Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Fisher and paykel agitator flap broken can this be replaced?
5 Suggested Answers
RescueTech
  • 145 Answers
SOURCE: Fisher and Paykel ecosmartWashing Machine Agitator flap broke off
Hi Bill...
It takes all of 5 minutes (if that) to change the agitator. You pop off the fabric softener dispenser on the top of the agitator, then reach down inside and undo the plastic wingnut that secures the agitator down and then simply lift if off.
As for issues with using it with broken fins, you could end up with some clothes damage, especially to delicate items, if you continue to use it that way.
You can get the part here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=229
Posted on Feb 14, 2009
  • 93 Answers
SOURCE: no power to fisher paykel washer. Replaced pump
PUMP IS ALSO A HEAT SINK FOR THE MOTOR CONTOLLER.
YOU MAY NEED A NEW BOARD
Posted on Jul 10, 2009
  • 250 Answers
SOURCE: Fisher Paykel Intuitive Eco Washer is squealing
You need to pull out the washer, TURN OFF THE WATER, then take the water hoses off the back of the washer. Check the screens inside the water inlets for debris. If that doesn't fix the problem you may need to ask fisher paykel if it's safe to put a chemical like limeaway in those holes to remove hard water deposits that have built up inside the valves.
Posted on Sep 20, 2009
richroth
  • 9472 Answers
SOURCE: The 3 agitator feet have broken off over the last
Here is a link to the part you requested.
Posted on Jan 02, 2011
Something is stuck underneath the agitator in m Fisher & Paykal Aquasmart. How do I remove the agitator?
Hi - with aquasmarts there is a plastic dome like fitting in the middle of the agitator & unscrew this to remove the unit.
Jul 08, 2011 | Fisher and Paykel WL37T26D Top Load Washer
How do u replace the agitator on a fisher & paykel clothes washer gwl15 ?
Disconnect power then lift the lid open. Pry the dispenser assembly off the agitator top then remove the agitator bolt by turning it counterclockwise. Once the bolt is off, lift the agitator then install the new agitator in place. Secure it with the agitator bolt then put the dispenser assembly back into position. Lifting the basket helps budge the agitator and remove it more easily.
Mar 02, 2011 | Fisher Paykel EcoSmart GWL15
AGATOR HAS BROKEN FINS
Take the cone out of the top of the agitator and you will see a large plastic wing nut down inside the agitator tube. Undo wing nut and agitator should lift of the splined shaft.. It may be a little tight.. Gently wriggle top to loosen. Make sure you get the same size to replace it, as there are different sizes....Good luck....Nomess
May 15, 2010 | Fisher and Paykel GWL11 Top Load Washer
THE WINGS ON THE AGITATOR ON MY FISHER PAYKEL ECOSMART TOP LOAD WASHER ARE BREAKING OFF. CAN I REPLACE THIS EASILY?
yes loosen the wing nut nd remove nd replace , u can order part from F&P direct 1800650590 ask for spares
Jan 28, 2010 | Fisher Paykel EcoSmart GWL15
REPLACING THE AGITATOR
unscrew the plastic nut down the centre and then pull the agitator up and off
Jun 28, 2009 | Fisher and Paykel IWL12 Top Load Washer
Hi Bill...
Feb 12, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Bearings
I can talk you througt this in live chat, but you'd need to get a F&P Bearing replacement toolkit and seals and bearings and a new agitator shaft. cheers
Jan 01, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
21 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
