Where to buy second hand lcd laptop for samsung sens 855
I stepped on my laptop samsung sens 855, the lcd cracked so i can not use it anymore, can i still replace d lcd? where to buy? tnx
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 137 Answers
The best chance you have is to get your panel specifications and find a site where you can order the same panel. It isn't a simple unplug-replace-done process. It can be quite meddlesome. It would be much simpler to go to a repair shop where they have panels present for replacement.
Posted on Nov 03, 2012
4 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: how do i replace a toshiba qosmio f45-av411 lcd
You can buy LCD screens on the Internet, I purchase parts from LCD Parts, they also service/repair and have DIY info.
Use this link to their WEB site :-
www.lcdparts.net
Posted on Aug 28, 2009
devverma143
  • 163 Answers
SOURCE: we have a samsung sens r50; the problem is with
firstly check the input power that is coming to ur home. this may be due to high voltage and may be a problem in the charger adapter.
Posted on Apr 19, 2010
joecoolvette
  • 5660 Answers
SOURCE: Laptop Screen is Cracked , need to replace lcd 16"
Let's get back to reality here.
Prices vary from city to city, or township to township, much less country to country.
I'm in the central USA. I can go to the next city, and prices will change.
If I went to California, or New York for example, the prices generally would increase.
I suggest YOU replace it, and save a boatload of money.
I'm going to look around on the internet, to check on Acer Aspire 6930-6771 LCD screen prices.
The search hits I provide will not be advertising, just examples.
I don't advertise for anybody.
http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=9008&zenid=e05ea4721d32d7a4c9e6a1fef6cffc14
Cheapest I found so far from a Reputable dealer, but you may want to try your hand.
Now you're going to need a Service Manual. See how to correctly disassemble the Display Assembly, to replace the LCD screen.
The Acer Aspire 6930-6771 Notebook PC is one of the Aspire 6930 series.
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
These service manuals are free to download, although donations are accepted.
(Just what I read)
Go down to the second Aspire heading. The one that begins with Aspire 1200.
Now go down to line 8. The one that begins with 5738GZ.
Go across, and left-click on > 6930
This is a PDF file.
The computer you are using now has Adobe Reader on it, which uses PDF files.
(I would recommend upgrading to Adobe Reader 9 if you do not have it. It's free)
After you click you won't see anything happening for a few seconds. Then the first page pops up.
Took approximately 8 seconds before the first page popped up for me.
It also takes additional time for the file to fully download.
Took a total of 85 seconds in all for the file to fully download for me.
I'm using a medium speed DSL connection.
Advise let the file download all the way before looking through it.
In the Bookmarks menu to the left, click on the + sign next to >
Machine Disassembly and Replacement
Now click on the + sign next to Main Unit Disassembly Process
Finally scroll down, and click on Removing the Switch Cover.
Page 76 in the PDF page number box at the top.
The actual page number is 66)
The last page you will finish with is Page 84 (PDF page number. Actual page number is 74)
A) You have to remove ALL power to the laptop First.
Remove the AC adapter (Charger) and Battery.
B) Observe Anti-Static Precautions.
Cannot stress this enough. If you have an ESD wrist strap available, use it. Connect the alligator clip to a good ground. If not, suggest you buy one, and wear it. Average cost is $3 to $6 ,for an economical one that will do the job just fine. Available in a multitude of stores, and online. (Electro Static Discharge)
Example;
http://www.amazon.com/Cables-Unlimited-ACC-1400-Static-Grounding/dp/B000EDMPQK
(If you look they have new ones available for $3.50. Not advertising for this people. Just one example)
C) Use a multi-compartment container for the various screws you will remove. Mark the compartments for the various screws you will remove.
You DO NOT want to mix those screws up. Some look VERY similar to others, but they Aren't.
You can use a clean egg carton in a pinch. Label each egg holder.
D) The Switch Cover has to come off first. There's 10 securing screws on accessed from the bottom.
Laptop open, DO NOT lift straight up on the Switch Cover. There are cables attached.
