Question about Sharp 21B-S10 21" TV
What is the common cost of sharp tv when quecly tornoff
When i oppen thy have an standby power but contineo to oppen it
    Top Expert:
  • Sharp Master
  • 14,553 Answers
Not sure what issue is: it turns on then quickly off?
short in power supply or more commonly in the high voltage area---bad solder connections (age of set does not matter) are also very common.
Posted on Nov 03, 2012
Sharp TV struck by lighting replaced all boards got standby light could the led lights be fried and keeping TV from powering up
There is a row of LED lights that are called the "Backlight" and if there is just one LED burned out, the cost of replacing the back light strip will either meet or exceed the cost of the TV. I have worked on several TVs and they ALL had the same issue.
You might luck out and find a repair shop in your town\city that knows about this issue and can go in and replace that LED strip( it carries 25+LEDs in a single row) or just replace the burned out LED(s) without costing you more than what you paid for the TV.
Hope this helps.
Aug 14, 2017 | Sharp Televison & Video
How do I turn off standby mode on a Sony XBR television?
Here's how, but it will cost you in life expectancy of your TV set. Standby costs a bit of energy but prevents cold components getting a sharp smack of power surge and also lessens amount of heating components are subjected to during start up.
How to Shut Power Saver Off on Sony Bravia
Apr 27, 2015 | Sony Televison & Video
My tv doesnt work. the red standby keeps on blinking. what seems to be the problem?
thi; when you LCD TV wont start , even if you press the power button , it has a power supply failure, maybe some capacitor ha bloated or change the value, try to watch this http://www.youtube.com if you know how to solder, or even disassemble the back of LCD TV. if not try to call a repair technician. thanks ,, hope this help.........
Sep 03, 2011 | Sharp LC-32SB24U 32 in. LCD TV
Tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light position...
tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light
Aug 30, 2011 | Sharp 21" Multi System Stereo TV
It's sharp 52 inch lcd tv. Model is 52SB55U. I could not turn on the tv. There is no backlight, and only the power and opc indicator are blinking. I tried the factory reset, it didnt work. It could be...
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out power transistor and zener diode...if otherwise, Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem....
Jun 23, 2011 | Sharp LC-C5255U 52 in. LCD TV
Sharp tv 20V-L80M standby only
If not power up even by remote control then check the the H-out transistor for short, open fusible resistor in line with the b+. This is the most common fault of your problem.
Needs a technician to isolate the problem.
Thanks for using fixya.
Jan 23, 2011 | Sharp Televison & Video
Sharp aquos won't turn on
Any indicator lights on, if it is then you only have the standby 5v circuit working, you will need to have the power supply check out first, that is a starting point.
Oct 30, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp agous .. no power
I have same problem, In Caribean and repairs and new TVs are extra costly. Bringing power supply back with me to USA to see if I can buy a new one.
Aug 30, 2008 | Sharp Aqous LC-26D5U Television
Sharp 34" TV
Why shouldn't it be worth fixing? It's only 4 years old, my own TV is 15yo, I fixed it twice but it's still kick'n! You have a problem in the power supply, do you have electronic's know how? And test equipment? Soldering equipment? If so we could walk you through it, If not A repair man should only cost 80 to 100 to fix it.
Aug 13, 2007 | Sharp 32C-240 32" TV
Sharp 21B-S10 21" TV Logo
77 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
