Loose wire yellow wire marked oo or dd is floating loose at back of timer, cannot find a terminal with this code, or is it off the capacitor ? washer behaves erratically
    Sergeant:
  • 264 Answers
The capacitor should have two wires on one end and two wires on the other end look for a piggy back spade thats where two wires fit on one spade ok get back to me if you still need help ok make sure the machine is off be for doing any thing ok
Posted on Nov 03, 2012
2 Suggested Answers
Cyril J
  • 45 Answers
SOURCE: maytag 2 speed replacement motor
you may have wrong part , post model serial , and part number that you have i will look them up
Posted on May 16, 2008
Connecting replacement fan motor in HP condenser
What is the model number of the heat pump? What is the voltage that you are dealing with?
Nov 26, 2013 | Carrier Heating & Cooling
Im trying to change out my automatic sprikler timer, the new one is Intermatic model T8845PV. Its an old house I have two hot wires going in to the old timer, and I only see one spot for my hot wire in the...
Open following links for resources:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
http://waterheatertimer.org/images/T8845PV-image-700.jpg
If you have 2 hot wires, then you have 240Volt circuit from breaker box.
T8845PV is 120Volt timer.
How to wire for 120Volt: Use one hot wire to connect to LINE terminal. Cap off other hot wire. Then connect bare ground wire to terminal marked NEUTRAL.
This is not code, but it will work until you have time to run 120Volt line from nearby 120Volt outlet.
Read about 120 and 240Volt circuits
http://waterheatertimer.org/B220C.html
T8845PV is 120Volt timer, made to control 24Volt sprinkler valve.
Inside the timer, there are two wiring terminals marked LINE and NEUTRAL
120Volt cable from circuit breaker has black hot wire and white neutral wire.
Connect black hot to terminal marked LINE
Connect white neutral to terminal marked NEUTRAL
The yellow wires are 24Volt output.
Yellow wires connect to sprinkler valve.
Do not connect 120Volt to yellow wires.
This timer does not have terminals for rain sensor:
http://waterheatertimer.org/pdf/How-to-Set-and-Troubleshoot-Intermatic-sprinkler-timer.pdf
Jul 31, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
I have a Ruud Air Conditioner and need to install a new capacitor, but I forgot how the wires were on the old one. Can you help me in tellilng me which wire goes where.
There should be 3 terminals on the capacitor marked "C" "F" and "H".
A wire from the high voltage contactor goes to the "C".
Another wire from "C" goes to the compressor.
These wires are usually red.
The "F" terminal has a wire going to the fan,usually a brown wire.
The "H" has a wire going to the compressor,usually yellow.
There should be a wiring diagram on the control box cover identifying the terminals,colors and number of wires.
Jul 25, 2011 | Heating & Cooling
Doesn't fill with water. Removed inlet valve and it tested good. Float works but limit switch seems not to get power. Don't know what to do next.
Hi and welcome to FixYa. I am Kelly. Power for the water valve comes from terminal 4 of the timer to the float switch through the water valve and then to the door switch before reaching L2 of the power source.
See the wiring data here:
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28467492&pkw_=basket&model_id=5170507&NewWindow=1
Check for power on Terminal 4 (marked AQ) of the timer. (No power.... most likely a door switch problem) The rest of the circuit you can read continity. You should read continuity from AQ of the timer to one terminal of the power source with the door closed and latched.
If you need more assistance just respond here and I will help you.
Thanks for choosing FixYa,
Kelly
Dec 08, 2010 | Maytag 24 in. MDB3700 Built-in Dishwasher
NEED WIRING INSTRUCTION FOR CAPACITOR FOR
On top of the capacitor you will find the terminals marked. One will say C, or Com. The others will be marked fan and herm. There will be a hot wire going to C. Usually this comes of the top of the contactor and is red. Find the wire that runs to the compressor. It will likely be yellow. This will hook to the Herm. Next find the fan wire (probably brown) it will hook to the fan. Hope this helps.
Jul 13, 2010 | Heating & Cooling
How do I wire a new condensor fan motor to the new capacitor? The old capacitor is longer and it has 3 terminals. the new capacitor is much smaller and oval. It has 2 terminals. the fan motor has 3 wires,...
Before attempting any of these recommendations, First disconnect all the power sources and check your wiring diagrams on the motor and condensing unit.
On the old capacitor if you look on the top near each of the three terminals. Are they marked, fan - C - herm? If they are that is a dual capacitor and that needs to stay because that is also your compressor capacitor.
The Red wire from the conductor is Run and it's connected to C on the old capacitor.
Follow the Yellow wire and see if it goes to the S or start terminal on the compressor, if it does then that is the Start wire for your compressor and it connects to herm on the capacitor.
For the fan motor a lot of times the wiring connections are printed on the motor label.
Check the label, Purple should be run and connect to C on the old capacitor.
Black should be Common and it connects to the opposite side of the contactor as the Red wire. If the Red wire connects to T1 then the Black wire connects to T2.
The Brown wire shoud be the start wire on the fan motor and it connects to the Fan terminal on the old capacitor.
Now if you want to use the new fan capacitor. Take the Purple wire from the motor and look for any marks (red paint or a dash) on or beside the terminals on the new capacitor. If there is an identifying mark then connect the Purple wire to that terminal, if no marks you can connect it to either terminal. Then you need a jumper wire from C on the old capacitor to the purple side of the new capacitor. Then take the brown wire and connect it to opposite terminal of the new capacitor.
Apr 05, 2010 | Heating & Cooling
Installing hard start capacitor
Hi, welcome to fixya. Color coding is not universal so we can't go strictly by that. You want to look at the top of the run capacitor and connect the two leads to the terminals marked C or common and the one marked comp. Be sure not to connect to the terminal marked F or fan. I hope this helped. Please don't forget to return and give me a fixya rating.
Feb 09, 2009 | Intertherm P3RC-042K Air Conditioner
HELP!!! Help wiring new motor for CKL60-1
  1. This is what your wiring should look like if you are using two caps. then you should be using a potential relay as well. This is the diagram for using a potential relay. Hope it helps you.
Aug 25, 2008 | Goodman CKL60AR60 Air Conditioner
Wiring compressor
The two terminal cap is only for the new fan motor. Connect the compressor wire back where you found it, on the 3 terminal cap. It's the terminal marked, "herm". The "common" terminal on the 3 terminal cap must still be connected to one side of the 220 power at the contactor. One side of the 220 goes to the common on the compressor. The other side of the 220 goes to the run winding on the compressor AND the common terminal on the 3 terminal capacitor.
Jul 18, 2008 | Carrier 38CKC036 Air Conditioner
New Timer--New Problem
Sound like you connected the timer up wrong, from my drawing check the following connections to the timer.
terminal 12 & 26 - Black (linked) mains supply
terminal 17 yellow/red (from rinse switch)
terminal 28 grey (from water level switch)
terminal 15 light blue (advance rinse switch water level switch)
terminal 27 brown (door switch)
terminal 25 brown (door switch)
terminal 62 green/black (motor)
terminal 7 red (motor)
terminal 32 yellow (motor)
terminal 9 blue (capacitor /motor)
terminal 8 white/yellow (motor) and white (water solenoids hot and cold)
terminal 71 pink (water selector switch and hot solenoid)
terminla 72 purple (water selector switch and cold solenoid)
terminal 70 white/blue (water selector switch)
Watch the light blue wires as there are several of them!!
Dec 12, 2006 | Admiral AW22 Top Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
