It gets very warm
My laptop gets very warm immediately. It also makes noise.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 137 Answers
Are you covering the vents? If you do that it will get hot easily. Happens when you place your laptop on a bed, try putting it on a table and if you still think it's hot get a cooling pad.
Posted on Nov 03, 2012
97 grand marquis engine makes a knocking noise
have the timing checked if its off it could be pre-ignition which some people describe as a knock. if its a heavy knocking noise it could be a piston noise or it may even be a bad crankshaft/connecting rod/bearing. have the oil pressure checked this may help to know what to do. some people describe a rocker noise as a knock but its more like a ticking noise at the top end in the area of the valve covers.
Sep 11, 2014 | 1997 Mercury Grand Marquis
Squeeky fan belt noise after driving a little
It sounds as if the belt is dry. Belts dry out after a certain amount of time and then start to make chirping noises. If the belt is not badly cracked, you can try using a belt lubricant spray. These sprays usually only last for a short period of time, though.
Mar 27, 2014 | 2003 Fiat Siena
Tick tick tick noise
Make sure there is no disc in the cd/dvd drive. make sure that fan vents are clear. Does this start when you turn it on, or when it warms up after about 5-15 minutes? The only stuff that moves in a laptop is a dvd drive, a fan or the hard drive (unless you have an SSD installed). The ticking noise may be one of these. The dvd drive is not an immediate problem unless you need it, NOW. The other two options are definitely important and I would not putoff getting this looked at, as they are internal and difficult to get to. If you are comfortable opening and working in a laptop that you are ahead of the game, but I can go no further, with so little information.
Nov 02, 2013 | Dell Inspiron Computers & Internet
Ticking noise in engine .louder when warm.is it the cam chain
A ticking sound that gets louder as the engine warms up usually is an indication of the valves need adjustment. The clearance between the valve stem and the tappet on the rocker arm will get larger over time and needs a periodic adjustment. The cam chain can make noise as well, but "usually" more of a continuous noise that will change with rpm's (may quieten when accelarating/deccelerating). If it is the valve clearance, it is not an immediate concern, but should be adjusted to prevent unnecessary wear on the tappet/stem. Another way to tell is if it quitens somewhat with an oil change. Newer oil will provide more of a dampening effect on the contact between the stem and tappen, thus reducing the noise.
May 28, 2011 | 2000 Harley Davidson FXD Dyna Super Glide
My Audi A4 2009 makes a rattling noise on cold starts which resolves in less than 30 seconds. Dealer says its an air pump. This doesn't seem correct. The noise comes from the front of the care. Does not...
READ THIS (happy ending so far...):
audi a4 2L turbo quattro, manual transmission with 98,000 KM. Perfect conditions, no oil leaks whatsoever.
Left the car off for two weeks in very cold weather (-10C down to -25C). When I restarted, it started immediately but with heavy rattling noise due to camshaft adjuster not getting enough oil pressure. After 3 minutes of warming up (outside temp.: -12C) at very low rpm (below 2,000rpm), I start moving the car. Still hearing heavy rattle noise. As soon as I pass 2,000 rpm, I get a scary red warning, low oil pressure. Turn off the engine immediately. In 1 minute, I re-start the car and the engine lights check ok, so I drive in first gear super slow (1,200rpm) hearing the same rattling noise. After another minute, finally the noise all the sudden disappears and the car starts running just fine.
Called Audi dealer and they told me that in extreme weather conditions, I should warm the engine for 10-15 minutes if necessary before start moving.
Take away: luckily, I didn't screw up the engine since I was using it at extremely low rpm (easy to do with clutch and manual transmission) until the oil reached full pressure. I am pretty sure now that the problem was leaving the car off for such a long time in freezing weather. All the oil flows back to the bottom, and when I restarted it, the cold oil with high viscosity took a long time to reach all the parts of the engine, specially the camshaft adjusters that are actuated by using oil pressure. Next day, the car started at -9C perfectly without making any noise (as usual). Basically, the longer you leave your audi in cold weather, the longer you might hear the rattling noise until the oil reach full pressure inside the engine. My car took 6 minutes to fix it after couple of weeks in cold weather. This makes sense to me; in fact, in the past I only heard the rattling noise after leaving the car off for a couple of days in the winter.
So far, this has had an happy ending....
Dec 19, 2010 | 2009 Audi A4
E6500 making a beeping noise
Does beeping noise happened before turning on laptop? If yes unplug the laptop from the AC Adapter. Just leave AC Adapter ON and connected to the power outlet. Check if AC Adapter is the one making beeping noise. Note: This is an issue with dell AC Adapter laptops
If no beeping noise in AC Adapter then proceed checking it from the laptop. Does beeping noise happened immediately when laptop is turned on? If yes then it might be laptop's hard drive creating the sound. Try to check the BIOS in your laptop under the category performance if the HDD Acoustic is ON either in Normal or Performance. Note: When laptop is in performance the hard drive makes noise due to its speed, this is normal if BIOS HDD Acoustic mode is ON to performance.
If the noise only happens when sometime while working on the laptop, this might be cause by the laptop fan. This also happens after turning on the laptop fan my have dirt and dust, please do check.
If fan was cleaned, HDD performance was checked and AC adapter was checked then, carefully sense if noise is coming from the internal speakers.
Download the latest BIOS update for your laptop then flash the BIOS. Make sure battery and AC adapter are connected when doing these.
Dec 11, 2009 | Dell Latitude E6500 Laptop
My acer travelmate 4150 when switched on makes a constant screaming noise and does not boot up
Try this: once you turn on your Acer Laptop, immediately it shows the acer logo on your screen, press 'Esc" button constantly or press the "Esc" button continuously immediately you turn on your laptop.
I am telling you to do this out of experience, but if it does not work, let me know.
Take care.
Dec 08, 2009 | Acer TravelMate 2300 Notebook
Noise when engine is warm and driving
4 or 6 cylinder? 4cyl. it is probably the t- belt slapping or one of the driven by belt items on the motor.
Jun 30, 2009 | 1999 Toyota Camry
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
