Question about York Sport & Outdoor - Others
I have a York Pacer 352i Treadmill that comes up with err 1 it has a main fuse on the circuit board that has blown what size fuse do i replace it with the old fuse has no size on it
Fuse size for York Pacer 352i
SOURCE: speed problem
There is a rotating handle to the right of the display panel that you need to turn clockwise to slow down and anitclockwise to speed up, this is the only speed control. Turn it all the way and it will start at the slowest speed about 4kph. Good luck
Posted on Feb 15, 2009
SOURCE: the digital display on my york pacer 2750 treadmill does not work
Try the York help desk the No is 01327701824 or get back to me at alxndrcv@talktalk.net and I will copy mine for you and send it on to you
Regards
Alex
Posted on Mar 07, 2010
maxtreadmill
  • 832 Answers
SOURCE: where is the circuit breaker or fuse message err 1
That error code mean you motor is not getting the correct signal to operate the drive motor. You will need unplug unit then take the motor shroud off visually inspect all connectors then make sure all of them are seating solid in their connectors. then plug the unit in check an see if the L E Ds have lit on lower electronics board then get on unit and with your foot proceed to move the belt while doing that hit your start button and see if that error code come up. At this point we are checking the speed sensor to see if it is functional. Now if your upper console is registering its showing speed and time moving forward this also tells us that the communication between the two boards are fine. Now stop this process and you should have the error 1 show on the console. If you have a multi meter handy find the two leads coming form the motor going to the board unplug them put the two leads into the connector switch the meter to dcv 100v range and proceed to move the belt in the previous now the motor has become a generator and if function you should be getting a dcv output if not the it telling either worn motor brushes or open winding in the motor now if you get a reading then that lower board is defective. Then call York and get pricing on the defective part.
Posted on Apr 11, 2010
SOURCE: i have a york pacer 3100 treadmill and the
ONCE YOU HAVE SET JUST PRESS START
Posted on Oct 18, 2011
  • 71 Answers
SOURCE: Fuse keeps blowing
There's s short circuit somewhere in the device.
Posted on Jul 27, 2012
Fuse is blown = need to replace, what type of fuse should I use
How to Change Treadmill Fuses ' LIVESTRONG.COM
www.livestrong.com > Sports and Fitness
Sep 29, 2015 - If the fuse on your treadmill has blown, it's time to replace it. ... Thetreadmill fuses are located inside the elevation motor. If you don't have the ...
Treadmill blowing fuse. ' All About Circuits
forum.allaboutcircuits.com > ... > Electronics > General Electronics Chat
Sep 1, 2014 - I have recently picked up a second hand treadmill with an issue (York Challenger ... If I unplug the motor from the control board it will not blow the fuse, and will give ... Not sure yet, but i'll replace the IGBT's/power mosfet (I still don't know whats ... Treadmill goes high speed then blows the fuse
Nov 25, 2015
Treadmill blows fuse as soon as it starts
Sep 29, 2015
treadmill motor controller problem?
Aug 25, 2012
Treadmill Controller - No power to motor
Feb 11, 2012
More results from forum.allaboutcircuits.com
Jan 20, 2016 | Exercise & Fitness
My York Pacer 3500 Treadmill switched on then every time I used it the fuse blew. Its happened almost 5 times.
see the block diagram attached.
1) you must test the power cord for short wires.
2) test the power switch for short.
3) test coil for shot
4) test capacito for short.
5) the main motor board can be faulty
In short you must disconnecat every wires , and isolated the short for to avoid the fuse blown.
Otherwise you must call some service tech, from your supplier company.
God bless you
Jun 29, 2012 | York Exercise & Fitness
Treadmill issue: Have a York fitness pacer 3700 that does not go and an error 1 comes on after 4 seconds, prior to this it starts up normally and the display is zeroed. Any ideas?
Adjust the speed sensor, clean, and tight the wire connector very well.
see the diagram attached.
2) Test the input voltage motor, if there are the motor need repair.
3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
sincerely. God bless you
Apr 19, 2012 | York Exercise & Fitness
I have a treadmill york barbell max series 2, keeps displaying err in the speed window and wont start up at all, sometimes it will start working and then sometimes it wont and err comes up again
1) You have out of adjustment the sensor reed switch,see the schematic.by 1/8" or 3mms aprox.
2) With this you will fix it.
3) However if the problem persist, you must check if the display board is o.k or faulty.
4) Test the 5VDC for IC( Including EPROM, ROM,etc) Tight flexible cable for Display Board vs Lower Board(Main Controller Board).
5) Since the Lower Board send the Power Supply coming from the Transforme you must Test it, and then power supply for +5Vdc.
6) You must have Strong Conclusion if the problem is Upper Board or Lower Board(Main Controller Board) .
Finally The Lower Board Control 90% functions of the Treadmills.
Nov 23, 2011 | York Barbell Home Use Fold-Up Treadmill
Cannot change speed up on york pacer 27650
1) Check it the speed sensor.
2) Watch if the connector is loose or bad contact.
3) Corroded contact( clean with special spray for contact)
4) Replace Speed Sensor.
May 24, 2011 | York Barbell Home Use Fold-Up Treadmill
I lost my manual for the York Pacer 3100, where can I download the manual? I also need to replace the running mat but I don't know the part number.
Try this 3 web page:
1) Free. http://fitness.manualsonline.com
2) Pay:www.fitnessrepairparts.com
3) Pay: http://manualsfactory.com
e.cuadra
Where is the circuit breaker or fuse message err 1
Apr 11, 2010 | York Barbell Home Use Fold-Up Treadmill
How i replace my york pacer 2750 safety key
I have misplaced my safety key for my York Pacer 2750 Treadmill and can no longer use it. Please help me find a replcement soon. The company York Fitness no longer do this model and don't have the parts either. Help....
Nov 28, 2009 | York Exercise & Fitness
My york treadmill pacer 3700 show error
I have just got a pacer 3700 off a friend and she had no manual for it. it keeps saying error 1 and wont do anything. what can i do to make it run again?
Oct 27, 2009 | York Exercise & Fitness
Sport & Outdoor - Others Logo
Top York Sport & Outdoor - Others Experts
Paul Carew
Shehu Pro
Shehu Pro
ray gallant
Are you a York Sport and Outdoor - Other Expert? Answer questions, earn points and help others
