Question about Sony MHC-ZX70DVD System
Mhc zx70 dvd drive not working
DVD DRIVE NOT WORKING ,TRAY NOT OPPEN ..AND SYSTEM HANGED...
How to oppen my WD
You don't. That's the quickest way to guarantee they never work again.
Jan 04, 2014 | Western Digital WD HDD 500GB SATA 25"...
Tray won't stay closed
The only thing to do on your unit is cleaning the lens. If you do other repair works on it you will lose your warranty
Feb 23, 2008 | RCA DRC8030N
How to get a dvd tray unstuck
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
May 19, 2013 | Televison & Video
DX4300-150
CD/DVD Drive Tray problems
Mar 12, 2013 | Computers & Internet
Hey Hi, my Dell DVD UJ862A is not working. I can see it in the Explorer but cannot read any CD or DVD. I have Downloaded also the Drive from Dell web but no success. If I right button the to get Eject...
you might have to physically unplug the leads for this cd/dvd drive restart your computer then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
May 18, 2011 | Computers & Internet
My disc tray won't open the lights turn on and work but the disc tray just won't open. How can I fix this?
hi,
You have to check two things.
1. You have to check the tray loading belt in the mechanism. To see the same you should remove the mechanism.because the loading belt is beneath the cd tray. As it is cyberhome it will be very difficult to remove the mechanism for an user. if your capable for doing the same then make try. Because you have to remove the top cover then the back panel, then the mechanism. Take care the mother board is attached to the mechanism.
2. You have to check the cyberhome dvd player will show this type of complaint if the Spindle motor is faulty (oppen or short ). Spindle motor is one on which the cd rotates. It will not cost a lot.
ok
May 05, 2011 | Cyberhome CH-DVD 300 DVD Player
HP Pavillion a6200n PC cd not working, but the DVD does work. When I put a cd in, it will not work. When I click on the drive, it asks me to insert a cd, it closes but does not play. The DVD works when I...
Your CD drive has an internal failure which is usually the laser head. It would be cheaper to replace the drive or use your DVD drive to read CD's then to have the laser head replaced in the CD drive. The disk tray motor system is not connected with the read write system in the drive and the tray ejecting or loading a disk is not an indication of the health of the drives logic system or laser head.
May 20, 2010 | Computers & Internet
Can not play any cd or dvd
Please check the proper cd/dvd is correct if cd/dvd is correct with no scratch then you need to change the tray with the motor lens set resolve your issue. Because when there is cd/dvd stucks and wont read menas there will be a lense problem.
Mar 16, 2009 | Philips LX3600D System
Rca dcr8060n dvd tray will not open
Your kid did not damage it, try this, apply pressure slowly to the top of the unit about 3 inches from the front of the unit centered above the tray. Press the eject button, I am betting it will open. They seem to have used really crappy dvd drives in this unit and the top magnetic mount does not release cleanly, therefor causing the unit to hang when the door attempts to open.
Jan 29, 2008 | Televison & Video
Dvd drive not work properly
it happens when the containg data of the dvd is heavy.or if ur pc ram is of lower size.
Dec 07, 2007 | LG GMA-4082N 8X SLIM DVD RW DRIVE FOR...
62 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
