Hi there. When talking about USB 3.0. Can say say that there is a USB 3.0 hard drive? Or can I say that if I have an external USB 3.0 hard drive case and place a hard drive in it it would have the USB
  • 32,281 Answers
USB 3 has the fastest data transfer speed through a computer with USB 3 port. If your computer does not support USB 3 then it cannot transfer data at USB 3 speeds.
If you install a hard drive into an USB 3 hard drive adapter case and the data transfer speed would depend how fast a hard drive you install in this USB 3 adapter case.
A SATA hard drive is faster than an IDE/PATA hard drive. Make sure you get the correct USB hard drive adapter case with the SATA or IDE/PATA connector that matches the hard drive.
Posted on Nov 03, 2012
Pyrhyc
  • 2028 Answers
SOURCE: USB DEVICE NOT WORKING
With some external hard drives, the usb port doesn't carry enough power to run it properly, especially with thw newer externals. Does it give you an error message?
Posted on Jul 11, 2008
jaymac007
  • 42 Answers
SOURCE: USB drive problem
I had a client with this same issue. However, her issue was that the top left USB port would only accept flash drives. Your external harddrive is probably not getting enough power from your USB port. Try using two USB ports (you can get a connector for this) to power up the external harddrive.
Posted on Jul 08, 2009
JaxPlanet
  • 922 Answers
SOURCE: usb does not recognise external hard drive
Your drive is being recognized. However, your computer only has USB 1.1 so you are being notified that USB 2.0 is faster. This message is FYI and will not prevent you from accessing the drive.
After you see that message you should see your external drive in "My Computer" If you don't see the drive you probably need to assign an available drive letter to drive.
Open Windows Help and Support.
Search for "drive letters" and find "assigning drive letters"
This will walk you through the process.
If this helps, please vote for my solution.
Posted on Oct 05, 2009
  • 21 Answers
SOURCE: I purchased a Western Digital
I have the same problem with my laptop. Here is my understanding of the problem.
Many laptops have a BIOS limit of 128GB hard drive capacity.
Try to find the latest BIOS available for the laptop, and see if it supports 48-bit LBA addressing of the hard drive.
If the BIOS only supports 24-bit LBA addressing, there are tools to restrict the size of the drive.
DISCLAIMER: I have read of Dynamic Drive Overlay (or Drive Dynamic Overlay) software, which is supposed to allow for the use of larger drives. I have not used one, so I do not know how well they work. I am sure they slow down access and, from what I have read, they do not work with Vista or Windows 7.
Posted on Dec 11, 2009
SOURCE: I have HITACHI hard drive model HTS541680J9SA00 i
Your HDD cannot start due to insufficient power. If you search for specs, you'll find out that your HDD needs 5W in start-up/peak - 1000mA at 5V. Your standard PC USB port will only supply 500mA, so you need to find an alternative power supply (if your enclosure came with such a thing), or better, find a 2xUSB cable , like this one (no publicity intended): http://www.lindy-usa.com/usb-cable-dual-power-2-x-type-a-to-mini-b-usb-2-1m/31780.html . PS I know it's a rather old topic, but I recently faced the same problem and I hope this will help those in need.
Posted on Apr 28, 2010
Western Digital 1TB My Passport Essential SE USB 3.0 Portable External, WDBACX0010BBKSN USB 2.0 Hard Drive not recognised
Hi there. Here are some solutions you could try 1. Try connecting it with a different USB cable as the present one may be faulty. 2. If you can open the casing, do so to confirm if there is a loose connection. 3. You can try this great application tool from Seagate called Sea Tool. You will need to download and install on your computer. This tool examines you hard drive and lets you know if it is totally damaged. You can download it here. SEATOOL
Sep 06, 2011 | Western Digital 1TB My Passport Essential...
Hi, I am trying to work out what kind of connector I need for my old HHD's (I have 2) I am thinking of buying an outside casing so that I can transfer my old data from these two drives to my current HDD,...
Hi. Thanks for your question.
