I turn on my lcd tv and it will just run for a few minutes then it suddenly turn off. can pls tell me what was its problem. thanks
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Its power supply related or something is triggering the shutdown circuit because of a problem---for a 26 inch it may or may not be economical to fix.
Posted on Nov 03, 2012
3 Suggested Answers
  • 1779 Answers
SOURCE: My LCD Sony HD tv turns off after few seconds.
You need the Inverter Board.
Posted on Sep 14, 2009
  • 608 Answers
SOURCE: ILO 32 in lcd keeps turning itself off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
Trouble Turning TV On
check for a leak or bulged electrolytic capacitors at the power supply board.
Oct 14, 2012 | Televison & Video
My samsung LCD tv turns off every few minutes but will come back a few minutes later . kindly advise thanks
the problem in your LCD tv are think power supply damaged check any damaged capeciter in there if have replace it and try
Sep 04, 2011 | Computers & Internet
My 32" Element LCD tv is broken. One night I was watching tv and all teh sudden there was blue, red and yellow lines running horizontally across teh screen, audio was fine. I turned it off and unplugged...
Yes!
It has suffered a breakdown in the power supply and the damage has also spread as far as the sustain boards that control video and convergence. This is not a DIY and the repair for parts is $300 + labour. However, get a few quotes. At least a 32 in is a little more transportable than a 6' model
Please rate my help++++Thanks for using FIXYA
Jun 28, 2010 | Element ELC-HS321 32 in. LCD TV
I have a Viore RPT50V24DX/SMS TV, That just turns off after a few minutes. When it's on it's nearly perfect, but then it quits. The cooling fan is running, and there's not much dust inside. Any Ideas?
A: Check clearances for proper ventilation, as overheating can occur even with the fans running. B: If A checks out then replace the lamp as it is in failure mode. They do not usually just all of a sudden fail. They give symptoms such as this.
Mar 27, 2010 | LG 42LC2D 42 in. LCD HDTV
Dear Madam/Sir - I have a Grundig Xentia 26'' LCD TV that is 4-5 yrs/o. Recently, when we turn it on, the picture comes on OK but in a few minutes the screen goes black. If I turn the power off at the wall...
Ur backlight video board,dying.Well require changing keep happening.LCD require more power and floescent lights more heat,not like cathoray tube have radiation,but more glass take heat better.
Nov 25, 2009 | Televison & Video
Picture messed up for a while when first turned on, then better
How old is the tv overall? The tv can be repaired.
https://eservice.sony.com/webrma/web/index.do
Follow this link and you can inquire about getting service for the tv.
Thank you,
Lee
Nov 05, 2009 | Sony KDL-46XBR4 46 in. LCD Television
Screen goes dark after few minutes
check your LCD inverter maybe there is loss connection or some parts damage from inverter.
May 05, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Circuit diagram Samsung LE23R88BDX - LCD TV
when I turn off and then Turn on after 10 minutes the TV notwork(by using remote or touch button). I try to disconnect power supply andthen reconnect and waiting a couple of minutes and turn on but no work (nosound and black desktop) .I repeat this procedure many times so some timework and sometimes not work. please help me to solve this problem
Feb 24, 2009 | Samsung Televison & Video
LCD TV Remote quit working
First thing, turn off the TV and unplug it for about 2-3 minutes. Remove also the batteries on your remote. Re-install the batteries on the remote and plug in your TV. Power on your TV using the remote. No luck?
Norcent may not be supported by a universal remote. If you just bought your unit new (maybe Best Buy who carries this brand) you are still covered by its warranty. Below are ways you can reach Norcent.
http://www.norcent.net/main/contact.asp
909) 305-2121
support@norcent.net
Mar 24, 2008 | Norcent Technologies LT-2722 27 in. LCD...
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
Electro Med Services...
