Question about Epson Stylus Photo R300 InkJet Printer
Vertical lines through my text and photos
Hi there, Please help. Everything I print has vertical lines running through it. I have tried to change my printer and paper settings and the lines either appear further apart or darker but never disapear. Any help is very much appreciated. Laura.
  • scorpion9er Jan 04, 2009
    I have the same problem on my epson stylus c66 with lines running through it. I have done all the cleaning you can do and this is a fairly new printer. Now if I print a few times then it clears up but then it will start up again. what can I do?
Either clean the print head nozzles or select a higher print quality and turn off High Speed mode.
Posted on Jan 08, 2009
How to print in vertical text mode
i dont know if i get the question right, but try to press the Style button and then move the cursor to the style that looks like "--" or "_". then pres the enter.
Sep 19, 2011 | Dymo LetraTag QX50 Thermal Label Printer
This evening I bought a new HP Photosmart C4780 printer. I am trying to print photos now and the photos are being printed with small vertical lines across the whole photo. How do I get rid of them?
> I bought a new printer
Take it back, and get one that does work correctly.
> VERTICAL lines ACROSS the whole photo
Hold the paper in "portrait" mode, not "landscape" mode.
Are the lines HORIZONTALLY-ACROSS the paper,
or VERTICALLY-DOWN the paper?
If those lines are WHITE and HORIZONTAL,
then some of the many ink-jets inside the print-head are *CLOGGED*.
Run a "print-head-cleaning-cycle" to try to unclog it.
Or, exercise the WARRANTY, and get it replaced.
Sep 24, 2010 | HP Office Equipment & Supplies
Faded text every few lines- Canon printer
When you print photos you print in Max dpi, for this no faded lines anywhere. Probably you have a problem only in black color in print head.
Мay be it's partially clogged or partially defective.
Sep 28, 2009 | Canon i850 InkJet Photo Printer
PRINTOUT IS LIKE A "ZEBRA" PATTERN
please download the latest drivers from:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=14991
Jun 30, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
I have the same problem vertical line epsonr230
get your printer service and get new INK jets mean Cartage for your printer thank you it will get no vertical lines then .. it is caused when cartages are leaking..
Jun 25, 2009 | Epson STYLUS R230 InkJet Photo Printer
Vertical and horizontal lines when printing photos - HP Photosmar
it sounds as if you may have the picture quality set to draft, its worth a check, especially if printing is ok. Does it print colour writing well too or just black, one of the colour inks may have a block or be low, go into printer settings menu and check what print quality its set for.
Apr 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
While printing photos my printer has white vertical lines
Sounds like you need to re-align the print cartridge . The reason the text comes out ok is probably because it is only using the black cartridge for text. The color cartridge is the one that's out of alignment. You may have some sort of Cannon utility running in the task bar that will allow you to easily allign the print cartridges. If not, go to the main "Printers and Faxes" window, RIGHT-click on the printer and select "Properties". You should be able to find a button in the properties that's labeled something like re-align print cartridges. It will print out a series of test pages and ask you to select the set of lines that looks the straightest and type it in. It's a good idea to do this every time you replace a cartrige. Hope this helps, If I was able to FixYa, please remember to rate me. Thanks.
Feb 22, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Epson 2200 - vertical lines
I don't know if this will help as my printer is a different model (the epson stylus photo r280) but I have been battling the vertical line issue for weeks, ever since getting a new imac. I am printing altered photos from photoshop on epson ultra premium matte photo paper. After trying every conceivable setting, and spending an hour with less than helpful tech support from epson (where they insisted I needed to download new drivers) I just resolved it this morning at last by increasing the dpi setting on the print function to beyond what I would normally use(1440x 1440 rather than what I had been using at 720).
The prints came out great at last!
On my older computer with this same printer the prints came out fine at the lower setting. But for some reason it appears that the higher setting is now necessary to eliminate those dreaded lines.
I hope this helps.
Feb 03, 2009 | Epson Stylus 2200 InkJet Photo Printer
Alignment wrong when using label stationery - OK with plain paer
open the related word document.
select 1 line above the Text in question, press enter twice.
That way, the text will drop by 2 lines.
try a test page on this, alternatively try using a different label layout, until you get the desired result.
Other than the AveryL7160.
Mike @ Compurepair.
Dec 05, 2007 | HP DeskJet 3940 InkJet Photo Printer
Epson Stylus Photo R300 InkJet Printer Logo
337 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
