Question about DeLonghi DH100P Dehumidifier
Dehumidifier wont work
I have a delonghi dehumidifier and i carnt seem to get it started when i switch it on it just keeps flashing and i dont know how to get it started as ive lost my instructions can u help as my kitchen is getting damp in this weather
22yooper
  • 828 Answers
SOURCE: delonghi de 220 dehumidifier tasciugo
http://www.manualnguide.com/download/manual-guide/
delonghi-de500p-dehumidifier-owners-manual.html
The above URL will allow you to download instruction manual if a PDF format.
Posted on May 09, 2008
SOURCE: lost owners guide to delonghi dehumidifier de400p showing code of e3
I am searching for a resolution to the E3 code (same init) and happened upon this request. The manual can be downloaded from DeLonghi.com but that advises you to call the service center.
Tom C
Posted on Jul 12, 2008
  • 72 Answers
SOURCE: delonghi de400p dehumidifier does not work
if comp and fans running your out of freon or the compressor is not pumping more than likely out of freon and that means theres a leak in the sealed system high cost repair
Posted on Jul 03, 2009
dcramer531
  • 1654 Answers
SOURCE: how to defrost a dehumidifier lost instruction
Simply turn it off and let it set! this will allow the coils to thaw.
Posted on Nov 27, 2010
  • 3 Answers
SOURCE: DeLonghi DH250R dehumidifyer - operating instructions?
http://www.delonghi.com.au/support/instruction_manuals/DH250R.pdf
Posted on Jan 10, 2011
I have the Delonghi DE500P and the lever that indicates the bucket is full will not stay down and therefore the bucket full light remains on and the fan will not start. when i use my finger to push this...
Replacing the switch/lever is more trouble and costly than it's worth. That's if you can find the part. I suggest, that you try reinstalling the bucket very carefully, making sure it making contact with the lever in the proper position. Lots of times, the bucket is simply not being inserted properly and it misses the switch. If that doesn't work and you want to repair it yourself. Contact Delonghi Parts Dept 800-865-6330.
Hope this helped you.
Apr 27, 2011 | DeLonghi DE500 Dehumidifier
My DeLonghi DE500P dehumifier whch I purchased last fall is no longer collecting water. Everything seems to be functioning as outlined in the instructions. The rooms humidity is about 55%. Any ideas?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Feb 07, 2011 | DeLonghi DH40P Dehumidifier
My dehumidifier keeps cutting out.
Most likely..motor cycles on over load switch..
Nov 04, 2009 | Dehumidifiers
My DeLonghi DEM10 wont power on any more - like fuse gone
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Sep 03, 2009 | DeLonghi Dehumidifiers
DeLonghi dehumidifier hose by drain tray leaking
I think that I am having the same problem, but I'm not sure that this tube needs to be plugging into anything. However, my humidifier seems to be draining out of this tube rather than from the tray into the bucket.
Jul 14, 2009 | DeLonghi Dehumidifiers
Delonghi pac 160 ( with air condition & dehumidifier modes) pINGU
i would like to know if the =unit turns off when it get to the tempature that you put it at
Mar 25, 2009 | DeLonghi DE500P Dehumidifier
Thanks
I went back and rechecked. If the fan mode is selected, you can only set the fan at one of the three speeds. If you leave it in the fan mode, the dehumidifier will not come on.
Once the fan speed is selected, it will run at that speed in the dehumidifier mode. The fan will keep running, even when the dehumidifier (compressor) shuts down.
The only way to get it to turn off is to use the clock setting, which either selects how long it stands-by before starting , or how long it will run before going back to stand-by. DeLonghi calls it "stand-by," we would call it "off." DeLonghi calls unplugged "off."
I've never turned mine to stand-by, because it will never get my entire house down to 30% humidity (I have it where my air handler returns air to the basement). I live in the greater DC Metro area, where 75% humidity is considered extremely dry.
Apparently the normal mode of operation is fan on unless awaiting a clock start, or encountering a clock shut-down; either condition puts it into the "stand-by" mode.
Sep 02, 2008 | DeLonghi DE500 Dehumidifier
Water bucket
If yours has a button/switch to turn on a pump, that will redirect the water to the drain. Sllee
Jun 28, 2008 | DeLonghi DH40P Dehumidifier
DeLonghi DH100P Dehumidifier Logo
63 people viewed this question
Top DeLonghi Dehumidifiers Experts
dennis lewis
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
