Do universal board want to modify when connecting with any screen?
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
Yes. It will have its own setup procedure and attached documents to guide you, how to do it.
Posted on Nov 03, 2012
My lg 42LF gets only half picture. What can I do to fix it?
The T-con board isn't working right. It could be one of the flat ribbon cables isn't making a good connection either on the board or the bottom of the screen. If both ribbon cables look OK, then the board needs replacing. You can get the part from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 15, 2016 | LG Televison & Video
Won't turn on
Hi! My name is Chris. I have this Phillips Wide Screen TV that didn't have or come with a remote, so I had to go out and buy a universal remote for it today from a BIG W Store. I'm having some technical difficulties & problems with switching and turning it on, but as I use the universal remote to turn on the TV, I'm having a bit of a slight problem with it turning it on, Ok, Yes, it works and Powers on, but there is nothing showing or giving me the indication that there is no picture or sound showing up on this Wide Screen Phillips TV, But there is a little red & green light at the bottome right hand corner that keeps on flashing red when ever I use the universal remote to switch the power on. Is there a possibility, that i can get some help on here, to help me out with any suggestions, is to why I'm not getting any picture or sound showing up on this TV with this universal remote ?
Is there anyway that i can maybe get some help with this to help me out with solving my issue with the Phillips Wide Screen TV ?
Dec 22, 2013 | Philips Televison & Video
Modifying Power Supply for 220 to 110
If you cannot get a ECU board from HP to replace the 220 volt model.
Then
The easiest solution, use a stepdown transformer fro 22m to 110 volts. Make sure the stepdown ransformer has a power rating that can supply enought watts to run the printer.
Mar 25, 2012 | HP LaserJet 1300 Printer
I Have an LG RU42px11 that displays dark fuzzy screen. I replaced both the Y sustain and Z sustain boards, but stiil the picture is fuzzy;moreover, the new z sustain board just blew from a C3 with red cap...
Send all 3 boards to coppell tv repair (http://www.coppelltvrepair.com) and pray.
After having invested time and money your real question is "do I continue with this or do I cut my losses and leave".
We can test all the boards and we can usually repair them too.
Knowing the price you'll have an easy choice as to whether you want to go ahead or bust it.
For a TV this old I can't honestly advise against busting.
But I can honestly say that if you're to bust it then at least we can have the bad boards and maybe help someone else in your position who's not going to bust it.
I can't comment much on what you;ve done because without seeing it I'll have to make lots of assumptions.
Dark/choppy screen can be caused by both YSUS and ZSUS by the way. Most often it's by the ZSUS.
Sep 24, 2011 | LG RU-42PX11 42 in. EDTV-Ready Plasma...
U tries to modifies the Z buffer board and it didn't work.The Z buffer board it is the causes and the problems.Replace the Z buffer board will solved this problems.
Imac screen moves around with cursor
Is your screen image also magnified?
It sounds like you accidentally zoomed the screen, which you can do by holding down the control key at the same time you are rolling the wheel on the mouse. When you do that, the screen will follow your mouse so that you can access portions of the screen that have "zoomed off."
Hold down the control key and roll the mouse wheel until you have zoomed all the way back in. Alternatively, visit System Preferences / Universal Access and modify the Zoom options to suit yourself.
Mar 02, 2010 | Apple iMac G4 Desktop
How do you print data from the calc? I connected it to the computer, but nothing happened
If you want to print your data, you can use the TI Connect software to grab the screen (screen capture).
If you want to modify the data on your computer and transfer the modified data to the calculator, you should download two additional applications: CellSheet and CellSheet converter for Windows or Ma cOs. Here is the link.
Feb 18, 2010 | Texas Instruments TI-84 Plus Silver...
Mother board connections
USB and sound connectors are universal. In case of very similar mb's (like yours) all the others will also work, just make sure you connect them correctly - the positions if the connectors on the mb might be slightly modified.
Apr 29, 2009 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Error 677
An error code E677 with a subcode of 0004 however, may be caused by either an overheating CPU or low voltage being supplied to the printer board. Follow the procedure indicated in Technical Publication CIB-T052 for those printer boards which continue to exhibit error codes of E677 with a subcode of 0004.
Note: Since error codes E677 were reported frequently with different subcodes, Canon decided that all boards be screened. After the screening a colored dot was placed on the board near the AUI port. As of now, a Yellow dot means that it has passed screening and should work. Eventually the board will be modified and the dot will be Red showing the board has modification and has passed screening.the problem is a connection problem between the printer board and the machine..
the first thing i would do is check and reconnected the printer boards and the connection box they plug into..witch is at the rear of the machine .. would not do software until i found out what the problem is...i have found one machine that the connection box did not have a outside cover so it would not hold the boards tight...
Mar 25, 2009 | Computers & Internet
Yamaha RX100bike in 4 gear modified it 5 gear
i have universal remote control philips , i need a program code for mini hifi philips
Feb 14, 2009 | Yamaha Digital Sound Projector YSP-800S -...
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
