Question about iLO 3200 32 in. LCD Television
I want to know R46 value
MLT 169B
    Top Expert:
  • iLO Master
  • 75,476 Answers
Download the service manual to this set from net. It will have the detail you want.
Posted on Nov 03, 2012
  • nguyen Nov 05, 2012
    can you send a link to download teh service manual?
R46 Paint Code
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Find the color code of your Yamaha Motorcycle
Yamaha Motorcycle Paint ColorRite
Yamaha YZF600 YZF600R 1994 2007 Service Repair Manual PDF Download Manuals...
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Mar 13, 2012 | Yamaha YZF 600 R thunder cat Motorcycles
Samsung SCX-4826FN/XAA toner exhausted
You need to replace the toner cartridge with the following part number MLT-D209L or MLT-D209S or MLT-D2092L.
Take these numbers to your local cartridge shop and they will be able to supply them.
Regards GM
May 27, 2011 | Samsung SCX-4828FN All-In-One Laser...
Hitachi 50FX20B convergence problem
RK42 is 2.7 ohm 1watt
RK46 &RK54 are both 2.2 ohm 1watt
RK50 & RK62 are both 3.3 ohm 1watt
RK58 is 3.9 ohm 1watt
They are all metal film (flameproof) 5% resistors
Jul 20, 2009 | Hitachi 50DX01B 50" Rear Projection...
Blown resister #46 need resistance value or color bands
From what if read number r46 is 150ohm im looking for the value of r45 hope it helps
Apr 22, 2009 | Yamaha YST-SW015 Subwoofer
Code needed for Memorex MLT 3221 HDTV To work with AT&T U Verse
Try 1431 - it's a Poloroid code since some Memorex tvs are similar
Jan 06, 2009 | Memorex MLT3221 32 in. LCD TV
Power Supply rapair
I fixed my Akai LCT3201AD in about 30mins. using 3 small parts from Radio Shack. Once I got the back off, I found the power supply board (PSB), mine was part# MLT-169B rev1.2. I looked at the capacitors (caps.) first, because they are usually easy to diagnose. I noticed the caps. bubbled out on the top of the board (where all the cables connect to it). There is 3 of them in a row, positioned between the two large heatsinks. My guess is that the heatsinks are generating a LOT of heat over time, because of bad ventilation, and causing the caps. to fail.
I went to Radio Shack and found 3 caps. (only had 3 in stock). The original ones were 16V-1000uF, Radio Shack only carried 35V and 50V in the 1000uF caps., so I bought the 35V ones and headed home, I removed the old caps. from the board, and installed the new ones. The 35V caps, are a little bigger, so its a tighter fit on the board, be careful. It took longer to remove the back from the TV than it did to do the soldering. YouTube.com has excellent videos on how to de-solder caps. on PSB's.
Total money spent on repairs:
$1.59 ea for 3 Caps. (part# 272-1032) $4.77
$2.99 for new soldering iron tip + $2.99
$1.00 donation for St. Jude's + $1.00
Total including tax $9.30
So for less than $10, I did a repair that my local TV repair shop wanted $575 for. Online stores want anywhere from $100-$275 for a PSB. If I get another 2 yrs out of it that's well worth $10.
Dec 14, 2008 | Akai LCT3201AD 32 in. LCD Television
Cobra 29
To my knowledge and depending on what board your Cobra 29GTL used, R46 is 47ohms dropping resistor after the switched 12V. Its output is then filtered by C20, 100uF/16V. While it is true that a shorted C20 would burnout R46, the issue is most likely a shorted FET2 (P/N 2SK104H). Should FET2 proved to be shorted, then it is very possible also that inductor/coil near FET2 is defective (LT-A108?).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 15, 2008 | Cobra 29 LTD CB Radio
NEED HELP
SYMPTOM: No Display.
COUNTERMEASURE: Re-solder the following components on PCB X34-415:
R43, R44, R46, R47, R48, R49, R50, R51, R55, and R57.
Ok so if you remove the top of the unit and cd player down the right side you see a line of surface resistors that say 2R7 on them, they all need to be resolders to the bord theres 9 total.
R43 is the circut number. They say 2R7 On Them
Jul 12, 2008 | Kenwood KDC-X590 CD Player
Akai lct3201 power problem
Nov 22, 2007 | Akai LCT3201AD 32 in. LCD Television
iLO 3200 32 in. LCD Television Logo
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
