Question about HP Pavilion dv6000z Notebook
Battery charging problem HP DB6000 series
I cannot keep batteris charging in my HP DB6000 series PC, this despite having had the mother board and AC power bricks replaced. The battery will stop charging when the computer shuts down for examle and will only start again when the battery is removed and reseated. This occurs with two battery packs, one old and one brand new. This means that I cannot depend on the unit charging the battery for me unless I am esentially in front of it.
This is a two-year-old unit and I must say that after som persistance I have gotten some help from HP in the form of a replacement mother board but the problem still persists.
  • Thomas F. Schneider May 11, 2010
    Have you considered replacing the charger?
  • 538 Answers
They either didn't replace MB or didn't replace charging IC on MB. Needs to be done either.
Posted on Mar 19, 2009
HP Mini 2140 "Plugged in, charging" but not charging
Hello jorel, most likely its a failure of the system board particularly the charging section, a broken pin or a loose terminal. work will be internal, suggest you do away with the battery. its better to operate it at home, or bring the charger with you. Maybe its time to get a new one.
Dec 05, 2013 | HP 417035-001 - HP Pavilion dv2000 Series...
I have no led light on my e1705 when i press it and nothing comes on
Things to check:
1. AC adapter cord, esp close to the brick. Does the green light come on the brick? If not, replace the adapter.
2. Reseat battery. Check the battery charge by depressing the battery indicator button on the battery. Does it have a good charge? If so, then it could be the connection to the mother board causing the issue. If not, then replace the battery.
3. If both the battery is good and the AC adapter is good then you are looking at a mother board issue.
May 21, 2010 | Dell Inspiron E1705 Notebook
System says it is charging, but the battery power is not increasing . I bought a new battery for my nc6400 laptop, and it was charhged up to 66% and then it stopped. Since then, the battery would not be...
take out the battery and just use the ac adapter
if the computer powers up and works
then i would try swapping out that battery
if the computer does not power up then you need to replace the mother board
Vote me 10 on this solution
Jan 06, 2010 | HP Compaq nc6400 Notebook
HP 530 Notebook will shut off by its self and when you restart it and will show you that windows was not shut down properly. Could it need a new battery?
The problem lies with the power supply system either in the power adopter or inside the laptop. When AC power is plugged in, the system shows that the battery is being charged (Yellow Light Indicator switches ON) but practically niether the battery is usually being charged nor the computer is being run by the AC power. Its a little bit of energy left in the battery that keeps running you computer for some time and as soon as the battery is discharged the note book shuts down by itself.
However, the Taskbar battery indicator gives the correct picture of battery charge and the charging process. Better rely on that.
Its a hardware problem pertaining to power supply and charging system and doesn't have to do any thing with Mother board, RAM, Hard disks or other hardware installed in the PC.
Do tell the above details to a repair workshop man to rectify the problem.... Best of Luch
Aug 18, 2009 | HP 530 Notebook
HP DV6915nr AC charger does not turn on or charge the battery.
You have a defective regulating circuit on the mother board that will not allow charging or a broken connector pin at power connection .
Aug 13, 2009 | Computers & Internet
I have a compaq presario 700 laptop that is no longer charging.
The notebook battery may have a defect if it will not power on the notebook and if it will not hold a charge. The battery indicator light on the notebook either does not light or always blinks orange. The notebook operates correctly when connected to the AC adapter.
A battery that will not charge may be the result of an AC adapter failure, a system board failure, or a battery failure. Perform the steps below to diagnose the failure.
Troubleshoot the power supply
To verify that the AC power supply is functioning properly, follow the steps below.
1.
Plug the AC adapter directly into a functioning wall outlet, and plug connector into the computer. Do not plug into a power strip, surge protector or secondary power source.
2.
Verify the following operation and take the appropriate action:
That all power cord connections are secure.
If the AC adapter connection to the notebook is loose, the connector may be damaged and require repair. Contact HP service and support for further assistance.
That the power button or power LED is lit when the computer is on.
That an LED on the AC power supply adapter is lit when plugged into an AC wall outlet (not available on all AC power supply adapters).
That the AC power supply adapter is the correct type.
Different notebook models require different AC power supply adapters. You will need to know the Product Number of your notebook to determine the Part Number of the replacement part. Click Start > HP Help & Support to view the product name, product number, and serial number that you'll need to have to speak with HP Customer Service.
View the See Also section for information about locating HP Help & Support in your operating system.
Troubleshoot the System Board
If you've verified that the AC power functions properly, troubleshoot the PC's system board by following the steps below.
1.
Remove the battery, and keep the notebook connected to AC power.
2.
Press and release the Power button to start the computer.
If the notebook PC powers on , then the AC adapter and system board are functioning properly. Go to Troubleshoot the battery .
If the Power LED is off , then the AC power adapter needs to be replaced. Contact HP Service and Support for further assistance.
If the power LED is on , but the notebook PC does not power on, then the notebook PC needs to be repaired. Contact HP Service and Support for further assistance.
3.
Shut down Windows by selecting Shut Down from the Start Menu.
If you have verified the AC power supply and system board are functioning correctly, troubleshoot the battery by following the steps below.
1.
Insert the battery into the battery compartment on the bottom of the notebook PC.
2.
Connect the AC power supply and allow the battery to charge for 15 to 30 minutes.
NOTE: The Battery Charging light should be on while the battery is charging. If it is not on, check the AC power adapter connection to the notebook PC.
3.
Unplug the AC power adapter cord from the notebook PC.
4.
Press and release the Power button to start the computer using only the battery as the power source.
If the PC does not power on, then the battery needs to be replaced. Contact HP service and support for further assistance.
If the notebook PC does power on, the battery is functioning properly.
NOTE: If you have purchased a second battery for your notebook PC or you have access to an identical battery, you can also check the battery by inserting the second battery into the PC and performing the Troubleshoot the battery steps again.
Apr 14, 2009 | Compaq Presario 700 470024-192 Notebook
Laptop does not work with AC adaptor, does not charge. Mother board issue
You may be able to get a battery charger but its rare.
If you do wish to use the AC adapter, take care with positive and negative. Also the voltage of the battery is actually lower than the AC adapter in order to get charged. I don't know what is going to happen if you do choose to use AC adapter as battery. 75% chance that it will work.
Oct 08, 2008 | Dell Inspiron E1705 Notebook
Battery is not charging
Charger board seems to have gone bad.
Aug 05, 2008 | HP NC4010 Notebook
HP Pavilion dv6000z Notebook Logo
288 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
