Question about Refrigerators
Light bulbs keep blowing fisher and paykal fridge only
The light bulbs keep blowing in fridge [it is all fridge] after only a few weeks - on to our 5th one this year. Used 15w Phillips Tubualr screw in bulb
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
Check the door switch for a loose wire or short.
Posted on Nov 03, 2012
SOURCE: light bulb in FAB28 Fridge
Just squeeze the light cover and it should pop off forwards (ie. away from the fridge side.
Posted on Jul 06, 2008
  • 87 Answers
SOURCE: Smeg Fridge light
What you need to locate is the door switch mechanism for the fridge. These are normally located towards the top of the door and protrude so that when the door closes the switch is pushed in. To find out if you have a problem with the switch just press it when the door is open and the light should go off. The switch itself can appear in various forms either as a protruding rod or a curved plate which pushes upwards against the door side when it closes. If I could draw in this section it could be better explained. But if you look around the inside of the fridge on the side away from the door hinge then you should find something you can push. Sorry to be this vague. If you do need a replacement switch they are normally quite simple to change depending on where they are located, most are two screws, or just a push in type. Hope this has been of some help.
Posted on Jul 13, 2008
SOURCE: Fisher Paykel fridge door handle loose
Yes hello, I had the same problem - similar fridge model.  Mine was the fridge (not freezer) door handle ie. the upper door.  There are no small holes on the bottom of my fridge handle.  Working from the outer door edge, I gently prized loose the plastic trim located under the door.  I didn't take it completely off, just loosened about one quarter of the length, enough to flex the trim downward so that I could then access the phillips head screw that secures the fridge handle from the inside of the door.  The trim will prevent you from using a conventional screw driver to tighten the screw.  I used a screw driver bit which is only 25mm long.  It has an hexagonal end to which I applied a small spanner and voila - the handle is once more secure.  Good luck.
Posted on Nov 15, 2008
SOURCE: I used a GE Helical
You should use a standard 40 watt appliance bulb (usually clear). The life of compact florescent bulbs is greatly shortened by turning it on and off frequently. They work best being left on for 15 minutes or longer. Cold temperatures can also shorten bulb life as well.
Posted on Dec 29, 2008
kel1guy2002
  • 3740 Answers
SOURCE: LG refrigerator GR-B258jvc - replacing light bulb
There are usually 3 or 4 locking tabs on the cover that just need to be pressed INDIVIDUALLY toward the bulb to release them and then carefully remove the cover. The ones with 3 tabs usually have and upper and lower tab then the thrid tab is on the side. Removed the upper and lower tabs by pressing inward to the bulb and then the cover will pivot out on the 3rd SIDE tab.
Thanks for using FixYa.
Kelly
Posted on Apr 09, 2010
Fisher and pykal all fridge beeps all the time, the bulb was blown, taken out (no spare at home). Will the fridge continue to work without a bulb
If you're talking about the light that goes on when you open the door, then yes It will. The light bulb has no effect on the operation of the refrigerator.
Feb 15, 2017 | Fisher Refrigerators
Fisher & paykel active smart fridge not keeping cold
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 28, 2012 | Fisher and Paykel Active Smart E522B...
Fisher paykal cooker
There is a fault with the wiring or the element. The fault started as a short circuit but has now blown itself clear to an 'open circuit' (a break). Check the element and associated wiring. I doubt the thermistat is to blame. Cheers
May 01, 2012 | Fisher and Paykel Kitchen Ranges
The oven won't turn on. We are unable to set the clock either. The display flickers but doesn't display.
There are lots of different timers on fisher and paykal The last one I reset was a few weeks ago it involves pressing 2 buttons at the same time I think it was the oven on and oven off buttons but I am not sure You will know when you have pressed the right 2 buttons the display will stop flickering set the clock time using the up down arrow buttons The auto light should not be on if it is press the manual button Regards Geoff Stove Recyclers
May 29, 2011 | Fisher Ovens
Fisher Paykal GWL-11 won't advance through cycles. Could this be
maybe blocked drain pump can u hear a buzzing when it tries to drain water
Oct 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel Model #E522BRX Fridge portion not working but Freezer OK
Hope I'm not too late - I had EXACTLY the same problem and the freezer fan wire was broken. I fixed it an documented everything in http://www.accentis.com.au/downloads/misc/How I fixed my Fisher and Paykel Fridge Active Smart Fridge.pdf. Good luck.
Aug 14, 2008 | Fisher and Paykel Active Smart E522B...
Refrigerators Logo
200 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
