Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool Ultimate Care II LSQ9549L - leaking water
My Whirlpool Ultimate Care II LSQ9549L washer is leaking water. I opened its cabinet and there is a white box with two pipes attached to it. This box is leaking water.
What is this box called and how much will it cost.
  • 1 more comment
  • The Washer Jan 05, 2009
    Thanks that was helpful. Please can you tell me how to find the part number and I can order it on the internet.
    Thanks, Marcon is in US. I am in Canada, Toronto. Who can be contacted over here.
  • Anonymous Mar 13, 2014
    It is not clear how to attach the can opener under the cabinet, with what came in the box and what the attachment items are for.
  • 530 Answers
About $60.00 depending where you live
Posted on Jan 04, 2009
  • 1 more comment
  • erica graber Jan 04, 2009
    I thought i sent you a comment i guess it didn't make it. it's your pump
  • erica graber Jan 05, 2009
    you can look in the phone book for appliance repair stores. there is a place called marcon they are nation wide. try this number it's either 916 488-9394 or just 4889394 they can locate a place neirest to you. and ship one there are only 2 kinds of pumps
    You got me. I did not know that you where in Canada. Is there a Sears in Canada? All you need is the model number off the washer. Call Sears they will find the correct part for your unit. If not maybe look in your phone book for for an appliance repair store. Let me know how it goes
Whirlpool Ultimate Care II Washer will not drain
bad lid switch,open the lid a few inches and close it down,if you do this a few times and don't hear a clicking sound the switch is bad.
http://www.youtube.com/watch?v=PZAbg9uftos
Jun 05, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer is leaking water near the water tube located right in front of the washer. Do I need to replace something or can I seal it?
most likely u will need to replace part.u should remove the cabinet to get a better look at where the leak is . the cabinet comes off from the front.
Oct 27, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
The washer filled up with water and stopped, I tried plugging the washer in different outlet it starting humming and nothing else. Now the washer is leaking.
you have something in your pump and is stopping the motor from running. you will need to remove the cabinet to repair this unit.
Oct 04, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water leaking onto floor from under washing machine
first off check for punctures in hoses,
a leaking pump (common issue, youll see water dripping from pump area)
search you tube for whirpool washer repair, for simple instruction for removing hte outer cabinet
Jan 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer machine Whirlpool Ultimate Care II LSQ9549L is leaking water when I fill the tub with water. I opened cabinet and there is a small white box below the tub that is dripping water. My questions are...
is it filling filling filling and not stopping. or will it fill and stop when it is supposed to. if it's fill fill filling could be a hole in the pressure hose or a faulty pressure switch. but if itt does all the cycles and is leaking you probably have a bad pump tip the unit back a little so you can see under but do not tip all the way you will see the pump. see if it leaking if so replace tha pump.
Jan 04, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care 2 leak after wash cycle
Hello, you may have a small drip from the pump or a small drip from the hose that goes from the pump to the rear of the cabinet. To make sure you will have to run the unit with the cabinet removed. A local service tech can remove the cabinet quicklyand isolate the leak.
Dec 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
I need help in opening my Ultimate Care II washer's housing
two screws on top usually on front take out flip up top you will see two gold clips on each side.take a flat tip screw driver put them in slots and pop loose remove unplug spin switch and lean cabinet forward and slide off .leak could be coming from pump tilt back first look inder it have a paint can or coffe can or tilt it way back and look under it pump on motor is probably leaking then take off case
Sep 15, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
708 people viewed this question
Dan Webster
Dan Webster
Sal De
