Question about Canon Sure Shot Z180u 35mm Point and Shoot Camera
With the Canon Sureshot Z180u the counter window is showing a blinking " H " and the focus is stuck open. The manual doesn't show this error. can you help?
No puedo instalar mi impresora canon pixma mp 130 por perdida del cd de instalaciòn, como me pueden ayudar gracias.
Posted on Apr 27, 2008
The alarm light is blinking. It says Error 5200? What is that?
Email me at :
Posted on Oct 01, 2008
  • 623 Answers
SOURCE: E18 error on Canon ixus40 - lens stuck
The E18 error is an error message on Canon digital cameras. The E18 error occurs when anything prevents the zoom lens from properly extending or retracting.[1] The error has become notorious in the Canon user community as it can completely disable the camera, requiring expensive repairs.
A quick internet search for "E18" + "canon" quickly reveals hundreds of similar complaints. reports that the "lens has a feature called bellows claw, which is a gear that physically extends and retracts the lens. A piece that holds the lens, the barrier plate, is not large enough and can sometimes cause the bellows claw to malfunction, resulting in a stuck lens". The result is a black screen that only contains the error message, E18. Another problem mentioned on the site blames a sticky iris in the lens, caused by grease entering inside from the microphones built into the lens. The buildup freezes up the ability of the lens to open.
Posted on Nov 13, 2008
  • 6 Answers
SOURCE: paper jam under print cartridges
Stick a 9x12 piece of cardboard down into the tray to force out unseen pieces of paper.
Posted on Jan 26, 2009
  • 365 Answers
SOURCE: Canon Smartbase MP360 showing error code ##336
It seems the home position sensor is out of whack or the mylar band behind the print cartridge carriage is missing or broken.
To find the mylar piece look for a clear 6mm x 460mm clear piece of plastic with black markings (like a gradient) on both sides.If you find it you can try and place it back by looking for an extended eyelet on both sides of the stell print carrier.
Most people in haste to change ink have the hand slip and it becomes dislodged.
Posted on Jun 17, 2009
How to fix Canon imageRUNNER 2318L showing error code **E000030-0000
I am not sure with this model for this error code. But the counter may checked for its continuity it might have open. There are two electro-mech. counters.
Feb 15, 2015 | Canon Office Equipment & Supplies
On the display of the printer the E225 system error is showing and an error is blinking show me the solution
this is error for scanner lamp, if the turn off and on doesn't help, you need to replace the cis unit. Call service....
Aug 29, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
Error 6000
This is the error code printer Canon IP1200, IP1300, etc. light blink Indicator:
3x orange 1x Green = mechanical error
if you dont have any knowlegde about printers, better bring your printer to Canon service center.
4x orange 1x green = printer absorber full
reset your printer using software ressetter or try using manual reset. different printers have different manual reset.
5x orange 1x green = black cartridge/color cartridge error
can be chip error or connector is dirty.
7x orange 1x green = black cartridge/color cartridge error
8x orange 1x green = printer absorber full
12x - 17x orange 1x green = cartridge detection error
How to Reset waste ink counter Manually 1. Unplug power and USB cable. 2. Open door and hold power button. 3. Connect power. 4. Close door, then release power button.
How to Reset waste ink counter using Resetter
1. Download software for Canon iP1200 printer. DOWNLOAD 2. Unzip downloaded file to any location using, 7ZIp, WinRAR, Winzip, etc 3. Run GeneralTool.exe 4. select connected USB port number from USB port 5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION 6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. the selected waste ink counter will be reset.
Thank you for posting. Hope this helps.
Jul 06, 2011 | Canon PIXMA iP1200 Photo Printer
Canon E18 error shows when the lens gets stuck while trying to extend.
  • This error indicate that focusing ring got stuck or jammed due sand, dust, may be due to external shock caused by dropping the device. try compressed air. With a fine tip blow off gun around lens barrel. It should remove all dust and sand. Turn the camera on this will solve the problem.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move once or twice then it will stuck again.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Thanks and have a nice day
Jul 04, 2011 | Canon PowerShot A470 Digital Camera
Hi , I have a Canon AE-1 camera and I'm haviving a problem with the film advance lever . It seems to be stuck . It will not advance. Have you ever come across this problem before? Thanks ,John.
Canon AE-1 35mm SLR is a manual focus camera EOS is Canon's designation of auto focus EOS stands for Electro-Optical System. The problem you are experiencing is caused by several little things that throws the camera, wind and cocking leaver out of synchronization or simply come to the end of the roll. There is a frame counter window just to the left of the shutter release behind the shutter speed dial. Also if you have just loaded film in the camera it may not be seated correctly check by releasing the rewind button, wind the film back but not all the way and open the camera to restart the film.
Mar 03, 2011 | Canon EOS-AE-1 35mm SLR Camera
Epson BX300F display shows priner error see documentation
Epson BX300F display shows priner error see...please help my
Dec 19, 2010 | Epson Stylus Multifunction Printer/...
I am looking to buy an instruction manual for a canon z180u sureshot, and I cannot find one any where. My computor skills are not very good so downloading is a bit of a problem- I would prefer an...
Hello there, You can download the owner manual at:
The file is about 1.8 MB You also need to answer some questions before you can download the file, Regards,
Dec 04, 2010 | Canon Sure Shot Z180u 35mm Point and Shoot...
Canon Pixma MP500 Error Code 6000
it is better you show it service center only becouse it is hardware problem .
Nov 06, 2009 | Office Equipment & Supplies
Email me at :
Sep 09, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon Sure Shot Z180u 35mm Point and Shoot Camera Logo
75 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
