I have Xerox Workcentre 7435 with an error code of 010-338..please advise how to resolve this error !
  • 2072 Answers
SOURCE: xerox 390 error code 1
> Support & Drivers > WorkCentre 390 Laser All-in-One Support > Search Results > How To Clear a Fuser Error Message Solution: Perform a RAM Clear bttn_print.gifMake Printable bttn_email.gifEmail this page elem_1_spacer.gif Performing a RAM Clear will restore all of the WorkCentre's settings to the factory defaults. It will also clear all faxes in memory, Speed Dials, One-Touch Buttons, Group Speed Dials, your System ID, and any other stored information.
NOTE: If you are able to print, it is a good idea to print out your Phone Book before performing the RAM Clear, to assist you in reprogramming your Speed Dials and One-Touch Buttons. It is also recommended to print out your System Data List to assist you in reprogramming your system settings. If you are not sure how to print your Phone Book or System Data List, refer to Related Items at the bottom of this page.
To perform a RAM Clear:
  1. Press the [Menu] button on the Control Panel.
  2. Press the [#] key, then press 1934.
  3. NOTE: These buttons should be pressed quickly. If not successful, try varying the speed you are pressing the buttons.
  4. When this step is successful, the bottom right-hand corner of the LCD Display will read 'TECH'.
  5. NOTE: If you are unable to access Tech Mode, please refer to Related Items at the bottom of this page.
  6. Press the [Menu] button to start navigating the menu.
  7. Press the [Up] or [Down] arrow button until the LCD Display reads 'Memory Clear', then press [Select] button.
  8. The LCD Display will read 'US and Canada'.
  9. Press the [Start] button to clear memory.
Posted on Jan 19, 2008
  • 2072 Answers
SOURCE: workcentre c2424 is showing system error 39,003.40:117010
That is a document feed or scanner fault. Often times it is simply that molex connector working loose. It is the connector mounted vertically next to the main power cord on the right rear side of the machine. That bottom screw can be dificult to tighten. What I would try first is to shut the machine off, unscrew and disconnect that conntecot totally then firmly slide it in and get both the top and bottom screwss tight. Like I said, the bottom thumb screw can be hard to tighten even with a screw driver because it is a pretty soft rubber the tighteners are made out of.
If that doesnt work. go to the back and disconnect the document feed to scanner cables and reconnect. Other than that, you pretty much have to replace the feeder/scaner assembly since very very few parts are spared for that .
Posted on Oct 23, 2008
SOURCE: Xerox WorkCentre 24 error code
Xerox tektonix phaser 780p has 2nd bias roller fault message with printer error 24.
Are there any easy fixes for this?
Posted on Oct 28, 2008
  • 239 Answers
SOURCE: CA1 error code on my xerox workcentre 416
I hope this messege come through.
This is a call for a Xerox service rep to visit the machine.
First you need to know if it has the latest software on the machine. If it has old software, and a new laser is installed, the error code will come back again.
You will need to have the right model for this machine and the right main board to match it.
Best to place a service call and let Xerox handle it.
Posted on Oct 17, 2009
SOURCE: how to install Xerox WorkCentre PE16 scaner? i ...
How to install Xerox workcentre PE16 scaner?i install twin & driver but not work . Please help...
Posted on Jun 20, 2010
Xerox 7435 machin error 041340 plz advice for solutions
I found a reference to this for you in a Xerox service forum from one of the forum admins, who said:".....try reseating the Transfer Unit and see if that will clear the code. If not please consider contacting your support centre for further assistance."
You can find the message in her forum complete with links on how to do the above at the link below. Good luck! --Mark
http://forum.support.xerox.com/t5/Hardware/6280-gives-error-041-340-MCU-VRAM-error/td-p/22376
6280 gives error 041 340 MCU VRAM error
Oct 25, 2016 | Xerox Workcentre 7435 Color Multifunction...
Xerox 7435 error code 010-328 whtes the problem
it is the code for fuser heat control problem. Usually, the unit has its airflow restricted try moving the unit or cleaning it to see if the problem clears
Here is a list of all the error codes
WorkCentre 7425 style Fault Code List Part
Aug 02, 2016 | Xerox Workcentre 7435 Color Multifunction...
How do I solve wc 7435 error 010-338?
Hi
I found information about this error and some approaches to solving it here:
http://www.support.xerox.com/support/workcentre-7425-7428-7435/support/enus.html
and they can be tried in the order given. Hopefully either 1 or 2 or 3 on the list will work as they are non-cost options as opposed to number 4 which could be quite pricey.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 27, 2014 | Xerox WorkCentre 7425 7428 7435 Second...
How to resolve error code 010-334 in xerox workcentre 7435
Check around the fused assembly. Is it a new one, or is it one you put to one side as as a spare? If you have a service contract with Xerox you should be able to order a new one. I don't remember all they error codes but the 10 codes usually refer to the fuser unit.
Good luck.
Sep 08, 2014 | Xerox Workcentre 7435 Color Multifunction...
Cannot get new cyan toner for 7435 to be recognized.. may of been changed before asked for by machine... not sure what to do next
Call Xerox. The Corporation needs to take responsibility for selling a machine that has toner available. //They should tell you where to get the toner or provide some for you. Start out nice but don't let the push you around; insist if you need to. Xerox can't sell a machine with no toner.
May 23, 2014 | Xerox Workcentre 7435 Color Multifunction...
041 348 ERROR CODE XEROX 7435
That error is due to a problem with the MD Board. The most likely cause is the MD Board and needs to be replaced, link below for part needed.
http://www.iteminconline.com/960K38900_960K38900-960K38901-960K38902-Xerox-Workcentre-7425-MD-P.htm
Jul 17, 2012 | Xerox Office Equipment & Supplies
I have a Xerox 7345 Workcentre and need to replace the Fuser Assembly but it's not where the enclosed diagram says it should be ! Can you advise where to locate it please ?
7435 is located on the upper left side of the machine, Should have a yellow guide on it, 2 orange thumb screws are all that hold it in.Open the left side door, and look for labels that say CAUTION HOT..
May 19, 2011 | Xerox WorkCentre M-24 Color Copier
Need to enter service mode on a Xerox 7435
The service tech should do this. The 7435 should be less than 3 months old, and Xerox should fix it. If you bought it from Global, or another company that does not actually employ Xerox technicians, try appealing to them, but I cannot tell you for sure what the outcome will be. Buying from an authorized agency ensures that you can use your "Total Satisfaction Guarantee".
Jun 04, 2009 | Xerox WorkCentre M-24 Color Copier
3,667 people viewed this question
k24674
jasbo
jasbo
