I have samsung wf-f1061 and i am having problem that when i start the power button noting goes on? what to do.
It has lot of functions like washing all types of clothes like cotton,wool ect... it carrys 5kg clothes
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Do you have power at the console?
Posted on Nov 03, 2012
Bob Gemmell
  • 209 Answers
SOURCE: Black particles in clothes after using a top loading samsung fully automatic washing machine
You said these particles stick to the clothes, do they come off and then leave a stain? It may be grease or oil coming from a leaking drum bearing seal.
If it is, This is a major repair and not one for DIY.
Posted on Sep 28, 2007
  • 105 Answers
SOURCE: lg washing machine wf-t902. clothes tangling up
the machine has a broken wire to motor possibly
check that first
if not
does machine spin
otherwise at the bottom of gearbox under drive pulley there is a pring on main shaft and tah locks gearbox up
if this starts slipping on shaft it will only wash one way
remove and rough up shast refit and grease
Posted on Mar 16, 2008
  • 4 Answers
SOURCE: I have Model WF-S6607?WF-S6607TC. Washing Machine.
This might be Lid cover open protection. There is a small magnet at the edge of the lid cover, housed in some sort of a catch.
If the plastic housing cracked, the magnet might have dropped into the washing drum. To overcome this, place a magnet on the position where the plastic catch will contact the washer when the lid is close.
Posted on Sep 09, 2009
SOURCE: LG WF-T1022TP Fuzzy Logic
Dear Sir¨
The problem with my machine WF-T1022TP is the fallow:
The pump not run correctly, for these reason, I need the manual of operation, please send this document to my e-mail: jmar440@gmail.com
thank you
Regards
Javier
Posted on Oct 04, 2009
SOURCE: LG washing machine WF-F 6861 CN Problem
ne yabba ardhamayye la rayye bae
Posted on Jun 12, 2010
HI, MY SAMSUNG WASHING MACHINE WF-B1061 RECENTLY GOT ERROR IT SAYS 6E WHAT DOES IT MEAN? AND ALSO WHEN I SWITCH ON THE WATER GOES IN PROPERLY BUT SUDDENLY IT TURNS TO ERROR. THANKS & REGARDS WILL
6e error mean heater not functioning. Check the heater element and if is bad change it. If the heater element is ok, check the connection to electronic board.
All the best !
Apr 21, 2018 | Samsung Washing Machines
Start button won't work on NEC nfl-265 washing machine
My Samsung washing Maching DC68-20425B driving belt ( elastic )has been damaged, kindly give me it's code number , please
Thanks a lot
Sep 25, 2013 | Washing Machines
LG washing machine WF-950 consumes a lot electricity when i did spining , how can i disable spinning option , please advice me
Spin cycles are intergrated into the function on all washing machine (cycles). It cannot be disabled in any way.
May 30, 2012 | Washing Machines
How do I use the Child Lock option on Samsung WF-B1456GW?
You can use the child lock feature in 2 ways.
1. To prevent operation of the washing machine when no wash cycle is running
To set this feature, switch the machine on using the POWER button at the top-left of the control-panel. Next, press and hold both the SPIN and RINSE buttons for about 3 seconds - until the child lock light indicator on the control panel illuminates. All functions of the washing machine will now be disabled apart from POWER ON/OFF until such time as the child lock is deactivated.
To deactivate the child lock, press and hold the SPIN and RINSE buttons again until the child lock light indicator on the control panel goes out.
2. To prevent any tiny fingers from tampering with the machine while a program is running.
After pressing the START/PAUSE button to start the wash cycle, press and hold the SPIN and RINSE buttons until the child lock light indicator illuminates. All buttons on the control panel will now be disabled until the child lock has been disabled. When the wash cycle has finished, you will need to switch the child lock off again to reactivate the buttons. Once you have finished using the washer, reactivate the child lock again before switching the power off as above.
The feature can also be used when using the delayed start feature, but needs to be set after pressing the START/PAUSE button.
Hope this helps. Please let me know if I can be of further assistance.
Regards,
BElectric
Feb 09, 2011 | Washing Machines
STARTED, ROTATED A FEW TIMES, FILLED UP WITH WATER, NEXT MODE "WASH" BEEP BEEP. BEEP BEEP.. "d E" .. MACHINE STOP. POWER STILL ON. CONTROL BUTTONS STILL FUNCTIONING. IT IS A LG...
he error code "dE" signifies a door open error. This may simply be because the door is not all the way closed, though it could also represent a number of other problems. There may be a faulty door switch, a malfunctioning electrical connection or a damaged gasket.
Dec 11, 2010 | Washing Machines
Hi, my samsung washing machine wf-b1061 has no power. however whenever i remove the plug from the outlet, i could see from the panel a blink. what could be the problem. is it possible that the mother...
i have a samsung washing machine, no power in my washing machine and i couldnt find in side any fuse, can you tell me what is the problem it? thanks
Oct 21, 2010 | Samsung Washing Machines
Lg washing machine wf-t655th won't start
Auto/off is power button--correct?
start/pause button actually starts the unit--correct?
Jul 27, 2017 | LG Washing Machines
I have Model WF-S6607?WF-S6607TC. Washing Machine. Loaded the clothes, pressed the POWER button, pressed the WATER LEVEL button, pressed the PROCESS button, and pressed the START/PAUSE button, But few...
Apr 04, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Aquarise + super silent WF 630 1300 spin
to removed test display press and hold start/cancel button for 5 secs. then press on/off and start/cancel together until d-off is displayed then machine will work
Oct 27, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
130 people viewed this question
Top Washing Machines Experts
