Question about Microsoft LifeCam VX-1000 Webcam
Camera will not uninstall so that i can re-install
The camera will not work after I restored my computer and I can not find out how to uninstall the camera so that I can re-install. when I try to re-install it goes most of the way and then says install error can not install.
    President:
  • 8,637 Answers
Do you still want to use it? If so,
Normal 0
Try disconnecting the Camera from the USB port and reinstall the software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Posted on Jan 26, 2009
Why do not may toshiba webcam work proprly
How can fix my webcam TOSHIBA FORUMS
How can I fix my webcam? Question When I try to use my webcam, it doesn't work properly. How can I fix it?
Answer Skip this and contact a professional
If you'd like to skip this guide and contact a professional, CLICK HERE.
When you attempt to use your camera, you might see an error such as "Connect a camera" or "Web camera initialization failed," or the camera might simply not work correctly.
There are a few easy steps to troubleshooting and fixing a malfunctioning webcam. Each step below might fix the problem. After each step, test the webcam. If it works, stop troubleshooting. If you don't want to go through each troubleshooting step, you can skip to the "System Recovery" section.
Check Device Manager
Open Device Manager. (In Windows 8, hold the Windows key and press the 'x' key to open a menu in the lower-left. Select "Device Manager" from this menu. In Windows 7, search for it in the Start Menu's search field.) There should be an entry titled "Imaging devices" that can be expanded. The webcam should be listed under Imaging devices. If it's listed, continue to the next troubleshooting section. If it isn't there, try slowly closing the laptop while continuing to watch the Device Manager. If it suddenly appears, it indicates a hardware failure and a repair would be needed. If it never appears, continue to the next section.
Reinstall Software
Right-click the camera in the Device Manager and select "Uninstall," then restart your computer. The computer should reinstall its camera driver.
If that doesn't work, check the Toshiba support site for an updated camera driver. For instructions on how to find your downloads from Toshiba, please see the following Knowledge Base article.
Finding downloads and support documents at support.toshiba.com
Look under the "Camera" category, and download the appropriate one for your version of Windows. Some laptops may not have one listed. This is fine, as many models don't use a specific camera driver, allowing Windows to provide the driver.
Check the UEFI or BIOS Settings
Some computers have the option of disabling the webcam in the UEFI or BIOS settings. Ensure that's it's enabled by performing the following steps. Note that some computers might not have this setting.
  1. Turn your computer off. If your computer uses Windows 8, hold SHIFT while seleting "Shut down" to perform a complete shut down.
  2. Start the computer.
  3. Begin tapping F2 when the TOSHIBA splash screen appears to enter the UEFI or BIOS settings. On some models, you might need to hold F2 while booting. If you have trouble entering the UEFI settings, please see the article titled How To: Enter the system BIOS or UEFI in Windows 8
  4. Select Advanced
  5. Select System Configuration
  6. Select Web Camera.
  7. Ensure it's set to Enabled.
  8. Save and exit.
System Restore
Try using the System Restore utility to restore the computer to a working state. Select the most recent restore point from before the issue arose.
How To: Understanding System Restore, Refresh, Reset, and, Recovery options in Windows 8 + Video
How To: Perform a system restore in Windows 7
Uninstall Other Webcam Applications
Uninstall any other applications that use the webcam besides the pre-installed Toshiba camera application. For example, uninstall Skype if it's installed. This is just a temporary troubleshooting procedure. If uninstalling the other applications doesn't fix the problem, reinstall them. If it does fix the problem, try reinstalling them again to check if the webcam continues to work. If it stops working again, the issue is that specific third-party application.
Contact a professional or perform a system reset
Lastly, you might want to return your computer to factory default conditions. This is sometimes called a system reset or a system recovery. Note that this will remove all of your software and data that you added including applications, documents, photos, etc.
How that helps good luck.
Feb 24, 2015 | Toshiba Satellite C655-S5212 Laptop
Sony Vaio VPCCB45FN exmor Hd web camera not working.....the green light besides the camera does not glow...neither does any webcam software detect the camera. The device manager shows a yellow exclamation...
Open device manager and uninstall that camera driver. After uninstalling click on CHECK FOR HARDWARE CHANGES, it will automatically detect and install the driver, if still doesn't work, take it to the service center.
Sep 08, 2013 | Microsoft MTP Device
When i power on my d860 camera then display connect the computer , printer so plz solve the prblem
It seems your camera is not installed, or the installation is corrupted.
Please, try reinstalling your camera:
1.Start>Control Panel>Uninstall a program>find your camera, click on it and hit Uninstall, confirm if prompted.
2. Restart your computer.
3. Insert your installation disc-the one you got with the camera, plug in the camera (connect with the computer, and start installation.
4. When installation finished, unplug the camera (disconnect from the computer) and restart your computer.
Should work now.
Regards!
Jun 20, 2011 | Computers & Internet
My toshiba web camera doesn't seem to work.how do I restore its function?
If you're running under windows, try reinstalling the drivers.
Go to control panel, Add or Remove programs, find anything related to the toshiba webcam and uninstall it.
Then go to device manager (press ctrl shift and esc at the same time and start a new process named devmgmt.msc) and find the camera; uninstall it from there if it shows up.
Restart your computer. Get drivers from the toshiba website or install the drivers that might have come on a CD, follow their instructions.
If that doesn't work, it might be broken, or if you installed a new operating system, it might not be compatible.
