Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer (GWH9100LW1) Bangs Loudly during spin
I have a Duet GWH9100LW1 with symptoms of a failed drum bearing resulting in very loud banging noises during spin with any size load. The unit is out of warranty. Based on my experience with this and a prior front loader washers (Maytag Neptune), I'm hesitant to invest in repairing vs. replacement with a top loader washer. In my experience, top loaders are significantly more reliable. I don't think I've ever had a top loader washer fail before 15 years, but my experience with front loaders is that they might not even make it to the 5 year point. Is this consistent with industry experience? What are the estimated repair costs if I had the Duet serviced by a professional or part #'s and costs if I performed the repairs myself?
  • 3 more comments
  • Mark William Jan 06, 2009
    After further investigation, the problem may not be as severe as I thought. Here's what I found. The tub bearing doesn't seem to have any significant play, although I can't quantize the exact amount. The drive pulley attached to the drum assembly appears to be bent. Looks like there is a variation of as much of 1/4" in the distance between the OD of the pulley and any given point on the tub assembly that's quite noticeable as the pulley turns. I don't know how or why it would become bent. It seemed as though the pulley nut wasn't very snug on the pulley, so I snugged it up by a small amount.
    I believe that the bent pulley results in setting up motion in the tub assembly from front to back of the machine. This motion increases with drum spin speed. This motion in turn first causes the plastic vent pipe to strike the frame starting the first banging noise. At higher speeds and greater front to back motion of the tub assembly, the nut holding the drive pulley onto the tub assembly begins to strike the rear cover. It' has developed quite a dent in the cover. I'm hoping that replacing the pulley and belt will solve the problem, but the question is why did the pulley get bent to start with and is there something else wrong that will result in failure of the a new pulley?
  • Mark William Jan 11, 2009
    After tightening the nut on the tub pulley, the symptoms improved, but there seemed to till be a lot of front to rear motion of the tub assembly. I could see the tub pulley was slightly bent. I replaced the pulley and all is now fine. Not anywhere near as bad as I had feared. I also purchased a new belt, but it was so tight that I was concerned about putting too much strain on the tub bearing since the unit was 6 years old or so. I'm sure that the old belt was stretched out, but otherwise seemed to be ok, so I just put the hold belt back on.
  • Anonymous Mar 27, 2009
    So you replaced the pulley. Good to know. I have the same problem with this 6 years old washing machine.
    Thanks
  • jpmgc69 Apr 07, 2009
    Loud banging sound during spin cycle. Turned out to be the center of large pulley on rear of drum had worn its self loose, spraying the rear inside of machine with a fine black dust until belt fell off. Had it repaired for
    $ 260.00 (pulley was only $ 47.00) and 7 Months later the same problem returns with same results. It seems to me that the material that the pulley is made of is too soft for the stress and the shaft it is bolted to tears out the center of same .Any ideas?
  • Anonymous Mar 28, 2014
    maytag front loader 4.5
  • 530 Answers
How old iss your washer? do you have an owners manual. because usually there is an extended factory warrenty on the tub and basket. the only thing you would have to pay for would be the labor. Call whirlpool if you do not have a owners manual to find out. the bearing is compressed in the tub. does it sound like an airplain taking off in your house that's usually it.
Posted on Jan 04, 2009
  • erica graber Jan 04, 2009
    if you do not have a warrenty it would be about $1000.00 to repair.
I had the same problem and it turned out to be the bearings. I talked to 5 repair techs. and A & E factory service. They all told me that all front loaders where lasting around 7 yrs. ( mine was 7 yrs and 2 months). The outer tub is covered for 10 years for "cracking". My outer tub was damaged because of the bearings causing the inner tub (lifetime warranty) to shred the front of the outer tub. This was not covered. The repair cost was going to be about $900.00 The funny thing is, all the techs still recommended Whirlpool. I would not have ever bought another Whirlpool on principle but my wife loved the machine, so we went out and bought a new one for $722.00. We also bought the 5yr extended warranty and H.H. Gregg store bought the addition 5yr warranty for us for a total of 10 yrs.Not only did went get a washer with more features, we have a warranty, instead of 90 days parts and 30 days labor for a repair.
P.S. Factory service stated that I should stay away from all top loaders that have no agitatior. They have major problem.
Posted on Jan 07, 2009
  • 3 Answers
I have a Kenmore which is the same as the Whirlpool. I dismantled the unit, it was only 3 years as Sears stated its was not under warranty. Upon review the stainless steel tub tripod assembly which is connected to the flywheel was cracked in three places which caused the knocking and vibration. Even though the warranty states lifetime on the Stainless steel drum, there is a ploy on words as the failure was not the stainless steel, so these machines are good for the scrap heap as the cost to replace the parts is more expensive than a new washer.
Posted on Apr 14, 2009
Whirlpool Duet Washer Model WFW9400SZ00 bangs only during spin cycle.
Yes you are exactly right, these bearings have failed & are causing the noise very common problem with whirlpool front loaders. very expensive to repair worth while looking into replacing instead of repairing as it will just happen again.The new LG machines are the best in my opinion.
Feb 06, 2012 | Whirlpool duet Washing Machines
Front load washer problems
Hello,Most likely this will be the drum bearings.
Bearings normally last quite a long time but some will fail sooner than others. Quite often bearing failure is due to a faulty drum shaft seal which allows a small amount of water through and in to the bearings. The bearings then start to rust, which then accelerates the wear on the bearings.
Thanks
May 31, 2010 | Kenmore HE2 Plus Front Load Washer
Washer making loud noise and wont spin
Check and see if the inner drum is loose and floppy.if it is, it's likely the bearings have collapsed, and require replacement...If the drum feels stiff and tight, it could be that something is jammed between the inner and outer drums. Both situations could be costly...Get quotes....Good luck...Nomess
May 22, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Very loud rumbling noise during spinning
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Sep 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Loud grinding noise only during the spin cycle.
Try looking at the solution for loud noise during spin with gray water in drain. This also sounds like the bearings on the shaft supporting the stainless steel drum, in the aft half of the outer drum.
Apr 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Loud Noise during spin cycle
drum bearings are gone,it would cost too much to repair,the drum shaft would to be repalced as well.Sorry
Dec 15, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
2,044 people viewed this question
Dan Webster
Dan Webster
Sal De
