I have recently bought a Pioneer DJM 350 & am
  • Computers & ... Master
  • 27,725 Answers
Im not sure i fully understand the problem when you say its not recognising it then you say it has no data on it ?
A few important bits of information about using faults and fixes on usb drives
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see
click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box
(I have found better results ticking the first box then reurn and tick the second box) you should not do anything while the chkdsk utility is in progress any input may damage this drive
also you might need to do this
click start click to open on my computer you should see your usb drive F: right click select properties there will be an array of options select the sharing tab option then advanced sharing
permissions make sure you have a tick in the share this folder box then click permissions make sure all three boxes are ticked you full control change and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
If you are running a Windows XP OS then you might be able to:
click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F: / E: or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
if you need more help with this post a reply
hope this helps
Posted on Nov 03, 2012
  • Antony Nov 04, 2012
    Thank you Brian for the response. I found that the memory stick wasn't responding at all to the mixer but had no faults shown on the computer. I found a spare memory stick which seems to work perfectly. The memory stick that does not work with the mixer is a Dane-Elec 8GB. Maybe just a cheapie unit that for some reason isn't noticed by the mixer! Thanks again for the fast response and the information.
  • Brian Sullivan
    Brian Sullivan Nov 04, 2012
    Thanks for replying and can you see it or get the dane elec in computer management
SOURCE: Skymedi USB drive is not recognised on my computer
i have usb kingston 4 GB data mini traveler, and my problem usb detect skymidi usb drive i dont know skymedi. i don't want if have format,because there are many data which is of important.
how is it's solution.
thanks 4 all
by blurz
Posted on Mar 08, 2009
  • 81 Answers
SOURCE: Is Zane-Elec 4GB USB portable memory (memory
If it was engineered specifically for USB 2.0, it may not work at all, then again, it may work, just more slowly. Plug 'er in and see, shouldn't be able to hurt anything.
Posted on Sep 01, 2009
  • 74 Answers
SOURCE: I have a new 500GB Iomega external harddrive. It
1. The TV and drive may not be compatible with each other. 2. The formatting of the drive could be the problem. The USB memory stick would be formatted as FAT32, but the Iomega drive would have been formatted as NTFS. Maybe the TV can only read drives formatted as FAT32 and not NTFS.
Posted on Dec 24, 2010
aviral_srms
  • 1216 Answers
SOURCE: datatraveller 4gb, not being recognised
no this cannot be done.
if your data is so much important only a data recovery company will help you.
you can't do this at your level
Posted on May 19, 2011
  • 3799 Answers
SOURCE: My windows 7 (x64) will not Acknowledge My AcomData HD250FAPE5-72 External Hard Drive, What do I do.
Having looked at the review of this device, it doesn't sound good. There is a problem with these but if it shows up in explorer you can use it. The other problem is that it is not windows 7 recommended. Have you tried to use it with the firewire connection? You may have better luck, but Windows 7 has to have "Signed Drivers" for all hardware (they have to be vetted by Microsoft) Good luck.
Posted on Mar 20, 2012
Testimonial: "Well, You didn't exactly fix the problem, but you did confirm what i had suspected, I just needed to hear from somebody else. Especially someone who knows more about computers than i do. Thank you for your help. By the way Mr. Michael Green, so that i can figure out what to do with this external hard drive. What Type, Model & Make of computer to the best of your knowledge was my external hard drive Intended for? Sincerely Yours, Aaron J. Baker. "
Pioneer djm350
What are you asking the fuse value does have a voltage rating and the current is based on the load.
Feb 26, 2014 | Pioneer DJ DJM-350 2-Ch DJ Performance...
User manual Technics DZ-1200 turntables & Pioneer DJXM600 mixer
I found your manuals below:
Technics:
http://www.givemefile.net/manuals/musical_instruments/technics/sl-dz1200.html
Pioneer:
http://www.nodevice.com/user_manual/pioneer/dj_mixer/djm-600.html
Sep 22, 2009 | Technics SL-1210 Turntable
How to connect my qqualizer to my djm pioneer 400 mixer
Use the stereo master outs from the DJM into the A and B Inputs of the EQ (you'll need 2 phono to Jack or 2 phono to XLR cables) then from the A and B Outputs of the EQ to the power amp/ speakers, etc (you'll need jack or XLR cables depending on what is powereing your speakers)
May 27, 2009 | Pioneer DJm 400 Professional DJ Mixer
DJM 500 & 2 1200mkIIs -- Very Low Sound With Multiple Speaker Sys
are you sure you have your tt's plugged into the phono line with the master booth knob turned up? Check the mixer too cuz the techs should be square.
Jan 15, 2009 | Pioneer DJm500 Professional DJ Mixer...
Pioneer DJM-400 mixer turns on, but channels aren't working
could be a few things , what have you tried to trouble shoot the problem ?
My steps would be ;
check all leads (even if you KNOW u pluged them in)
check the gain is set corectly .
check the line phono slectors are set to what ever you have you leads pluged into on the back of the mixer ( there is 4 red and white RCA plugs , 2 for phono,2 for line CDJs shold be using line )
if you are using digital cables to conect your CDJs , on the back on the mixer there is a small switch marked "CD or digital" make sure that is sleceted "digital " . if ur not using digital cables make sure it is on "CD" .
the info iv put here is based on the DJM-800 so your mixer my not have some of these featers as iv never used a 400 . hope this helps dued . check out www.djtutor.com for more tricks and tips . Pratices'N'enjoy !
Dec 28, 2008 | Pioneer DJm 400 Professional DJ Mixer
Ga-k8ns memory problems
did you go into bios and check set up of ram speed etc
Jul 14, 2008 | Gigabyte GA-K8NS Motherboard
Problem with USB Flash
It is possible the memory stick is faulty. Are you using xp or vista? If so it should be recognised instantly. I bought one the same a couple of weeks ago, and it recognised it instantly, and I'm using xp.
Try it on another computer if possible, even where you purchased it. Just tell them you think it's faulty. If it works on that computer then you have a problem with either your usb ports or you have a virus.
Jan 01, 2008 | Electronics - Others
Computers & Internet Logo
104 people viewed this question
David Payne
David Payne
