Question about Western Digital Computers & Internet
Western digital 3200aajs hard disk failure is imminent
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 43 Answers
This warning given from your SMART built into your hard drive. It is to be taken VERY seriously. You need to backup all your important data, Everything in My Documents, Pictures, Music etc. as soon as possible to another drive, either internal or external. This is a warning the drive WILL FAIL SOON. If you plane on cloning everything to another hard drive, do the backup FIRST because cloning is ******* the bad drive and can cause the failure to happen sooner. Good luck. Hope this helps..
Posted on Nov 04, 2012
zzptichka
  • 95 Answers
SOURCE: western digital passport problem
Here's a page with typical problems these drives have: http://datacent.com/datarecovery/hdd/western_digital/WDXML800UE
Posted on Nov 04, 2008
kamal1984
  • 1383 Answers
SOURCE: solve Bad sectors Problem?..????
irst connect your drive to computer then check its drive letter meand c: or d: or e:
then go to start > run> then type "cmd" then go to drive letter then type "chkdsk /r"
then it cheks your harddisk for eror.
Posted on Jun 09, 2009
  • 45 Answers
SOURCE: SMART failure predicted on hard disk 0:
There is a big problem with newer conponents and Win XP versions prior to SP2. Especially with newer motherboards.
You have to make a bootable SP2 disk if you don't already have one. To do this use the slipstream proceedure specified on the Ms website. Many other websites describe the process with easier language.
Slipstreaming is a common practice now. Essentially, you copy your original install disk to the c: drive then download SP2 to C: drive then download the slipstream utility from MS. Running the slipstream utility then inserts the proper drivers (ide and HD drivers too) into the licensed copy you have. You then create a bootable disk from the slipstreamed files you have.
This approach is resolving alot of blue STOP errors and SMART errors.
ALSO, you want to make sure you are installing any drivers provided by the MB manufacturer AND Drive maker.
Good Luck
Posted on Jul 29, 2009
  • 163 Answers
SOURCE: My western digital Passport 320Gb usb drive is not detected
U need to update windows XP , USB drivers will be installed
Posted on Dec 29, 2009
  • 17 Answers
SOURCE: get the message 'hard drive failure imminent
Have you tried turning off/on again your laptop?
If you did but still getting the same message am afraid you will have to replace the hard disk
Posted on Jan 04, 2010
Wdc wd800jd-75msa3 not reading disks
A Western Digital WD800JD-75MSA3 is a 80GB hard drive.
The usual cause of read failures of a DVD ROM is dirt in the device.
Try a cleaner disk.
Jan 21, 2014 | Western Digital WD800JD-75MSA3
Hard disk failure
Check if your hard drive is still in warranty period so you could ask for replacement from the manufacturer. Otherwise, simply buy a new hard drive and move all your data from the old one to the new drive.
SMART always predicts correct hard drive status and probably this time, you need to change it ASAP.
Hope it helps!!
Dec 07, 2012 | Western Digital WD Scorpio Blue WD2500BEVT...
SMART Failure Predicted on Hard Disk 0: WDC WD3200BEVT-75ZCT2-(S1) WARNING: Immediately back-up your data and replace your hard disk drive. A failure may be imminent. Press F1 to Continue
just means its time to backup all your information, as if the hard drive does fail theres a good chance you may lose some or all of your information.
hard drives aint that expensive around 30 pounds +
and you can replace it with any sata hard drive.
Jun 17, 2012 | Western Digital Computers & Internet
I have an ACER Aspire 5542 laptop and when I switch on I get the following message. "SMART Failure Predicted on Hard Disk 4 WARNING: Immediately back up your data and replace your hard disk drive....
Save your data asap and replace the drive it's failing. All drives fail over time you are lucky in that you are getting a notice. Others are not as fortunate.
Aug 30, 2011 | Western Digital (WD6400BEVT) 640 GB SATA...
I can not access my computer after imminent failure message
> imminent failure message ... cannot access
Bad luck that the 'imminent' failure was _SO_ soon followed by _complete_ failure.
Buy a new disk-drive. Disconnect the old disk-drive.
Install Windows to the new disk-drive.
Reconnect the old disk-drive, as a 'slave' disk-drive, and hope that you can access the files on it, even though you could no longer 'boot' Windows from it.
Oct 26, 2010 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Hi!im using a toshiba a210 laptop.i put it on some fews days ago it says "smart failure on hard disk 4-hitachi-(s1). warning:immediately back-up your data and replace your hard disk drive.a failure may...
Your drive is failing and you should back up any important data you need onto CD/DVD or an external USB device (hard drive/pen drive). The drive may keep working for a while but your system is warning you that it has detected a critical error with the drive and failure is imminent.
Jun 10, 2010 | Toshiba Satellite A215-S5822 Laptop
Get the message 'hard drive failure imminent
Jan 04, 2010 | Toshiba MK8025GAS 80 GB Hard Drive
How to fixs this
The hard drive is going bad cause it can't read the sectors properly.
Either get a known good workng hard drive in the computer or a brand new one and restore the computer back to factory defaults.
Aug 19, 2009 | HP Pavilion a1700n PC Desktop
SMART HARD DISK ERROR BACK
hi
SMART Hard Drive detects imminent failure. Your hard disk drive is detecting an imminent failure. To ensure no data loss, backup contents and replace this hard disk
Jyo
Jun 19, 2008 | Computers & Internet
Computers & Internet Logo
138 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
