Question about Microwave Ovens
My Microwave/Convection National NN-C2000P Does not work
The convection works but the microwave doesn't work
MicrowaveSvc
  • 9047 Answers
SOURCE: microwave light door turn table works but does not heat up food
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 02, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: JVM convection microwave
I see. Okay, well then I would expect there's a problem with a high voltage part, such as the diode, magnetron or transformer.
Your model number should be entered as JVM192002 and you can find exploded views here.
You can usually find GE parts for much less here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Posted on Aug 10, 2008
  • 25 Answers
SOURCE: Daewoo WM1010CC convection/ microwave combo unit issues
Likely takes a torx wrench or some other special star tool to open it.
Could be a bad relay a bad mag tube or a bad timmer or a bad door switch. Needs to be trouble shooted. You have to get it open and check the fuses and test the voltage on the pri transformer first.
Posted on Jan 14, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: NNC2000P - Microwave does not work but convection works
An IGBT is an insulated gate bipolar transistor - sort of a hybird between a bipolar transistor and a MOSFET.
These are the final output driver transistors in the high-voltage inverter.
If it stops after 7 seconds, it still has a problem with the inverter.
It's likely a bad transistor, an electrolytic capacitor with an internal short or bad ESR or altered value, bad connection on the inverter board, a shorted diode or blown resistor, or a bad connection in the wiring.
Reputable service centers will have a repair warranty, but it may only be 30-90 days.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You should use a Panasonic-authorized service center so they'll have the service manual and (hopefully) experience and training to repair inverters.
In the US, you can find an authorized Panasonic servicer here.
This sounds like a non-US model. If so, visit panasonic.net, find your home country, then find the service / support links.
Posted on Feb 15, 2009
najah
  • 180 Answers
SOURCE: sharp R-1871 microwave/convection oven. Microwave will not work
This may be due to the microwave section not working. Check the high voltage diode if it is ok, replace the Magneton.
Posted on May 30, 2009
What is the output power of National NN-C2000P microwave oven?
the pwr rating is normally on the label.
google for a manual
Feb 02, 2016 | Microwave Ovens
Panasonic convection oven nn-cd989s, complete power off during prebake cycle of 450 deg which was directed to remove light oil coating from manufacturing process . Now unit has no power on face panel
Check the 20 amp fuse where the power cord ends inside the oven. If it is open check the latch switches. If the switches check ok the invertor is probably bad, smoking.
Dec 20, 2014 | Panasonic Genius Prestige NN-CD989S -...
Need user manual for National model no: NN-8655 Microwave oven user manual...
I would suggest that contact the dealer from whom you purchased the oven or call any number listed on the model tag of the oven.
Jan 06, 2014 | Panasonic Microwave Ovens
Dimension 4
I have this NN-C780P Microwave/Convection Oven. The microwave mode is not working and baking was ok until recently, the turntable cannot rotate when the temperature, timing and baking are ok.
When I bake, there are knocking sound.
Please advise.
Sep 10, 2013 | Panasonic NN-T888S Convection/Microwave...
I have a panasonic microwave with convection oven, grill and steamer. When I switch on the microwave, the house fuse (16 amp) cuts out. With the other functions of the oven, it works fine. Do I need a new...
you have a short circuit.
test the a) HV rectifier b) Capacitor HV c) HV transformer d) Magnetron e) test the swich for door for short.f) circuit board main is short.
see the diagrams and proceed.
10_2_2012_12_41_44_pm.jpg10_2_2012_12_42_15_pm.gif10_2_2012_12_42_35_pm.gif10_2_2012_12_43_09_pm.jpg
Oct 01, 2012 | Panasonic NN-C994S Convection/Microwave...
Time and weight setting doesn't works
There will be a reset switch button on your microwave's timer or somewhere on the appliance. Try the button and if it doesnt work then call customer care. It seems like a minor problem and can be fixed quickly..
Jul 29, 2012 | Panasonic NN-C994S Convection/Microwave...
Convection works but wont microwave heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ee
Jun 06, 2010 | Panasonic NN-T888S Convection/Microwave...
Feb 13, 2009 | Panasonic NN-C994S Convection/Microwave...
The main 10A 250V Fuse keeps on blowing up everytime I use my Microwave function. This does not happen when I use the Convection Oven.
Possibly magnatron to earth fault.Needs testing profesionaly.(microwaves can kill even when unplugged.)Regards grandadfixer
Oct 15, 2008 | Microwave Ovens
Panasonic dimension 4 microwave/convection oven
Does this unit have a turntable? If so does it turn when on?
Sep 24, 2008 | Panasonic NN-C980 Convection/Microwave...
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
