Question about Brother IntelliFAX 2800 Laser Fax
Answering fax doesn't receive my fax
The answering phone fax picks up, but my fax does not go through.
    Champion:
  • 320 Answers
You need to go into the menu set up where ut says easy receive and hit the set button or menu and then try and have some one fax you something
Posted on Jan 16, 2009
How to recieve a fax ?
If your printer is connected to a modem make sure that the port has a dial tone. To check for dial tone, try to plug in a phone to the same port that you printer is connected to. If it doesn't have dial tone, you might want to check with your phone provider. Or you can plug in the printer straight to a wall jack.
Once the printer is connected to a line that has dial tone, you can then setup the printer to receive faxes. To set it up, on the control panel of your printer, press on Setup > Fax Setup > Ringing and Answering.
If you have an answering machine, set your printer to pick up 3 rings higher than your answering machine. If not, set it to pick up on the 5th ring that way you will still have time to pick up the phone if it's a voice call.
If you have a voicemail service from your phone provider, you'll need to contact your phone provider to get a distinctive ring feature. Once you'll have that feature, you can assign a distinctive ring to your printer. You can find that under Fax Setup > Ringing and Answering > Ring Pattern.
May 29, 2012 | Lexmark Interpret S405 Wireless All-in-One...
How do I tell my 2820 to prepare to receive an incoming fax? My phone line and my fax line are the same number. It continues to ring but the fax machine is not answering. I have also turned the answering...
To have the machine answer faxes and record voice messages unattended change the answering mode to message centre. If you are home and pick up the phone , but it is a fax, not a phone call push *91 on the phone you answered on, and hang-up the phone. the fax machine will tyhen start receiving.
Dec 27, 2010 | Brother IntelliFax-2820 Laser Fax
Can send but not receive faxes.
Fax machines won't work reliably on a digital phone line.
Feb 02, 2009 | Office Equipment & Supplies
Fax answer phone line
You set the machine up in the answer/fax mode, when a fax is coming in you have to press 9 on the phone to make it receive the fax if you pick up the receiver when it is a fax call.
You can also change the number of rings to answer a fax, I think the max is 7 rings.
Dec 20, 2008 | Xerox WorkCentre Pro 412 All-In-One Laser...
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
How to receive faxes automatically
First this is a good machine, I use the same one and have my fax setup for the same thing. If you have a (TAD) Telephone Answering Device first you have to set up your phone to pick up before the fax, do this by setting the phone to pick up on three rings and the fax to pick up on four. Go to Menu/Fax/Setup Receive/Ring Delay. While there make sure Easy Receive is on. The machine itself will distinguish between regular calls and facsimiles and will display this info at the time of the call on its LCD screen, make sure you are using the line connection and not the phone connection. Hope this helped.
Jul 01, 2008 | Brother MultiFunction Center MFC-440CN...
VOICE MAIL AND FAX
The short answer is no. The JX200 will work with an answering machine because it "listens in" when the answering machine picks up a call. It can't "listen in" to voice mail, because the voice mail is handled by your phone service.
Mar 29, 2008 | Canon FAX-JX200
Auto-answer issue: fax beeps on line when voicecall received
Try changing the receive mode from automatic to FAX ONLY and set the number of fax rings higher. You should be able to receive phone calls and if you are not answering your phone it will automatically receive a fax.
Mar 27, 2008 | Office Equipment & Supplies
MP730 fax issue-can't receive fax, but can send out
I think I know why. You need to set the proper priority of your all-in-one Canon device.
If it is TEL priority, it means you need to have a phone connected to the fax. If the phone rings, you need to pick up the handset and check if it's a fax tone or a call. If it is fax tone, you wait for 5 secs til fax tone stops, and then hang up. After that you will receive the fax. Failure to pick up the handset will not allow you to receive the fax. This might be the most probable setting you have, hence you can't receive the fax.
If it is FAX priority, the same thing happens as TEL priority. Only difference is if you don't pick up, and it is a fax, it will still receive.
You can also do FAX only. No need to connect a phone. Device will receive automatically.
-Acieboy
Sep 21, 2007 | Canon MultiPASS MP730 All-In-One InkJet...
Brother IntelliFAX 2800 Laser Fax Logo
42 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
