface material can break down causing shorts. If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel -don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Hope this helps.
Jun 03, 2011 | Jenn-Air Ovens
Hi there Have recently moved into a house with a Belling 626 white, electric cooker and the grill doesn't seem to be working. It has a mian oven, top ovem and "dual grill". The main oven...
ISOLATE THE MAINS POWER BEFORE CHECKING THE APPLIANCE
Run your fingers along the grill element, in this model it is accessible, check for raised areas or small hole or roughness not food burnt, if visible, it should be Black Grey colour at the blemish, you can obtain parts from www.whitegoods.co.uk you will need the model and serial numbers.
The grill elements come out but when unsrewed sometimes the ceramic holders crack, remove element before ordering as you may have to replace the element holders.
Hope this has been helpful
john
May 31, 2011 | Belling Ovens
No name on the oven so presume it's a Europa same as the cooktop. It won't move off 0:00 with automatics on the lefthand side showing.
Hi -
I'm assuming this is an Omega/Creda Europa oven. All you need to do to make the oven work again is set the clock. The 0:00 and "AUTO" will stop flashing and the oven will work again. You didn't specify a model number, but you should be able to set the clock as follows:
1. Hold down the two buttons on the left-hand side under the clock display. One should have a symbol of a bell and the other, a symbol of a cookpot (not a cookpot and 'STOP').
2. While still holding both of these buttons, use the + and - buttons to set the clock to the correct time. The clock needs to be set in 24 hour format.
If this doesn't work, look for the buttons under the clock with the bell symbol and the cookpot symbol. Hold both of these buttons in and use the + and - buttons to set the clock.
If this doesn't work or your clock doesn't have these buttons, let me know and I'll check for other possible methods of setting the clock on Europa ovens. If you can find the model number it would assist me greatly. This should be on a sticker on the rim of the oven and can only be seen when the oven door is open - possibly at the bottom. The model number should be something like 40-1, 60-1 or 66-1.
If you can't find the model number, please let me know how many buttons there are in total below the clock and which symbols are written above each button and the order from left to right. I will then be able to provide the correct instructions for your oven.
Hope this helps.
Regards,
BElectric
Apr 18, 2011 | Ovens
Looking for a manual for Whirlpool BS0801/WH oven
I have a paper copy of the manual - if you need to know anything more than the information below post a more specific question.
The function symbols on Knob F, clockwise from the top, are as follows:
  • 0 = Off
  • Lamp symbol = Lamp Only, no fan, no heating.
  • Fan + Drip Symbol = Lamp + Fan, but no Heating - this is for defrosting.
  • Fan inside a Circle symbol = Lamp + Fan + Oven Heating - this is the normal cooking position. The temperature of the oven is set on the Temperature Knob.
  • Final position = Grill. The temperature of the Grill is set on the Grill knob.
The red indicator light only comes on when the Oven is heating (not the Grill), and goes off when the oven has reached it's set temperature.
The bulb is 25W 230V Type E-14 300 Degree C.
The oven draws a maximum of 2300W so requires a 10A supply.
Nov 29, 2010 | Ovens
Ovens Logo
1,100 people viewed this question
Top Bosch Ovens Experts
ashburton
paulcarew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
