Intermittent power on problem in desktop
Hi, please help in resolving the issue. I have a HCL Beanstalk desktop. It doesn't power on intermittent. When it gets powered on, it works fine.
  • joecoolvette
    joecoolvette Nov 03, 2012
    It powers on intermittent. On, then Off. 1) Check to see if the computer is dirty inside. (Power unplugged, Anti-Static Precautions followed) 2) Remove the Ram Memory modules, clean the gold plated contact pins with a pencil eraser. Still the same? Power Supply problem. Also Carefully check the Radial Aluminum Electrolytic Capacitors on the motherboard,http://capacitorlab.com/visible-failures...
    Top Expert:
  • 14,553 Answers
If a desk top unit and you have to try to turn it on several times to get it going I would suspect bad filter caps in the power supply---once on they will function--usually happens in units at least a few years old.
The power supply if removable can be tested or at least inspected for this as caps will be easy to see if bad----
Posted on Nov 03, 2012
krihard
  • 407 Answers
SOURCE: no sound
plz tell me after all your mp3 player run.......
hope some virus effect in your system....chack your anti virus 1st.
then setup your mp3 winamp 5.52 go to  download.com....thensetup properly...ok
Posted on Mar 02, 2008
SOURCE: powering up
cleaning wont help you have to get a new motherboard
Posted on Sep 20, 2008
SOURCE: Acer Aspire L100 will not power up
It's most likely not the power supply. I have a customer with the same problem. I used a power meter to see if the power supply worked and it checked out perfect. (You should still test it though, just in case.)
The only thing I can figure is a bad motherboard. Unfortunately, there's no visual signs of overheating, arc burns, or the like on this one to make it obvious... just one capacitor (the small one nearest to the power port) that has a slight bulge.
These things don't seem to be build to last, from what I've been reading.
Options:
-Break it down, sell the parts that are likely to still be good (wireless minipci card, memory, processor, heck - maybe even the front ports if you get longer cables/extensions), and maybe make around $200 that can be invested in a reliable machine.
-Or drop money into replacement parts. (but after what dj said about a second mobo going bad, I don't think it's worth investing more in this)
Posted on Jan 10, 2009
  • 34 Answers
SOURCE: intermittent startup problem. power light goes
The Yellow light would be for standby mode, Blue would be running. Sounds like the power supply is going bad, and when you took it to Best Buy the power was off long enough for it to not give you problems.
I would take it back to them as one of these times it will do what you are talking about and they will have to fix the problem. Do not let them get around fixing it under warranty.
The power supply can be a once in a while problem at first and progressively get worse.
Posted on Jan 09, 2010
SOURCE: hi i have a compaq
You may inserted the power supply to the CPU wrong or the motherboard is not functioning properly.
Posted on Mar 12, 2011
I have HCL Ezeebee desktop computer when we boot the system monitor, keyboard, mouse blink for a while and monitor (HCL) show 'no signal' message, and keyboard num lock led not display mouse i
No signal at the monitor indicates (if you know the monitor is working ok) a failure of the graphics chip or graphics card, The lack of indicator light on the num lock LED and the lack of power to the mouse would indicate that there is a major issue with the motherboard.
you can try using another monitor to confirm the problem lies with the graphics, and in the case of the keyboard and mouse, swap them for a usb version, if they work, the Ps2 ports are probably damaged.
I'd be thinking of replacing the motherboard
May 19, 2012 | Computers & Internet
On my device manager i see a yellow ? under other devices / PCI device. It doesn't show me what kind of driver I need.
Good day, the yellow question marks means that you have a device that has been detected by the computer but doesn't have a driver installed. You need to install the drivers included with your computer and devices. You can download a program on the internet that can detect all devices installed on your pc and it will update all your drivers to resolve this issue.
You can try to download this one:
http://www.devicedoctor.com/
> Just download and install
> Then run the program
It worked for my pc a lot of time. Help this will resolve your issue. Have a great day and thanks for using Fixya
May 26, 2011 | Dell Dimension 3000 PC Desktop
Ezeebee 4451 Desktop Motherboard Drivers
Here is the correct Site for all of the drivers
http://www.hclsupportservice.in/drvr-dwnld.jsp?pF=RGVza3RvcA==&pC=RXplZWJlZQ==
May 11, 2011 | HP Computers & Internet
Hcl beanstalk sound driver want
Hi nnirpa,
I see that you need a driver for your motherboard intel P4-4 864GV for the Audio to work, see link below for the driver download site.
http://drivertools.com/lp/en/7/AC97/xp/audio.html?dtid=5383&dtkw=ac97%20audio%20driver%20xp
I hope this helps.
Have a nice day,
mvincentc
May 05, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Power button won't stay down.
Sorry to hear you're experiencing a problem with the power button on your DC25.
In case you haven't tried this, give the button a firm push all the way down. If this doesn't resolve the issue, please get in touch with us, free, on 08002980298 (UK), or 1866MYDYSON (US) so we can help.
Kind regards,
Jack
Dyson Customer Service
Feb 24, 2011 | Dyson DC25 Animal Bagless Upright Vacuum
NO SOUND IN MY PC hcl I810-ITE8712
I was trying to find your given model name on the HCL page without succes. Register your product at HCL and get updated drivers.
Aug 30, 2009 | ASUS Terminator A7SC (TERMINATOR...
Sound Problem
Please mention the Model, Year of Mnfg. Model should be something like:
" HCL Ezeebee TOP T 811 " or "HCL Beanstalk Classic Z324" Else visit this link:
http://www.hclstore.in/consumer-pc.html and get the right drivers...............................sodeep
Apr 10, 2009 | Computers & Internet
HCL notebook drivers
Just go on the flowing link for download the HCL Desktop & Laptop driver
(www.hclsupportservice.in) HCL Driver site http://203.76.139.132:8080/examples/jsp/download/pon_index.jsp
(It’s free) and mail your quarry on wecare4u@hcl.in
Thanks
Abhay Singh
Sep 16, 2008 | Computers & Internet
Lost my laptop sound & display
I tried to search for the HCL drivers....it requires a specific code frm the laptop. Here's the link for tht page:
http://59.90.146.12:8080/examples/jsp/download/pon_index.jsp
In case of any issues, please let me knw
Jul 23, 2008 | VIA Balance Notebook Notebook
No sound
Mar 02, 2008 | Computers & Internet
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
