Question about Hotpoint First Edition WMA12 Front Load Washer
Hotpoint First Edition 1000 WM52
It does the wash, but is not turning and jus makes a click nose, can you help please?
I had same problem. Had to replace brushes on motor. Easy enough job to do yourself
Posted on Mar 18, 2010
No power to my hotpoint wm52 washer
Check the wall socket with another electric gadget. Check your washer plug fuse. Finally open up the rear (after taking the washer power cord off the wall of course!) and disconnect and reconnect all wires and connectors one by one. Possible it could just be a loose connection somewhere. Sometimes happens due to vibration.
Click so pl if helped.
Feb 27, 2013 | Washing Machines
Hi, i have a hotpoint 1000 wm52. Its stopped working all of a sudden yesterday. The drum wont turn, so i opened up the top and it is clear that the cam belt from the motor to the drum has come off and got...
You need to put it back on. I would get a new belt and just cut the old one. Check your manual for a diagram Ben. If it doesn't have one, call customer service. If you have a question, just write me back. I will help you as much as I can. A vote is greatly appreciated if you appreciate the reply. If you need anything, write me back Ben. I will be here. Thanks
Feb 25, 2011 | Hotpoint Washing Machines
Stopping mid cycle, not taking softner, doing a
OKAY.....Could be cold water not entering the machine , due to turned off. or faulty valve coil not too expensive to fix...
May 24, 2010 | Washing Machines
I have a Hotpoint WM52 that fills but will not spin / rinse
Check the brushes in the motor, and replace if less than 5mm or or so in length.
Please rate my solution.
Thanks.
Aug 11, 2009 | Hotpoint First Edition WMA12 Front Load...
Hotpoint first edition automatic washing machine washes clothes .
I've got a Hotpoint First Edition WM52 that stopped spinning at the end of the wash cycle. Called the repair man and he said it was most likely just the filter blocked? Suggested I reemove the front base panel and try to locate the filter remove, clean and replace. Front panel wouldn't come off, base panel at the rear, 6 screws to remove revealing a black squeezy hose with slide grips holding them on, on removal of the hose two ten pence pieces, a one pence piece and a childs hair clip blackened with dirt sat blocking the top of the hose.
Hope this helps; repair man saved me £58+vat just with a few words and a bit of persistence from myself
Jun 17, 2009 | Hotpoint First Edition FEW10P Front Load...
No instructions
Go to:
www.hotoint.co.uk.
Scroll down and click on www.hotpoint.co.uk.
Click on after sales and then click on down load instruction books, type your model number in and you can save it to your hard drive, or print it off.
Plz rate my solution.
Thanks.
Dec 16, 2008 | Hotpoint First Edition WMA12 Front Load...
Hotpoint First Edition 1000 WM52 the turner thing for different washes is very hard to turn now, the machine seems to struggle.
Hi.
It sounds like the timer is stiff, remove top cover, and spray WD40 liberally over and into the timer unit at the front right of the m/c.
If the motor is struggling to turn then you have another problem as well.
Good luck.
Nov 23, 2008 | Hotpoint Washing Machines
Hotpoint first edition wma12
thats the problem its arking and making the breaker trip. if this helps please rate joe
Aug 18, 2008 | Hotpoint First Edition WMA12 Front Load...
Hotpoint WM52 first Edition
I think you will find that if you check the brushes, you will probably need to replace them.
Oct 27, 2007 | Hotpoint Aquarius WMA52 Front Load Washer
Why dont my machine take the soap powder
Assuming that the bit the water is going into is the prewash dispenser (rather than a bleach or conditioner dispenser), why not just put the powder into there? Some of these machines can be a bit illogical about where the main wash powder is meant to go - sometimes even varies depending on which cycle you're running. If you can find a place that will take the powder at the right time, your problem is solved. If the instructions say different, it might even be them that's wrong. Wouldn't be the first time. A.
Mar 04, 2007 | Hotpoint WM56 Front Load Washer
Hotpoint First Edition WMA12 Front Load Washer Logo
1,328 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
