Question about Coffee Makers & Espresso Machines
Need to no what the first red button - Coffee Makers & Espresso Machines
I need to know what button is set
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
    Code Search Method
    1. Manually turn on the device (TV, VCR, etc.) to be controlled.
    2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
    3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
    4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
    5. Press and release MUTE to install the code. The indicator light goes off.
    Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Mar 22, 2012 | One For All URC-3021 Remote Control
I need to set-up my one for all remote for a sanyo tv. i need the tv code
Hello
You just try one amoung the following four digit numbers
{ 0049 0097 0110 0004 0268 0012 0108 0180 }
Proceedings
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
Oct 23, 2010 | Sanyo Televison & Video
Need to down load the codes i need to use with a dolby dvd player
http://www.p4c.philips.com/files/s/sru3006_27/sru3006_27_dfu_aen.pdf
That is the link to the manual if you need it. All the codes and information is on page 7
2. Press and release the desired mode button (TV,
3. Enter the 4 digit code from the code tables (on
separate sheet). Note: after a valid code entry, the
indicator flashes.
Note: If some buttons do not operate your equipment,
controlled.
3. Press and quickly release the desired mode button
(TV, VCR, etc.). The red indicator blinks off once.
channel. The red indicator blinks off with each
button press. If you accidentally overshoot the
code required, press the CHANNEL DOWN button
to backtrack through the library until the device
changes channel. Pressing CHANNEL UP changes
direction to forward again.
May 21, 2010 | Philips SRU3006 Remote Control
TDS 3-button keyless remote operating instructions please
RED opens the drivers door, BLACK opens all the doors, and GREEN turns on the head lights
Apr 30, 2010 | 1998 Toyota Camry
Wii controllers wont syncronise with console
to sync remotes you need to open a little door on the front of the console which has a red button underneath it then on the remotes in the battery compartment there should be a small red button and you need to press both those red buttons for a few seconds and they should sync up
Jan 21, 2010 | Nintendo Wii Console
Installation of record button
If it is just a red button then it's simple, it will lock up on its place when you'll push it in, DO NOT FORGET SMALL SPRING THAT GOES UNDER THE RED BUTTON.
Dec 01, 2009 | Sony Video Cameras
Wii fit balance board wont connect
Unplug the AC adapter from power cord then wait 10 min and plug it again.Open the SD Card slot cover on the front of the Wii console, just below the disc drive, and press and hold the red SYNC button for 15 seconds. This will clear all synced Wii Remotes from the console.Then push the red button again, then open the batteries cover on your
Wii Remote and push the red button there.After that push the red button on console one more time, then open the batteries cover on your Wii Fit and push red button there.If this not help may your wii fit need service.
Nov 02, 2009 | Nintendo Wii Fit for Wii
Wii fit board - blue power light flashes then goes off and wont work. This is also happening to my parents one and we are both on our 2nd wii fit board each. Have reset red button but no joy - help please
A red ring is around my xbox start up button
How may lights are showing up?
3 red light is GPU and the CPU overheating,
2 red lights is general overheating
1 red light is E74 and 4 red lights is the av cable.
For the 1, 2, 3, red lights you will need to get it fixed you can either send it in to do this or repair it yourself
Oct 26, 2009 | Microsoft Xbox 360 Console
Cant connect the second wii remote to the console i sync did not work
you need to try to put new batteries in the remote. and if that does not work, then you need to make sure you are pushing the red button on the wii remote under the battery cover and the button on the wii AT THE SAME EXACT TIME. it would be easier to have you push the remoted red button and have someone else push the red button on the wii. make sure it is at the same time or it will not work.
Aug 25, 2009 | Nintendo Wii Console
Coffee Makers & Espresso Machines Logo
18 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
