Question about Star DP8340-FM Receipt Printer
Alarm signal is on and not going to be off star 8340
The printer not going to on line
Canon mf 8340 will not scan despite full reinstall. Black toner level is low
When it won't scan will it copy, please? Will it print?
Best wishes,
Robbie
Mar 17, 2015 | Canon i-SENSYS MF8340CDN Laser...
Printer prints one line, then alarm light comes on and stops printing.
Sir the printer is giving line because the cartiage or toner is not of good quality so it does not melt properly and produces line while the alarm comes and stop printing is due to the problem in charging cathode or gutter
Jun 03, 2013 | OKI MICROLINE 321 Turbo Matrix Printer
Redcare alarm system won't work with sharp
Yes you are correct.
What happens is most , not all things attached to the same line as the fax, that require monitoring will interfere with the incoming fax.
I can go through the technical explanations but it has mostly to do with the ammount of signal received to the fax and it not being high enough to turn on the fax.
The best explanation I can give you is to compare it to trying to use a TV remote with low batteries. It may be enough power but most of the time it will not be.
The cure for your problem is to seperate the fax from teh alarm system.
Unlikely any type of filters will work. I have run into this issue with alarm systems, credit card readers, etc when attached to the same line as a fax.
Aug 02, 2010 | Sharp MX-2300N Color Copier
I wa schanging a tail light on a trailor attached to 1996 Bronco must have shorted something. Now all sorts of problems 1 won't start 2 alarm keeps going off no turn signals n no brake lights Can't...
Remove the in-line fuse for the alarm. If the alarm faulted out it is activating the starter kill switch and the lights issue is the alarm trying to flash the lights.
Sep 12, 2009 | Ford Bronco Cars & Trucks
I have a blinking star/starburst animated graphic in the top left hand
it's an alarm Iget that a lot. tap on it. it opens an alarm. Then you can clear it. It's a feature!
Sep 11, 2005 | Palm Tungsten E Handheld
Star DP8340-FM Receipt Printer Logo
20 people viewed this question
Top Star Office Equipment & Supplies Experts
ray gallant
Cara Lee
Cara Lee
Level 1 Expert
Are you a Star Office Equipment and Supply Expert? Answer questions, earn points and help others