Your Hard drives connection type is IDE. You can but adapter for your hard drives to connect them via USB port to your current machine. This is link to one of adapters like this on ebay so you can have a look at what I mean http://cgi.ebay.com/USB-2-0-IDE-SATA-S-ATA-2-5-3-5-5-25-Adapter-Cable-/280501660830?pt=LH_DefaultDomain_0&hash=item414f33ac9e#ht_3091wt_1139
Buying adapter like this would mean that you could still use your drives and keep files on them. Use them as external drives. Only connect when you need them. I hope this helped you. Please do not hesitate to ask more questions if this is needed.
Dec 06, 2010 | Samsung SpinPoint V60 SV0813H 80 GB...
Hi there i hav ea maxtor onetouch 4 mini 120 gb.
Remove the hard drive from the Maxtor case, purchase an USB hard drive adapter case, and install the hard drive inside this case. Then you can connect this to the computer's USB port and if the hard drive is OK then this computer will detect it as an external USB hard drive, then you can open the folders and files and back them up.
Jun 29, 2010 | Maxtor OneTouch 4 Mini 120GB External USB...
Internal 320 hard drive into external
If you got a USB casing for that, it would have come with a USB and power cable. Yes, power too!
Plug the power, and make sure you have a USB 2.0 hi-speed port. Also check "computer management" and check the hard disk works.
May 24, 2010 | Western Digital (WD3200JS) 320 GB Hard...
When i connect my wd 1tb hard drive i get usb device not recognised plz help
Hi sexybarneygu, Assuming you have tried other USB ports getting the same problem, I recommend you return it (if it's under warranty) if not, remove the Hard Drvie from the casing and connect it to another computer internally (I dont want you to get another external case for you Hard drive because you hard drive MIGHT be the one with the problem and you cant fix it (you can't fix hard drives, just work around it in order to get your data back and then trow it away). If the other computer sees your hard drive ok, then go buy an external case and install your hard drive there. make sure it's the same interface - most likely SATA interface. I'm 80% sure it's just the casing not the hard drive. Don't forget to rate if my answer helped you. Thank you :D
Apr 28, 2010 | Western Digital My Book Essential 1TB...
Hi ,my name is sameer i have 120gb lacie external hard disk,but is not suporting usb cable how can i change case pls help.............
just open your external HDD case, look for the connector (SATA or IDE), so buy new external harddisk case according the connector type.
Dec 20, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
I want to make an internal western digital 160GB drive from my imac g5 20" into an external drive and need to figure out what enclosure and cables i will need
You need the following
http://cgi.ebay.co.uk/External-USB-2-0-2-5-SATA-HDD-Hard-Disk-Case-Enclosure_W0QQitemZ320419271720QQcmdZViewItemQQptZUK_Collectables_HardDriveEnclosures_RL?hash=item4a9a7a1428&_trksid=p3286.c0.m14
http://cgi.ebay.co.uk/3-5-IDE-Aluminum-Hard-Drive-HDD-HD-External-Enclosure_W0QQitemZ400070866376QQcmdZViewItemQQptZLH_DefaultDomain_3?hash=item5d2614f5c8&_trksid=p3286.c0.m14
http://cgi.ebay.co.uk/New-3-5-USB-2-0-External-Hard-Drive-Case-HDD-Enclosure_W0QQitemZ170377549189QQcmdZViewItemQQptZUK_Collectables_HardDriveEnclosures_RL?hash=item27ab4b1585&_trksid=p3286.c0.m14
Please note the links are an example only.
Sep 02, 2009 | Western Digital Caviar WD1600 (1600YD) 160...
USB port broken in 1TB seagate Freeagent external hard drive
This listing (260320213027) has been removed, or this item is not available.
IS THERE ANOTHER SITE THAT WILL FIT MY SEAGATE EXTERNAL HARD DRIVE, 1TB?
Feb 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Can my Vantec NexStar 3 Hard drive SAVE?
You might want to take the drive out of the case and use and external drive connector to see if the drive still works.
https://www.amazon.com/Drive-Adapter-Converter-Optical-External/dp/B002OV1VJW
Sep 02, 2017 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Samsung SP0802N External Case?
Hi, try this. This will work with your HD. 2.5"/3.5" EN391-S2HC USB 2.0/eSATA SATA HDD Dock w/Card Reader & Hub
Dec 12, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