Mar 04, 2011 | Toshiba Satellite L510 Laptop AC Power...
I cannot connect my camcorder to the PC thru a IEEE 1394 cable
1. Possible issue with the driver. You need to uninstall and reinstall the driver/sony software to your computer. Complete uninstall required then restart your computer, install the driver, restart computer then connect your camera.
2. If #1 didn't work, it is a possible issue with the Operating system update, usually messes up the internet connection and other 3rd party software. All your need to do is to perform system restore back to the date when your were able to your camera and computer normally.
** Here's how to do the system restore for Win vista and win 7:
Click on the start menu, go to all programs, go to accessories, go to system tools and look for system restore. Click on system restore then follow the prompt then choose the restore point for your computer.
**For Win XP
Click on the start menu, go to all programs, go to accessories, go to system tools and look for system restore. Click on system restore, choose Restore my computer to earlier time, there will be a calendar where you can choose the restore point for your computer.
Apr 12, 2010 | Sony DCR-HC19E Mini DV Digital Camcorder
Accidently unistalled my orbicam.how do i get it back?
go to the manufacturer's website of your webcam and download the camera software... - if not there, and you are using windows, simply do a system restore... it will restore your computer to an earlier state - normally the last restore point is when software is installed/uninstalled...
Feb 17, 2010 | Acer Aspire 5100 Notebook
My camera dont want to workanymore i dont know what happen it just says that application has failed to start because its side-by-side cnfiguration is incoorect., waht does it mean? do i neet to unistall it...
You may need to reinstall your webcam driver to your computer to try to fix it.
Windows XP
1. Click start
2. Click run
3. Type devmgmt.msc press enter
4. Look for imaging devices
5. Right click it and click on uninstall
6. Restart the computer
7. It will automatically reinstall the driver
Windows Vista
1. Click pearl button
2. Click start search box
3. Type devmgmt.msc and press enter
If you have the installation driver, you can try to use that as well.
If that didn't work you may want to restore your computer before that problem occur. Windows Operating system has the capability to restore.
Windows XP
1. Click Start
2. Click All Programs
3. Click Accessories
4. Click System Tools
5. Click System Restore
6. Choose a clickable date where you can restore your computer before the issue began.
Windows Vista
http://www.howtogeek.com/howto/windows-vista/using-windows-vista-system-restore/
Jan 14, 2010 | Acer Aspire 5610-4648 Notebook
Hi I have a Toshiba PA3554U-1CAM that was working on my home computer. I has to upload a new version of Windows Messenger and initially the cam was working but no sound. After reloading the Toshiba disks I...
could be a couple of things gone wrong,first go into your device manager and look and see if the drivers are there for the camera if not you will have to put the drivers back in.did you get a disc with your camera? if you did then install drivers from that.or go to control panel and look for install new soft wear and see if the camera is there.or go to were you uninstall programmes and see if the camera is there if it is uninstall it then reinstall using the disc if it come with one.
if you want you can restore your computer setting to when it all last worked.
Oct 08, 2017 | Toshiba PA3554U-1CAM Webcam
AVG will no install error 0x800736b1 also retrirve my desktop
Hi there. My name is Alex and Im here to help solve your problem
First of all, AVG has always had a problem installing when windows updates are enabled and download and install automatically. I would recommend uninstalling all updates that have been installed to your computer and disable automatic updates which I will explain to you below
To uninstall the updates.
Click start, settings and click control panel.
On the icon add and remove programs, please double click
You will now see all the programs and updates installed on your computer. The microsoft updates are located near to the bottom of the list and there may be a lot of them installed. You can only uninstall one update at a time. You may be prompted that uninstalling a windows update may cause a program not to work properly, this is normal so you can continue uninstalling them. When you have uninstalled these updates please restart your computer.
To disable the automatic updates
Right click on your icon My computer or My pc which is located on the desktop or on the start menu (if you are running windows xp) and select properties
You will then see a sub menu called 'Automatic updates' and inside this menu you will have the choice to disable the updates
If you are using windows xp and you have system restore enabled on your computer, then you will be able to take the computer back to an earlier time when it was working correctly. Please save all documents first to insure that nothing will be lost if you decide to do a 'system restore'. There is a very friendly wizard to help you restore your computer. You can get to the system restore by clicking start, programs, accesories, system tools and selecting system restore.
Regarding your problem about your desktop disappearing, to restore your icons on the desktop, right click anywhere on the desktop and select organise icons and be sure that the heading 'show desktop icons' is ticked. This will restore your desktop items
Last of all try installing AVG, if you still experience problems with this issue, then please let me know. Im happy to help
Oct 10, 2008 | Computers & Internet
Can't upload pics; computer not "seeing" camera
The key to getting back to "It used to work fine;" is to make Windows "GO BACK IN TIME" to that moment when it last "It used to work fine;" occurred. How to do that. Try to pinpoint the exact date that it started acting badly. Now do this: START-ALL PROGRAMS-ACCESSORIES-SYSTEM TOOLS-SYSTEM RESTORE. I'm hoping you actually have RESTORE utility turned on...Now select the restore date BEFORE it quit working. DONE! Windows will run as it used to run when all worked well. I use RESTORE all the time and I have 100% success rate!
Jun 23, 2007 | Nikon COOLPIX L3 Digital Camera
Microsoft LifeCam VX-1000 Webcam Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
