Question about GE 24" Built-in Single Electric Wall Oven - Black
Ge wall oven model jkp66g001 broiler does not work
Broiler doesn't work
  • 25 Answers
SOURCE: electric starter gas oven model jgrp17 won't heat
more than likely your glow bar ignitor has stopped working or at least pulling enough amps to open the safety valve. The floor of the ovens come out may have a couple screws toward the back. take the floor out if a diffuser is on top of the burner remove it. the glow bar ignitor is mounted on the burner turn the oven on and watch it should glow bright red and in about 30 secs open the gas safety valve. If it does not glow you may want to verify power to the ignitor, more than likely the ignitor is the problem. If it glows but does not open the safety valev still replace the ignitor not pulling the required amps to open the safety valve. just put a little dish soap on the screws to the ignitor to help from srtripping them out
Posted on Feb 23, 2008
docjohn174
  • 943 Answers
SOURCE: the oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Posted on Sep 30, 2008
dgjtex
  • 405 Answers
SOURCE: Install bake unit in GE wall oven model JKP07J
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
Posted on Dec 27, 2008
  • 89 Answers
SOURCE: broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
Posted on May 29, 2009
SOURCE: GE P7 Wall oven model JK1905AV only gets warm....
I have a pair I'm trying to get rid of if you're interested.
Posted on Aug 05, 2009
Testimonial: "thanks!"
Oven element good but does not heat even though broil workes with temp sensor
Hello Billy;
My name is Peter. I am a retired field service appliance technician.
First, your broiler is not connected to your oven thermocouple (Temperature sensor). When you turn on your broiler full load amps go into the broiler element with no adjustment.
There are only three components that control your oven operation:
1.) Heater Element - Inspect your heating element for cracks, sparking or corrosion on the two contacts on the back wall.
2.) Thermocouple - This is a temperature sensor inside your oven. It is about the diameter of a coat hanger wire. Either it comes straight out of the back upper wall or is mounted on the back wall.
It is disconnected and removed from the upper back of the oven.
You should get a meter reading of 1000-1100 Ohms if the component is good.
3.) Oven Control - The control communicates with the thermocouple and increases or decreases the amps to the oven heating element. If the thermocouple is good then the oven control needs to be replaced.
If in unsure, replace them both.
Recently, I replace a digital oven control for a friend. Sears wanted $256.00 for the control. I purchased a remanufactured oven control over the internet for $30.00.
Get the oven model number off your oven. It is on a metal tag on the face of the oven after you open the door.
Go into the following website. Put in your oven model number (on the left). You will get diagrams and parts part numbers. Record these numbers for the above components. Put the part number in your computer search engine and search best price.
CAUTION: If you replace a electrical control board GROUND YOURSELF by touching something that is bare metal. Static electricity will knock out a control board.
Water Filters Lawn Garden Appliance Parts
Jun 06, 2015 | Ovens
I have a GE 24 inch wall oven model number JRS04B0W5BB that when bake is selected the broiler element comes on and then after awhile it looses temp and does not cook anything.
Ovens often use broiler element to preheat, then shut off when set temp is reached. Check fuses for and bake element itself.
Dec 01, 2014 | Ovens
GE wall oven gas model # JGRS14 won't heat past 100 and I don't see any flames
if you can see the ignitor glowing on either the broiler or the lower area of the oven then the gas valve is bad and not opening anymore,sometimes the ignitors are the culprit as they are in series with the gas valve and if weak wont let the valve open,but both upper and lower burners not operating i would suspect a gas valve first
Nov 24, 2012 | GE JGRS14 Gas Single Oven
It's a Model JJW8530CAB. The baking element
Are you having any issues at all with the display at all? Did this start out of the blue or did you have a power outage or anything else?
Jan 20, 2012 | Jenn-Air 27 in. Electric Single Wall Oven...
Oven doesn't work (bake nor broiler) checked both heating elements there fine whats next?
With out a model number I was unable to look up any specific information.
First I would look for a thermo fuse on the back side. If you model has one it may be bad. If it's a older oven with a mechanical clock make sure the clock is not set to timed bake.
Aug 03, 2011 | Ovens
Our 17year old GE gas oven/broiler stopped lighting today. What might be the problem? Stove burners work.
Most likely culprit is the igniter.
When you turn the oven on it opens a gas valve allowing a small amount of gas to flow thru the pilot light. The igniter then lights the pilot and when the sensor determines the pilot is lit it opens th emain gas valve and the oven lights. If the igniter fails and doesn't light the pilot the sensor doesn't heat up and it shuts down the pilot and nothing works.
The igniter is usually accessable under the oven by removing the drawer. It has a single wire attached and looks like a short cigarette made of ceramic witha metal tip.
You didn't provide model number so I can't give you part number but if you look it up here you may be able to get one from Sears
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001
May 18, 2011 | Ovens
GE Gas built in oven Model JRS14 will not heat up
The bake ignitor has failed.Turn off the gas supply. Remove the racks. Then remove the bottom pan cover in the oven to access the ignitor. Place a amp meter on one wire of the ignitor.Turn the BAKE switch on. If it reads less than 3 amps,replace the ignitor.
Oct 30, 2009 | GE 24" Built-In Single Gas Wall Oven
Oven wont light
Check the amp draw on the ignitor. If 2.9 amps or less, replace the ignitor. If 2.9 amps or more, replace the gas safety valve.
Aug 02, 2009 | GE Ovens
Broiler element comes on when "bake" is pressed
May 28, 2009 | GE JTP15 Electric Single Oven
GE 24" Built-in Single Electric Wall Oven - Black Logo
55 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
