Question about Quiksilver Moondak Tide Watch
Quiksilver moondak digital manual
Resetting time, date
Could you help me with my roxy crushin krw222dr watch ? i cant set the time and date . please ?
Click on this link, to view the manual
http://media.quiksilver.com.au/media/rx/watch-manual/RX%20Crushin.pdf http://media.quiksilver.com.au/media/rx/watch-manual/RX%20Crushin.pdf
May 13, 2014 | Watches
Need a manual or instructions for mt watch please!!!
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to resume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
Have fun :)
May 04, 2017 | Watches
The manual of my quiksilver watch Chapter is not complete. what means AEL and KET?
KET means keytones
AEL means Light ON each time you push any key
Nov 14, 2012 | Watches
How do i reset date after battery change? or where can i cet a pdf file a9no calliber number on case or movement but its a timex perpetual with indigo light approx 30 yers old
to reset the date manually, pull the stem out to the second position to reset TIME; manually continue setting time until the date is on the correct day/date.
I had to do this to get back to the proper date when my timex was off by a week. Nothing else worked. 14 times around (twice per 24 hour day) and each time I passed "midnight" the date advanced.
blessings!
Mar 12, 2011 | Timex Watches
I would like to know how to reset my watch: quiksilver RANDOM M029 AL. Thank you
Try pressing all the buttons for at least 2 seconds. This might reset the watch like it does for other models.
Mar 01, 2011 | Watches
Where can i get a manual of my quicksilver traction watch?
I looked at the Quiksilver web site but could not find the model you have.
If you go to thier web site http://www.quiksilver.com/family/index.jsp?categoryId=2978686&sr=1&origkw=watches, you will see a list of watches and clicking on one of them will take you to a page that has "manuals" near the bottom.
Click on this and you will see a heading "analogue watches" but there are no instructions for digital types. If you watch is a digital watch, then I can only suggest that you contact them and ask them to send you a copy.
Feb 01, 2011 | Watches
I dont want it to beep every hour. How do I make it stop
Go to the Quiksilver web site "www.quiksilver.com"
Enter "watches" into the "search " box.
Scroll down the page and you will come to the selection of manuals that you can download. Select yours and the method of turning off your alarm should be described.
Jan 02, 2010 | Watches
Setting time/date on old Seiko
With our 10 year old grandson's help, my husband was able to figure it out. Took a while, but he is now wearing his watch again!
Thanks for the follow-up.
Feb 08, 2009 | Seiko Watches
To adjust time on a watch
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
May 31, 2008 | Casio Baby-G BG370S-4V Wrist Watch
Setting time on Seiko watch 7N43
Mike 1935 if your watch has hands only & no digital display the crown where you set the watch pulls out half a click to set the date and should pull out a little further to set the time try that.
bjbc I am assuming your seiko watch is a digital watch. Try holding in the top rt button if its the watch I think it is it should change to 12yr time.
Mar 09, 2008 | Watches
Quiksilver Moondak Tide Watch Logo
128 people viewed this question
Top Quiksilver Watches Experts
Jimmy Accardi
Are you a Quiksilver Watch Expert? Answer questions, earn points and help others
