Question about Eiki LC XNB3 Multimedia Projector
Problems changing lamp
Hi, i have changed my bulb and the only image that i received is a blue screen on my wall. The lamp is a brand new one but no image . On the top of projector the LAMP REPLACE is orange and LAMP is RED. What can i do ? Thank you!
  • 41 Answers
Try removing the new bulb and reinsert it and make sure it make a good connection. Be sure to follow your projector's instruction manual on how to change your bulb exactly.
Posted on Jul 27, 2007
Hi my Sony KDF-E50A10 has a yellow blob in middle of the screen. Tried changing the bulb and yellow blob was worse. any suggestions?
Your Optic blog has failed. The bulb will not fix that. There was a class aciton lawsuit against Sony about this a few years ago. The Optic block must be replaced(only posibble fix) Sony Rear Projection LCD TV
To fix it out of pocket would be ridiculously expensive($800+). Return the lamp or use it until the image is too bad to watch. Then treat yourself to a new TV.
I am well versed on this issue and would not recommend fixing this
Jan 10, 2018 | Sony Televison & Video
How do i change side bulb in mitsubishi space wagon
Mitsubishi change side lamp bulb mitsubishi space wagon ...
www.fixya.com > ... > change side lamp bulb mitsubishi space wagon
Change side lamp bulb Mitsubishi space wagon related problems. Ask your Change side lamp bulb Mitsubishi space wagon questions. Get free help, advice ...
Mitsubishi Space Wagon 91 98 Sidelight Bulbs W5W 501 ...
www.ebay.com > ... > External Lights & Indicators > Bulbs & LEDs
eBayProduct Type: Sidelight. Operates: Sidelight. Further Information: These bulbs are a direct replacement for any W5W 5W (501) wedge bulb no matter what brand.
Nov 26, 2015 | Mitsubishi Cars & Trucks
Time to change bulb??
Check the lamp. It might be faulty. [low light intensity]
May 11, 2012 | Vivitek D732MX DLP Projector, 3200 ANSI...
I am trying to figure out how to replace my replacement lamp, but do not know where it is located.
Lamp Access door for Sony KF50WE610 is below the screen on the front of the TV. This page shows location of Lamp access door and DIY bulb change instructions for most SONY LCD TVs:
DIY Bulb Installation Guide
XL-2000 XL-2100 XL-2200
XL-2400 XL-2500 XL-5000
XL-5100 XL-5200 XL-5300
This page shows Lamps and bulbs for all Sony LCD Projection TVs
Sony Lamp Gallery
Look at Optical Engine Faults before buying a lamp or bulb. Replacement bulb will not repair these problems.
Feb 05, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Still getting "Projection lamp is nearing end of life"
KDF46E2000 - Change Lamp Warning - Reset
Bulb is most likely OK. Original bulb in Sony TV is Philips, label on bulb usually says Philips. Sony don't make bulbs. Sony Cost is usually 1.5 times other sources. Many shopping cart operations sell condemned, reject or poor quality electronic service items because cost of return and fooling with them is excessive. This is obvious and widespread with convergence ICs and other parts.
Lamp timer needs reset. This is usually an automatic function. TV detects Increased lamp current from previous failed bulb or weak bulb condition and resets automatically. TV must be unplugged for lamp replacement for this to work. Occasionally it must be reset manually, as below:
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a
second of each other:
DISPLAY Channel 5 Volume + POWER .1. Access Service Adjustment Mode and select the Service Menu that
contains the Category with the Adjustment Item you want to change.
2. To change the Category, press 2 or 5 on the Remote Commander.
Note: Pressing 2 or 5 only changes the categories within the
Service Menu displayed. To change a Category on one of the other
Service Menus, press the JUMP button until the correct Service
Menu is displayed.
3. To change the Adjustment Item, press 1 or 4 on the Remote
Commander.
4. To change the Data Value, press 3 or 6 on the Remote
Commander.
Note: To go back to the last saved Data Value, press 0 then ENT
on the Remote Commander to read the memory.
5. To save the changes, press MUTING then ENT to write into
memory.
6. To exit service mode, turn the power off by pressing POWER .
Wait 2 minutes before restarting the set to allow the fans to
completely shut down or the Service Menu will appear on the screen.
easyab
ConvergenceRepair.com
__________________
Feb 27, 2010 | Sony KDF46E2000 46" Projection HDTV
Acer Aspire One A150 : screen all dark after changing it
It is an inverter problem. Check all cable attachments first, then change out the inverter.
Feb 17, 2010 | Acer Aspire One A150-1049 Notebook
Problems with Projector Panasonic PT-L501XU after change the lamp
was this bought new or second hand?
There is a "Lamp Time" setting that can be accessd using your remote control, check this setting.
Look on page 40 and after that of your manual about ambient temperature bulb failure.
By powering off or hittign the reset button the bulb should stay on IF the projector is gettign a signal from a device to show an image. If the projector is not hooked up to a device, laptop, TV, etc. the bulb may turn off to save hours of operation.
Dec 21, 2009 | Panasonic PT L501U Multimedia Projector
Giant blue spot on 50" Hitachi LCD HDTV
The problem is an expensive one. The blue display has become distorted due to excessive heat overtime. The blue display is closest to the lamp and gets most of the heat. The Light Engine must be replaced by a repair shop to correct the problem.
Mar 22, 2009 | Hitachi 50V720 Television
My in1 projecter keeps turning itself off
if the lamp has 2000 hors on it, it needs replacing. go into the menu and find out how many lamp hours are used. it could be the lamp and it could be the ballast.
Nov 23, 2008 | InFocus ScreenPlay 4805 Multimedia...
MY TV has a blue cloud on the left side
Blue lcd is burnt up.. Normally happens due to excess heat from poor ventilation or not changing the lamp at the required time.. Allways happens on the blue as blue light is the hottest wave length, and as the lamp burns, it shifts to that side. Nothing you can do but replace the lcd itself. From the image shown, looks like the unit uses sony lcds.. Sonys are well known for there burns.. No quick fix on this one.
Jan 27, 2007 | LG RU52SZ30 52" Television
Eiki LC XNB3 Multimedia Projector Logo
338 people viewed this question
Top Eiki Office Equipment & Supplies Experts
Jaime Hernandez
Mohamad Abdan
Mohamad Abdan
neOen
Level 1 Expert
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