(Just in case you are not aware. You can enlarge the view on a PDF file. Go to the top header, and click on the Zoom In icon. ( + )
E) Remove the Power Board (It's a circuit board)
One connector on the cable for the Power Board is a ZIF connector.
(Zero Insertion Force)
These connectors Do Not come all the way apart. They just spread open.
This action unlocks the connector, and allows a Flat Flex Cable to be removed.
The connector is shaped like a fat T, with small tabs being the top of the T.
These small tabs, (One on each side) are eased towards the LCD screen.
The ZIF connector unlocks allowing you to remove a flat flex cable.
Just the flat cable. There will be no connector attached to it.
To expound;
http://www.youtube.com/watch?v=RblDBWRFB7o&feature=fvw
At 1:18 he's opening a ZIF connector, and removing a flat flex cable.
F) Remove the Keyboard. (Another ZIF connector is used)
G) Remove the Speaker Module
H) Remove the Antenna Cables
I) Finally remove the LCD Assembly.
I would like you to now go to the Bookmark menu, and close Machine Disassembly and Replacement.
Click on the Minus sign ( - )
Scroll down to the heading > FRU (Field Replacement Unit) List, and click on the + sign to the left.
Now click right on > LCD Module
This shows you an exploded illustration of the Display Assembly.
Gives you an idea of how the parts fit together, how they come apart, and the names.
If you wanted to you could print this off.
Now close this section, (Click on the - sign), and open Machine Disassembly and Replacement once more.
Go down to where it states LCD Module Disassembly Process, and click right on it.
Follow the next few page to disassemble the Display Assembly.
Then reverse with the new LCD screen installed.
Do I think you can do it?
ABSOLUTELY
If you have problems ANYWHERE along the way, come back here, and post it/them in a Comment.
We'll walk through it together.
Regards,
joecoolvette
Posted on Nov 10, 2010
I'm looking for a replacement plasma panel for my Samsung TV, any ideas?
Plasm's are not build anymore, so you could try to buy a second hand plasma, because nobody will have these screens in stock. The screens alone cost more than a complete TV.
Feb 06, 2015 | Samsung Televison & Video
HELP Samsung sens p30 audio driver
You can download the audio and device drivers from the Samsung WEB site. Please click on this link and select your model computer/notebook and the Windows drivers you require :-. http://www.samsung.com/us/support/
Sep 16, 2012 | Samsung P30 Notebook
Samsung 46 LN46D550 LCD TV. The outside case is cracked
be careful of Samsung's, they are notorious for LCD panel tab failures. Do your homework first !!! There are plenty of reviews that backup my suggestion.
Jun 05, 2012 | Samsung 46 LN46D550 LCD TV
Hi, my daughter has a dell inspiron 1545 laptop which is about 18 months old. today when she turned it on , apart from a 3/4 inch strip on the left hand side, the screen had a pattern resembling a large...
i think this is fixable, but just professional teachnician from service center can fix it, you just go to service center, and ask for fix that error
Dec 02, 2010 | Dell Inspiron 9100 Notebook
Screen cracked laptop was accidentely dropped laptop still working but the screen is not showing everything on it ie:colour faded in places
your screen really might be damaged, you cant fix it unless you change the lcd itself,buy a 2nd hand lcd, its cheaper than buying a new one
Feb 15, 2010 | Computers & Internet
Cracked monitor
Hi there.
I'm in no doubt that the screen has to be replaced and maybe other components to if they have suffered shock damage.
If you want to check to see if the system still works plug an external monitor to the laptop, then use the keyboard toggle to switch screens (usually hold down Fn and hit the F key with a monitor icon on it)
If you get a good display whilst using the external and the OS works properly then it will just be the screen and any plastics that need replacing.
Good luck and thanks for choosing FixYa!!
Jun 08, 2009 | IBM ThinkPad R40 2722 Notebook
Replace screen
Just replace the LCD panel if you got spare part. But the new LCD panel may cost you as much as to buy a new tv.
Dec 30, 2007 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
LCD display cracked
id put my **** in my *** and cough out a nut
1600$ i could pay a ***** 16 time to but a nut and lick
my booty hole
Dec 01, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
