Question about York Barbell Home Use Fold-Up Treadmill
Pacer 352i main fuse
Treadmill comes up err 1 tested the main fuse and it has blown what size fuse do I need
4 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: where is the circuit breaker or fuse message err 1
That error code mean you motor is not getting the correct signal to operate the drive motor. You will need unplug unit then take the motor shroud off visually inspect all connectors then make sure all of them are seating solid in their connectors. then plug the unit in check an see if the L E Ds have lit on lower electronics board then get on unit and with your foot proceed to move the belt while doing that hit your start button and see if that error code come up. At this point we are checking the speed sensor to see if it is functional. Now if your upper console is registering its showing speed and time moving forward this also tells us that the communication between the two boards are fine. Now stop this process and you should have the error 1 show on the console. If you have a multi meter handy find the two leads coming form the motor going to the board unplug them put the two leads into the connector switch the meter to dcv 100v range and proceed to move the belt in the previous now the motor has become a generator and if function you should be getting a dcv output if not the it telling either worn motor brushes or open winding in the motor now if you get a reading then that lower board is defective. Then call York and get pricing on the defective part.
Posted on Apr 11, 2010
maxtreadmill
  • 832 Answers
SOURCE: need a running belt for a York Pacer 3100
Technical Support & Spare Parts OrderingCall: 01327 701824
Email: helpdesk@yorkfitness.co.uk
Opening Times: 9am-4pm Monday-Friday
Posted on Apr 24, 2010
maxtreadmill
  • 832 Answers
SOURCE: Treadmill belt
I have kettler pacer treadmill it is not getting start,when I press start button the display shows system fault and also shows error dc6
Motor controller...these are typically motors that have speed controllers. When they fail, just test and replace. Call the manufacturer for parts.
Nov 25, 2014 | Kettler treadmill Pacer
Treadmill blowing electrics when switched on
Step 1:
1) please use desk lamp and connect in outlet wall, where the treadmill is connected.
2) if the breaker or fuse is blown, the problem is the outlet wall.
3) Test the wire ground with DVOM, if there are touching with another wires inside of the outlet
4) test the another wires white + black, if there are touching, or there connecting with the carcase from the outlet and repair.
Step 2:
1) if the problem if the machine: please test the power cord use the DVOM for continuity
see the video for measure continuity
2) test the main switch from treadmill
3) test the reset switch for continuity
4) test the fuse +c.breaker for faulty with contunuity and repair
5) test the power supply continuit see the block diagram
Step 3:
please test the main motor for open or faulty see my personal TIPS for motor help.
2) test the output main board , for input voltage motor, if there are NOT the board is faulty,replace the boaatd use the DVOM for measure Voltage.
use the diagram above mentioned.
Jan 07, 2013 | Exercise & Fitness
Treadmill KETTLER PACER error code E7, what I have to do?
see the next steps and fix it. God bless you
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Nov 28, 2012 | Kettler treadmill Pacer
Treadmill KETTLER PACER have error E7 when starting run. How to eliminate it?
see the following indications and fix it. God bless you
ERROR CODE # 7
2)Alternative:
Cannot turn on proform 380 cs treadmill
1) test the outlet wall with a desklamp, if the lamp turn On THE circuit is o.k otherwise, the problem is fuse blown or c. breaker tripped, reset or replace fuse.
2) test the power cord for open or faulty. with VOM usin continuity
3) test the fuse y/o c.breaker inside of machine and reset or replace.
4) Turn on the machine if the machine keep the same simpton, test the key(magnet) the key is a magnet, test vs your magnet from seal magnet of your refrigerator for atraction or repulsion, if doesnot pass the test replace the magnet from some hardware like home depot.
and PROOF again, can be work. see the block,
Otherwise if the problem keep you must call some tech profesional, maybe you have Main switch open or defective and need replace, or power supply, capacitor, transformer, etc defective. or faulty.
God bless you
Sep 20, 2012 | Proform 380 CS Treadmill !
785pi
1) test the outlet wall, put some desk lamp, and see if turn ON the light, is does the circuit is o.k if NOT the circuite is missing , Reset The c.breaker from your house or replace the blown fuse.
2) if everything is o.k, turn ON the treadmill, if does work test the fuse blown y/o reset the c.breaker see the block diagram +diagram
3) test the main switch for loose wires, or bad contacts, or faulty swithc.
4) see any wires loose, maybe broken, or break, tight very well, see if some animal byte some wires connector. repair and TURN ON again.
5) adjust the REED switch, see the diagram clean it, tight the wires connector well.
Try again. God bless lyou
Jul 29, 2012 | NordicTrack Treadmill
Treadmill will not come on
1) reset the c.breaker from your home or blown fuse and repair
2) test the power cord for open or break with DVOM OR VOM very important
3) reset the treadmill with the switch
4) open the treadmill and see the fuse blown and repair or c.breaker and reset.
5) LUBE the deck belt , this happen because the lack of maintenance produce enough friction between deck vs deck belt.
6) lube the rollers bearing too.
7) test the input voltage motor, if there are the motor need repair.
8) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram.
God bless you
Jul 11, 2012 | Proform 580 LT Treadmill
My York Pacer 3500 Treadmill switched on then every time I used it the fuse blew. Its happened almost 5 times.
see the block diagram attached.
1) you must test the power cord for short wires.
2) test the power switch for short.
3) test coil for shot
4) test capacito for short.
5) the main motor board can be faulty
In short you must disconnecat every wires , and isolated the short for to avoid the fuse blown.
Otherwise you must call some service tech, from your supplier company.
God bless you
Jun 29, 2012 | York Exercise & Fitness
EPIC TL 2200 wont start
1) Test the fuse or c. breaker see the diagram attached.
2) Test the c. breaker from your hourse, or blown fuse
3) Test the main switch of the treadmill see how to do it
4) Test the voltage input motor, if there are voltage the motor need repair.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Jun 08, 2012 | Epic Exercise & Fitness
I have a treadmill york barbell max series 2, keeps displaying err in the speed window and wont start up at all, sometimes it will start working and then sometimes it wont and err comes up again
1) You have out of adjustment the sensor reed switch,see the schematic.by 1/8" or 3mms aprox.
2) With this you will fix it.
3) However if the problem persist, you must check if the display board is o.k or faulty.
4) Test the 5VDC for IC( Including EPROM, ROM,etc) Tight flexible cable for Display Board vs Lower Board(Main Controller Board).
5) Since the Lower Board send the Power Supply coming from the Transforme you must Test it, and then power supply for +5Vdc.
6) You must have Strong Conclusion if the problem is Upper Board or Lower Board(Main Controller Board) .
Finally The Lower Board Control 90% functions of the Treadmills.
Nov 23, 2011 | York Barbell Home Use Fold-Up Treadmill
York Barbell  Home Use Fold-Up Treadmill Logo
75 people viewed this question
Top York Exercise & Fitness Experts
William McDowell
richie46
Are you a York Exercise and Fitnes Expert? Answer questions, earn points and help others
