Question about Hotpoint TDC32 Electric Dryer
Empty water light stays on
Hi the model of the condensor dryer is cdt00 the empty water light is staying on all the time even though there is no water in the draw therefore wont heat the dryer up have cleaned all filters, the dryer is almost new
  • Hotpoint Master
  • 3,463 Answers
Remove lower left filter,and washout under running water, reach into the opening and clear out all fluff and gunge, get a plastic bag tie or similar, and feel for and locate small hole at rear of compartment and poke clear with plastic
Make sure the air vents are clear back and front and try again, if still showing light then probably the float switch is sticking or faulty, this involves a complete strip down of dryer to fix.
Plz rate my solution.
Thanks.
Posted on Jan 04, 2009
Hotpoint condensing dryer model TCFS93BGP. cleanfilter/empty water light keeps coming on after 3/4 minutes
Hi, my dryer has 3 things to check out of which one is more hidden:
- empty the water reservoir
- clean filter in the door
- clean condensor which is hidden below the bottom panel which has to be released through a button behind the door
The last one is less obvious and more difficult to find/reach. Might need to consult the manual.
Did you check all 3?
Hope this helps
Mar 25, 2016 | Hotpoint Dryers
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
Empty water button staying on
Remove lower left filter from dryer, and wash it out under running water. Reach inside the compartment and clean any fluff and gunge you can find there.
Get a plastic bag tie or similar, and feel for and locate a small hole at the rear of compartment, poke it clear with bag tie.
If you are certain that the element and stats are o/k , and it still does not heat and the light stays on, then that indicates that the float switch is stuck or is faulty.
To access this involves stripping the dryer down, not an easy job.
Thanks.
Jan 10, 2009 | Bosch Axxis WTA 4107 Electric Dryer
Empty water light staying on machine will not work
Probably sticking float switch
Remove lower bottom left filter completely run water thro it to clean all fluff out reach inside and clear any build up of fluff that you can see or feel.
At the back of this aperture is a small hole that gets clogged up,feel for it and poke a plastic bag tie or similar, and poke it clear, if this does not work then it would probably involve a strip down to access the float chamber and switch assy.
Thanks.
Dec 13, 2008 | Hotpoint TDC32 Electric Dryer
I have a Hotpoint Aquarius dryer TDC30. The 'Empty Water' light stays on even though the reservoir has been emptied. The machine runs but does not warm up. Is this a common problem? has the element...
Float chamber is bunged up ,at the rear of the dryer at the bottom is a black plug / cap pull it off and stick a pipe cleaner
or long cable tie metal coat hanger in it to clear the old wet fluff (have some kitchen roll handy as some water comes out with the wet fluff),
other wise its a total strip down to clear the chamber out.
Oct 29, 2008 | Dryers
Seimans dryer txl733...incessant buzzing warning light to empty water resevoir even after emptying?
hiya
i take it this is a condensor dryer, the most likely cause of this will be the float in the recirculation pump (takes he water from the condensor unit to the bottle) sometimes these just stick and once freed they work ok, other times they will need replaced.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 03, 2008 | Siemens Dryers
Water light on dryer
hey cadoras,
you might want to check the sensor for the water inside the dryer. you say that even if you already put water in it, the light is still on correct? which means that the dryer does not detect or sense that water is already there. so please check if the sensor is working and if not, replace the sensor.
Jun 04, 2008 | Hotpoint Dryers
Hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Mar 09, 2008 | Dryers
Hotpoint dryer TDC32
check the switch where you remove the tank towards he bottom
Dec 30, 2007 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC32 Electric Dryer Logo
349 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
