My washing machine gets stuck after rinse cycle
When the machine is finished with the rinse cycle sometimes it will get stuck. All the water will be gone from the tub but it continues to run and drain out of the machine into the drain, which if left unattended can be a huge waste of water. But if you advance the timer just slightly it will go into the spin cycle as it should. Could the timer be bad? Please help. I have a problem like that my machine gets stuck and continues to ad water and drain half way derekflaro@hotmail.com
  • 15,935 Answers
It appears your timer/controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
For some reason my GE GBVH6260 washer cycles are getting hung up on either the wash or rinse cycle. Some days it will stay stuck in the wash cycle & some days it will stay stuck in the rinse cycle for...
Most likely its your water inlet valve..(cold side is not letting water in). Very common problem that usually manifests during rinse cycle since rinse uses always cold water.
According to your model # , part # is WH13X10023
Jul 10, 2017 | Washing Machines
My washing machine will not drain. It finished all the cycles but didn't drain after the rinse cycle. It still spun afterwards with water still in it.
Aug 10, 2009 | Whirlpool Washing Machines
Washer will not discharge water after wash or rinse cycle
Pump failure. Unit probably has something stuck in pump....the washer eats the socks not the dryer. suggest shope vac to get water out, and then remove hose from pump and check to see if its clear.
Jun 08, 2009 | Kenmore Washing Machines
Wash machine sometimes gets stuck on rinse cycle & dryer not dry
Sounds like the drain hose for the washer is too far down in the stand pipe at the wall causing a siphon effect, try raising drain hose a little. The dryer sounds like the vent line from back of dryer too wall is pinched causing an air flow obstruction. Hope this helps.
Mar 19, 2009 | Whirlpool Washing Machines
Whirlpool Ultima Wash II Intermittent Rinse/Spin
Hi, the water not drain , the drain pump was stuck , causes are the small linen and other foriegn materials are bind the pump infeller , pump connot completely turn . so drain stuck need to clean , also the drain hose have sedimentation of soap and dust.
Feb 03, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Stuck in rinse cycle
Mimmi, If the water isn't reaching temp this will happen. It sounds like a heating issue.
Guest,
The spray arm being blocked will not cause this. Again your machine isn't heating the water to temp.
Oct 27, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Front Loading Washing Machine - stuck in cycle.
there may be a simple solution. on rinse the water level is higher. it is just possible that the water is syphoning out. try putting the drain hose higher in a swan neck
Apr 05, 2007 | Frigidaire GLTF530DS Front Load Washer
Before spending any money calling a repairman or changing parts, check the drain hose. If it is too deep down into the drain pipe then pull it back so that only about 6 to 10 inches is down the pipe. If it is too far down then it creates a vacuum which drains the water as it is trying to fill for the final rinse.
Mar 30, 2007 | Frigidaire GLWS1339CS Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
