Error E013-002 irc6800
Cleared error but still same
Canon irc6800 error code E000061-0005
Have you checked corona assembly wheter the wire is not damaged/missplaced? From my memory this error means either that or problem with voltage on drum in general. (corona and/or laser shutter issue)
Apr 12, 2016 | Canon Office Equipment & Supplies
How to fix canon irC6800 error code e00008-01
Fixing roller must be changed,After replacement U have to reset machine in service mode COPIER COUNTER DRBL1 FX-UP-RL.Than turn machine on and off
Nov 09, 2014 | Canon Toner, irc6800, 5058/68, ma
Fixing roller has exceeded a specific count.After you repled it reset in service mode:COPIER<COUNTER<DRBL1<FX-UP-RL,and turn machine OFF and ON
Problem with fixing assy. Fixing roller needs to be replaced. After replacement U have to execute,reset it in service mode COPIER COUNTER DRBL 1 FX -UP-RL .
What does error code E000014-0001 on Canon iRC6800 mean?
Welcome to FixYa
Dear USer
This might be fuser motor is not turning. Rotate the green fuser knob to see if it is hard to turn. If freely turning then a gear, motor, or DC Controller board is bad.
hope you got it...Thanks for Connecting FixYa
Aug 20, 2010 | Office Equipment & Supplies
E000003-0010
fault not listed in manual but E003 is to do with the fixing temp check thermistors and heater lamps
May 10, 2009 | Canon imageRUNNER C6800 Copier
IRC6800 ERROR CODE E000020-03a8
This code indicates a failure of the fuser Unit (the device that melts the ink onto the page) to heat up. There are several things that can cause this to happen.
Blow fuser lamp
Defective thermister
AC Driver board
Apr 20, 2009 | Canon imageRUNNER C6800 Copier
22 people viewed this question
jasbo
jasbo
