Question about Refrigerators
Whirlpool 6th sense not making ice or dispenceing water
Fridge and freezer working, when pressing for water motor appears to be working, water to appliance is ok, water not going through appliance, so no water no ice
  • 2 more comments
  • danny Nov 03, 2012
    To Richard Roth whirlpool 6th
    To Richard Roth model no 20ri-d4a+pt whirlpool 6sence side by side
  • Richard Roth
    Richard Roth Nov 03, 2012
    I am not coming up with anything on that model number. Are you in the UK?
    yes, what about 20RIDA (858642015010)
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 03, 2012
erpaalai
  • 999 Answers
SOURCE: removal of old water filter
Righty Tighty- Lefty Loosey :)
Eric
Posted on Oct 12, 2009
  • 56 Answers
SOURCE: my whirpool 6th sense american fridge freezer has
Be very careful, when the ice maker malfunctions, many things can be the culprit. The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Posted on Jun 10, 2010
SOURCE: ice maker not working
Cause could be the solenoid valve which controls water flow into the ice maker.
Could be bad solenoid, bad relay for solenoid, clogged solenoid valve, corroded electrical connections, etc.
More info? Let me know...
Charlie
Posted on Aug 14, 2009
heatman101
  • 43501 Answers
SOURCE: whirlpool 6th sense side by side fridge/freezer
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 31, 2010
  • 5370 Answers
SOURCE: Whirlpool 20RBD3J American Fridge Freezer
At the back of the ice maker there is a water inlet solenoid valve.This valve gets command from the main board of the unit to open and close.The water fill tube is connected to the valve.When the main board gives command to water inlet valve the valve open and water fills,when the water is filled in the ice maker tray,the valve gets close.But in your case this valve is not getting close so its overfilling and this is making ice and ice dropping in the unit. ------------- Remove this water fill valve and replace it.This will help the water to run properly and stop properly.------Also other thing to check is ice maker shut off arm or shut of switch.Check this switch. Look for this arm if its up you shouldnt be making ice if its in the down position lift it up it should stop the ice making.------------- This should help.Thanks.Helpmech.
Posted on Jan 29, 2011
Whirlpool 6th sense fridge freezer electronic panel - how do i unlock? child lock not on
Emma:
The lock and unlock feature is accomplished by holding the lock button for 3 seconds, and you will see a count down number just above it that indicates 3, then 2, then 1, and a soft tone along with the lock icon appears. To reverse this hold the same button for 3 seconds following the same procedure and the unlock icon will appear.
Jul 14, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool 6th sense fridge freezer instructions
unplugging the unit for 10 minutes is the reset feature. other wise I refer you to the owners manual
Dec 22, 2017 | Whirlpool Refrigerators
Whirlpool 6th sense side by side fridge/freezer 25rid4 model,freezer working fine but fridge part does not cool
heatman101
Oct 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My whirpool 6th sense american fridge freezer has stoped making ice? The water is still live, th eonly problem appears to be the level control arm which is in the up position and want move?
Jun 09, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
There is a flashing #6 in a circle above the temperature indicator. What does this mean?
Mine did the same thing today and I just got off the phone with Whirlpool and they said it just means that the 6th Sense technology is activated. If you put a bunch of warm food in the refrigerator or leave the door open for a while, the 6th Sense technology kicks on to return the refrigerator to the set temperature. The flashing 6 should go away once it gets back to the right temperature.
Nov 21, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
My Whirpool Side by side refrigerator, the fridge isn't cool
whirlpool side by side refrigerator, quit working. not cooling or making ice compressor surging on and off.Does this mean it need freon? and can we do it our selfs.
Mar 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side
Hi, it sounds like you have a bad auger motor on your dispencer. If the button works for water, usually it will work for ice. It is also possible that you have a bad dispencer control board. If you would provide me your model # I could assist you further.
Dec 02, 2008 | Refrigerators
Icemaker and water dispenser not working GE GSS25JFPA stopped working and i thought it was water filters (have not changed in 4 years changed the internal filter and a aux one in basement in line no...
generic troubleshooting video: http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
as the video shows a kinked line may be the culprit. or
if your ice maker is making ice and it is your ice dispencer that is not working along with your water dispencer and when you press the dispencer button the light dims on the door. I would replace the main board. I experienced the same problem and the board fixed it This board is shared by many models and brands of fridges and the transformer goes bad from power surges this board powers the solenoid valves that open for your water
Apr 03, 2008 | Refrigerators
Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Refrigerators Logo
642 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
